Chasing down a vibe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Notoneiota, Oct 29, 2024.
  1. Oct 29, 2024 at 7:58 AM
    Notoneiota
    Notoneiota [OP] Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I have a vibration going that I can't figure out. Starts at 60 mph. Steering wheel wiggles and seats vibe. Steering feels lighter and jumpy.
    Truck is 100% stock. No lift. No accidents. Stock tires. Truck has 253k miles and vibes stared at about 250k.
    Things I've done:
    - new inner and outer tie rods
    - new end links
    - new tires
    - alignment
    - new wheel bearing hubs on both sides
    I've checked all nuts, wiggled and pulled on everything. The only loose component I can come up with is maybe the needle bearing on the driver's side. The cv axle has a lot of play up and down and in and out. The other side barely moves.
    To add some data, it happens when going straight on the highway and def kicks off at 60 mph. When in a turn the vibes settle significantly and then amplify when straight again. I will also throw in that they get really bad when pulling a trailer - like the load on the truck just makes it shake even harder.
    Thoughts? Needle bearing? Bad CV axle? Maybe even bad U joints in the drive shaft?
  2. Oct 30, 2024 at 9:23 AM
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    Try having your wheels "road force balanced". Not all shops have the ability but it's worth seeking one out that does with your symptoms.
  3. Oct 30, 2024 at 9:55 AM
    Notoneiota
    Oakdale, MN
    I'm thinking this is my next step. It has to be the tires. I was messing with it yesterday on the freeway and kicked it into neutral while going 70 mph. The vibe never changed when I took the load off the driveline.
    Now to find a shop that has the machine near me. The tires are brand new Michelin MS2s but I got them at Sam's and I'm pretty sure they were spin balanced.
    Black97v6MT and 2001 4x4[QUOTED] like this.
  4. Oct 30, 2024 at 4:50 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Might I suggest you check your u joints and Carrier bearing?
  5. Oct 30, 2024 at 5:00 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I could be wrong but i believe even in neutral your driveshaft will still be spinning cause the rear wheels are spinning.
    Most dealers will have road force balancers, I work at a dealer and while most tires are fine with just spin balanced, road force balancing is particularly useful for vibrations. You can ask Firestone and Discount Tire if they do road force balancing. Michelin tires are top shelf.
    Its rare but I've seen a few times where the cv axle joint causes vibrations.
    Black97v6MT likes this.
  6. Oct 31, 2024 at 12:07 AM
    Taco'09
    Taco'09 Well-Known Member
    Yes, some Tacomas are particularly sensitive to wheel balancing. Mine is one of those. What I do is the road force + this adapter:
    suoo2-96.pdf
    I had difficulty finding a shop in mine that had the adapter so I purchased one. But I have been told by Discount Tire that they have an identical one but have yet to verify.
    2001 4x4[QUOTED] likes this.
  7. Nov 6, 2024 at 8:22 AM
    Notoneiota
    Oakdale, MN
    Just wanted to update the situation.
    I found a shop that had a road force balancing machine, but I decided to give the original shop one more try before I paid someone else to do it.
    When I went to the tire shop I got the tires from I asked for a rebalance. They said no problem and would get me in immediately. I commented that I noticed that tire shops don't seem to use weights on the outside of the rims anymore and instead pile on the sticky ones inside the rim. I asked if it was better to put them on the outer lip of the rim and they said they usually get better results doing that but people don't want them showing anymore so their policy is not to unless requested. I told him I have 250k on my truck and could give a crap about the rims. I just want them balanced and smooth on the road.
    Well, they removed the sticky ones inside the rim and just used the outer clip on ones and my vibes are 100% gone.
    I still have a groaning noise in sweeping left turns, but I'll maybe post about that separately later.
    Black97v6MT, mstx84 and 2001 4x4 like this.
  8. Nov 20, 2024 at 12:58 PM
    mstx84
    mstx84 New Member
    That’s so weird, so it was a balancing issue?
