Cheap and semi easy organizer for center console.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DEEVON911, Feb 3, 2012.
  1. Feb 3, 2012 at 9:09 AM
    DEEVON911
    DEEVON911 [OP] Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Hi all, figured I would do a quick write up on this for anyone looking to organize the center console in the 2nd Gen's.
    1st I would like to give credit where credit is due, even though this is not the exact same thing, I got the idea from this thread http://www.tacomaworld.com/forum/2n...50-center-console-power-inverter-install.html OP jackrules.
    So I wanted something because I have a bunch of shit in the center console and it was always a pain in the ass to find something in there. I don't have any pics with everything in there, but it was pretty much filled to the top.
    So I started out buying this
    At Home Depot for $14. Its pretty much the same as the Lexan stuff that is a lot more expensive.
    So I measured out 6 1/2 inches for the height of the console (top to bottom)
    Now this is the 1st time I have ever worked with this stuff, so I'm not very good with it. I used a utility knife and a strait edge to cut this part, since it was pretty long. I'm sure there is a better way, and that would make a cleaner cut, but this is what I did.
    So I cut out a strip 6 1/2 inches tall all the way down the length of the piece of Optix.
    Then I cut a piece 10 1/4 inches long
    This is the length from front to back of console.
    Then I cut 2 pieces 7 1/2 inches long.
    This is the width of the console and it is between the hinges of the console lid. If you know what I mean, and if you don't , you will see what I mean in the finished product.
    Also I used a Dremel for these shorter cuts, which was a pain in itself. Went through a few cut off wheels.
    So then I put the pieces for the width of the console, in the console and figured out where I wanted to divide them with the one longer front to back piece. This is something you can figure out yourself, because you can put it anywhere you want. I just set up the 2 smaller pieces where they will go, then I held the longer section on top and put a mark where I wanted to put it.
    Then I measured half way down the piece, and went a little more to give myself some play and drilled a hole.
    Used a 9/64" size bit, which is slightly thicker than the Optix.
    Then I used the Dremel and cut a slot down to each hole I drilled in all 3 pieces. (sorry, no pics of the slots) This is going to let it fit together like a puzzle.
    Not the greatest pic, but here is is all fit together.
    And here it is all together inside of the console
    And here it is with all my crap in it.
    SO much better than before, and actually gave me more space for other things! And using the clear Optix, lets you see where things are also.
    So there you have it. This is not the nicest or cleanest thing I have ever made, and I will probably make another one some day, and do cleaner cuts and whatnot, but I'm happy with it for now and figured I would share it with you guys, in case anyone wanted something like this.
    All in all, took me about 45 mins to do, so its something that does not take long to do.
    Enjoy!
  2. Feb 3, 2012 at 10:08 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Great idea!+ rep.
    Ps look at all those smokes! Lol
  3. Feb 3, 2012 at 10:11 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Nice idea but .... y'all got to cut down on the smokes .... :rasta:
  4. Feb 3, 2012 at 10:12 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Good idea! If I were not so lazy, I'd do this too. :anonymous:
  5. Feb 3, 2012 at 10:19 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Cool! I dig, better than shit rattling around like a bearing in a paint can.
  6. Feb 3, 2012 at 10:52 AM
    DEEVON911
    Dave
    LOL, I knew I would get comments on the cigs. I just buy a carton and keep it in the truck. :D
  7. Feb 3, 2012 at 10:59 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    LOL, I do the exact same thing. But I sure wouldn't advertise it online...oh, wait. :crapstorm:
  8. Feb 3, 2012 at 11:03 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I don't smoke but I like your stash. Bad ass.
    Don't apologize.
    Also nice work on the organizer. Mines a cluster ... all the time.
  9. Feb 3, 2012 at 11:07 AM
    r6hokie
    r6hokie Well-Known Member
    Virginia
    tint, fog light anytime mod, weathertech visors
    where do the condoms and listerine go?
  10. Feb 3, 2012 at 11:08 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    Great idea, it is now on my future mod list.
  11. Feb 3, 2012 at 11:13 AM
    bangarang
    bangarang Active Member
    Alex
    Panama
    '12 Hilux D4D 2.5L Dbl Cab 5 mt
    great mod! now that's a smoker...
  12. Feb 3, 2012 at 11:13 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    Doing this soon. Great idea & good pics. Thanks OP
    And way to be a man & credit where u got the idea!
  13. Feb 3, 2012 at 12:20 PM
    DEEVON911
    Dave
    I'm married, with a pregnant wife, don't need that shit! :D
  14. Feb 3, 2012 at 12:30 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Good idea, looks nice. I only keep CDs in mine though. (And cigarettes, if I happen to drive through a state that sells them cheaper. Haha.)
  15. Feb 3, 2012 at 1:36 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    nice job!
  16. Feb 3, 2012 at 3:23 PM
    DEEVON911
    Dave
    Not to many states that are cheap anymore. :sad:
    :thumbsup:
  17. Feb 3, 2012 at 3:27 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Yeah, it's lame. I generally pick some up in Missouri when I make the Arizona-Wisconsin drive...
  18. Feb 3, 2012 at 3:49 PM
    DEEVON911
    Dave
    Yeah West Virginia is the closest that has a little cheaper. I hit up stores down there when I go.
  19. Feb 3, 2012 at 3:52 PM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Nice! Way better than just digging through a pile of random crap I've thrown in the center console!
    Hey... Can I bum a smoke? Lol that's an impressive collection!
  20. Feb 3, 2012 at 3:59 PM
    Blueridge
    Blueridge Well-Known Member
    Poor truck probably smells like a butt :rasta:
