Changing to syntheic oil
Discussion in 'Performance and Tuning' started by Mouse, Jun 2, 2008.
  1. Jun 2, 2008 at 6:12 AM
    Mouse
    Mouse [OP] Active Member
    Charlotte - NC
    08 PreRunner SR5 w/ Sports Package
    Indigo Ink Pearl Exterior Graphite Cloth Interior, TrueFlow XDi CAI, Redline Tunning Hood Struts, Bluetooth Handfree Phone System, Tinted Windows. Chrome: Bull Bar, Billet Grill, Tail Light Guards, Tailgate and Door Trim, AC Vents.
    As stated in my other forum posting...im a computer geek not a gear head so please bear with me on these noob questions.
    I am insterested in switching to a synthetic oil. How do I go about doing that? I have my first oil change coming up and would like to do it then.
    Do I need to drain the oil and then flush the system before I put in the synthetic stuff? Do I just drain and replace with synthetic? I was told by one person that I had to put some type of cleaning solution in to get the old regular oil out before I could successfuly use synthetics...
    Seems like a lot of people have changed to a syntheic and are getting some benefit from it. Please share with me how I can change to syntheic oil as well...
    Thnx
    Mouse
  2. Jun 2, 2008 at 6:19 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Just drain it and replace with synthetic. Don't forget to change the oil filter. If you're unsure about changing oil, I would take it to a professional and have them replace it.
  3. Jun 2, 2008 at 6:27 AM
    Mouse
    Charlotte - NC
    I am really wanting to start doing most of my service myself. I had a 2000 celica before my Tacoma. I took it in for an oil change and they drained it and never refilled it with oil. As I drove to work I blew the engine and they got away with not refunding me for the damages...My tacoma was my celicas replacments.
    You know what they say...if you want it done right...you have to do it yourself.
  4. Jun 2, 2008 at 7:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    As Klown mentioned...
    No flushing needed. Just drain & fill.
    Do a lot of research before you tackle the job. It's an EASY job once you know exactly what you're doing. Paticularly...know exactly which bolt is the drain plug (NOT the transmission drain plug).
    Change the filter and look in your owners manual for how much oil you need to put in.
  5. Jun 2, 2008 at 7:22 AM
    Mouse
    Charlotte - NC
    Thanks...
    Im getting a copy of the 2005+ service manual now...I would expect it to show exactly where the oil drain plug is.
    Is there a special synthetic oil filter...or is an oil filter and oil filter?
  6. Jun 2, 2008 at 9:57 AM
    1killerkaw
    1killerkaw Well-Known Member
    08 Silver DC LB SR5 4x4 Tow Pkg.
    Pop-N-Lock, AFE OE Replacement Pro Dry S, 20% tint all the way around, 6000k Bi-Xenon HIDs, 3" Dynomax super turbo muffler, ATC LED Limited campershell, Bedrug, Suspension TSB.
    I use Wix or Napa gold oil filter with Castrol syntec.
  7. Jun 2, 2008 at 10:07 AM
    klown
    Lynchburg, VA
    I just get the toyota oil filter that you can buy at the $tealer.
  8. Jun 2, 2008 at 10:19 AM
    Janster
    Jandy
    Lancaster, PA
    Oil filters & synthetic oils - there are many different types & brands. You can use whatever you want. It's a personal preference. You can easily research oil filters and see what folks are using.
    I'm running toyota filters - no paticular reason why. I got a case of them for a good deal and figured I'd stick with OEM.
  9. Jun 2, 2008 at 2:26 PM
    Bakemono
    Bakemono Wrath of the runbird
    Southern Wisconsin, USA
    '09 Toyota Tacoma regular cab 4x2
    Just drain out the old oil, replace the old oil filter and refill it with synthetic. There is no need to flush the engine.
    Id suggest using either a Toyota OEM oil filter or a Wix and any oil is fine as long as its a name brand (Mobil, Castrol, Amsoil, etc...) and isnt Pennzoil.
  10. Jun 2, 2008 at 3:05 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    What's wrong with Pennzoil?
  11. Jun 2, 2008 at 3:07 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    :spy:
  12. Jun 2, 2008 at 3:26 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    Hopefully not much cause about 20 minutes ago I put in 5.5 qts of Pennzoil Platnium.
  13. Jun 2, 2008 at 3:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hell yeah!!! damned good stuff!!!
    nothing at all wrong with pennzoil platinum......i have been using it in my tacoma for 12k miles.....no problems whatsoever!!! its as good, if not better than mobil1(an oil i like also).
  14. Jun 2, 2008 at 7:10 PM
    Bakemono
    It has a reputation for leaving a lot of dirt and gunk in the valvetrain. IMO, Pennzoil is to oil what Fram is to filters...
  15. Jun 2, 2008 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have heard the same thing, and did some tests on the older stuff that proved its usefull life was spent at less than 1500 miles, but Im not sure about the newer stuff. I hear some good things about it.
  16. Jun 2, 2008 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    tests on.....http://www.bobistheoilguy.com/forums/ubbthreads.php......show the pennzoil platinum to be really good oil. they do their fair share of testing over there. i havent had any problems with it since i've been running it.
  17. Jun 2, 2008 at 7:17 PM
    Bakemono
    Yup, same here. Personally, I wouldnt run Pennzoil in my lawnmower, much less in my truck.
    Ive personally always been a believer in Castrol. I ran Castrol GTX in my '85 4Runner. When I sold that thing it had over 245,000 miles on it, didnt burn a drop of oil and ran like it was brand-new. Castrol is kinda pricey, but its good stuff.
    Almost any of the name brand oils are good though. A lot of people make a big fuss that you have to run Mobil 1 or Amsoil or Royal Purple or whatever, but the fact is that as long as you change the oil every 5,000 miles an engine will just about run forever no matter what oil you use. IMO, doing the proper maintenance is the most important thing you can do to prolong the life of your vehicle.
  18. Jun 2, 2008 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    At your next change, could you have an analysis done so we can see how it looks on the Tacoma 4.0 engine?
  19. Jun 2, 2008 at 7:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i may give it a try. i had seen a while back on tn that a couple of people had done an analysis on the 4.0 with the pp, theirs turned out pretty good.
  20. Jun 2, 2008 at 7:23 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I just changed my oil. I used Mobile 1 synthetic with Mobil 1 filter. The engine sounds much smoother now that I've got synthetic in there. I don't drive much, so I figure I'll just change the oil every six months.
