Cheap easy lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DustinSK, Aug 20, 2011.
  1. Aug 20, 2011 at 3:52 PM
    DustinSK
    DustinSK [OP] Well-Known Member
    Im sure there is a thread somewhere but at the moment I dont have the time to look. Just wondering if there was a relatively cheap do it yourself lift to put on your tacoma without bringing it to a shop. I have a 02 prerunner xtra cab 2wd and was looking for the cheapest way to add 3-4 inches?
  2. Aug 20, 2011 at 3:57 PM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    Bilstein 5100 (2.5") aFe short ram intake KC light bar PIAA halogen Lights Hella Lights on top Yakima Load Warrior
    top strut spacer. (not a coil spacer)
    blocks in the rear.
    good luck with that setup. it sucks
  3. Aug 20, 2011 at 4:09 PM
    DustinSK
    hah so basically any cheap lift sucks.. What would I be looking at if I went to a shop for a 4inch lift? Is it worth it when I have 135,xxx miles?
  4. Aug 20, 2011 at 4:23 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    Assuming your shocks are okay, you'd need to buy a new set of coil springs for the front, and a new leaf pack for the back. IIRC new coils are around $180 and a new leaf pack is +$500.
    My suspension is shot, so I'm looking at lifting too.
  5. Aug 20, 2011 at 4:26 PM
    magixfinger
    magixfinger Well-Known Member
    Tail gate mod | shorty antena mod | K&N drop in filter
    cheap lift ended up paying more in the long run buddy
  6. Aug 20, 2011 at 7:08 PM
    DustinSK
    Alright well say new coils and a leaf pack and bought some quality stuff. If I did research and had some buddies over you think an amateur could get it done?
  7. Aug 20, 2011 at 7:15 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I've put about 1,200 into my lift and it rides better than it did stock.
    I got new coilovers and uca's up front, an add a leaf, new shocks and extended brake lines in the rear.
    I also put it on myself. There's write ups on here on how to do everything I did and I just followed those. Just bag and label everything you take off and take your time, it's actually pretty fun IMO.
  8. Aug 20, 2011 at 7:31 PM
    MacGyvR
    Tom
    Arizona
    Having never done it, I couldn't tell you. Search around TW and try to get a feel for the amount of work and time that will be required.
  9. Aug 21, 2011 at 12:29 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yeah go with an OME set up, they are affordable and give a good ride,
    and its definitely doable yourself! just pay the fee for them to put the coils on new shocks, or have a shop do it, I did it with the autozone rental
    but I won't do it again, and then yeah its real simple to put the coilover in,
    just have somebody put their weight on the lca to
    push it down
  10. Aug 21, 2011 at 12:37 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    haha cheap and suck..ALWAYS go together my friend lol
    Yes its worth it. Putting new fresh parts on and old beat down suspension...ALWAYS better haha Can't ever go wrong with replacing everything with good quality parts.
  11. Aug 21, 2011 at 1:40 AM
    tacomarotto
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    yea OP,
    take this guys word for man. he just got a brand new setup that is legit.
    new leaf packs. coils. and shocks.
    boom.
  12. Aug 21, 2011 at 12:10 PM
    DustinSK
    Alright thanks everyone. Ill do some more research and look in to it some more. Thanks guys.
  13. Aug 21, 2011 at 12:57 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  14. Aug 21, 2011 at 1:05 PM
    DustinSK
    Thanks guys. Do any of you have, well actually Im sure you do, have a 2.5inch lift on your truck that I could see? Im interested in lifting my truck primarily just for looks not really off road performance, after all I have a 2wd anyway. I just want to see how noticeable a 2.5 inch lift would be
  15. Aug 21, 2011 at 1:10 PM
    Warhorseforever
    Will
    Sand Lapper
    If you have a jack and stands you could lift the truck on a level surface to the height you want it to put a jack stand on it the repeat for all four corners measure it with a measuring tape for height, and find one you like. :thumbsup:
  16. Aug 21, 2011 at 1:23 PM
    feltsphoto
    feltsphoto Well-Known Member
    NKY
    2010 TRD off road pkg 4x4
    As of now... completely stock, but hopefully not for long
  17. Aug 21, 2011 at 1:38 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    Also remember if you get bigger tires, ride height will be brought from those aswell. Not alot but it does make a difference in look.
  18. Aug 21, 2011 at 2:15 PM
    DustinSK
    Dang thanks for all the help guys! Okay so feltsphoto for that setup, that has everything included correct? That I would need to do the lift, except for the tools obviously.
    And warhorse I would do that but quick amateur question. Higher the lift the more expensive? Or am I being dumb. Because I was originally thinking 4-5 inch lift but all Im seeing is 2.5 to 3 inch lifts..
    And I already have 31in tires but if I lift next time I need tires Id upgrade to what 33s probably.
  19. Aug 21, 2011 at 2:33 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    The reason for seeing the 2.5-3 inch lifts is because after 3" your going to have to go drop bracket lift. Also 31's are about 2 inches taller than stock so that's an extra 2 inches in just the tire making it taller. Correct me if I'm wrong anyone. Don't want to throw out bad info. It's just my thought
  20. Aug 21, 2011 at 6:23 PM
    Warhorseforever
    Will
    Sand Lapper
    Bigger doesn't mean pricer by much. You are 2wd so no front diff drop or anything like that needed. Higher than 3 would mean new uca which is a good idea anyway but not needed, also drop brackets for rear springs which is the easiest thing to do in a lift.
    The only way you could be dumb is to not ask question's I havent been on this website but 3 months, and have realized that the people on here know what they are talking about and aren't trying to sell you the most expensive pos thing they can, they want what's best for you, your truck, and your budget.
