Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Mar 5, 2008 at 3:29 PM
    #181
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Under warranty... did you requested a replacement? ... at the end everything it is covered... before 36K or 3yrs
  2. Mar 5, 2008 at 3:54 PM
    #182
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Why? The damn things would just break off again. Would they replace my front-passenger fender as well to replace the plastic ripped out by the flap mounting bolts? Not that it matters now... I'm out of bumper to bumper warranty. Just curious though.
  3. Mar 5, 2008 at 4:06 PM
    #183
    mvega1969
    Laredo
    Well yes they will cover all before the 36K or 3yrs, and getting a replacement at least will work for a "BRAND NEW" sale at ebay.
  4. Mar 8, 2008 at 7:37 AM
    #184
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    I installed this strut on my 2008 Tacoma. It works great and I love it. Installation required me to drill out the bolt in the tailgate, go to Lowes and buy a metric flat head bolt to replace it and a trip to Napa for a metric tap to clean up the threads. The OEM bolt has thread lock on it and was very difficult to remove,,, especially with a Torx drive (it stripped and would budge the bolt).
    Nice mod once it's all done though. Ends that annoying slam of the tailgate if you let it go accidentally.
  5. Mar 8, 2008 at 7:45 AM
    #185
    piercedtiger
    Jon
    Southern Tier, NY
    I end up using an impact and torx socket bit to remove any torx bolts on the truck now... Breaks the thread locker loose.
  6. Mar 9, 2008 at 7:21 AM
    #186
    piercedtiger
    Jon
    Southern Tier, NY
    This mod is similar to Alternating Turn Signal/Side Markers (#27), but doesn't use relays!
    From what I can tell the side markers blink with the turn signals when they are off, and opposite of the turn signals when the parking lights are turned on. I'm not sure yet as I haven't done it yet. Will post up after I try it.
    Parts:
    • 2 pieces of wire
    • 2 butt connectors
    • 2 quick splices
    • shrink tube, electrical tape, etc
    Just cut the black/white wire on the side marker and splice it into the Red/black on left. For the right cut the black/white and splice to red/yellow.
    Like this:
    If you did the DTRL mod (#6) the the wiring will look something like this:
    Green wire goes to empty hole on turn signal plug, and the white/black wire from the markers go to the appropriate red/yellow or red/black wire on the turn signal (cut, not splice the white/black one).
    Original thread here:
    Another way to get side-markers to blink? - Toyota Forums :: Toyota Nation
    Thanks to Jungleman for trying it, and others for their contributions! :D
    Edit:
    Running Lights on-alternating, Running lights off-synchronized.
    tbird95 and xPineapples like this.
  7. Mar 10, 2008 at 4:02 PM
    #187
    piercedtiger
    Jon
    Southern Tier, NY
    I did the alternating turn signal mod above today.
    Some actual pics of the mod, and a video of it in action.
    White/black wire spliced to red/black on driver side. Same setup for passenger with red/yellow wire. White/black wire was long enough to not need extra wire so I just cut both, stripped the 3 ends, and shrink tubed them after twisting together. I also applied a layer of liquid tape just to help weather proof them. Damn salt around here has a way of getting in connectors, shrink tube, electrical tape, etc and corroding the wires.
    Turn signal plug (red wire for DTRL mod)
    th_DSCF2355_2796299c2cf89adade5720b81a0cf6315c468353.jpgWire's spliced together:
    th_DSCF2352_85008b0ca540f9a020494d7294bdec67fb5b5b28.jpgth_DSCF2353_a3ebe80431c4d2974e6b28660af84986b598dfac.jpgth_DSCF2352_85008b0ca540f9a020494d7294bdec67fb5b5b28.jpg
    Video: (passenger side just DTRL mod, driver side with mod)
  8. Mar 10, 2008 at 4:43 PM
    #188
    piercedtiger
    Jon
    Southern Tier, NY
    Thanks! It's pretty cool! And free! :D Just swap a couple wires.
  9. Mar 10, 2008 at 6:28 PM
    #189
    jungleman
    jungleman There can be only one
    North California
    2005 Access Cab Indigo Blue
    Don`t thank me I`ll try anything once.....
    If anyone deserves the credit it`s jeddak for posting up this link to Daniel Stern to begin with
    http://www.danielsternlighting.com/tech/markerflash/markerflash.html
    I don`t know why, but when I looked at that and the way he explained it something clicked in my head like a light bulb.
    I`ve been over and over the diagrams and just never saw it for what it was I guess.
    But then I never considered the alternating configuration of the system either. Every time I came back to that as a solution I immediately wrote it off as either a blown fuse or a blown bulb
    "That`ll never work"
    Let that be a lesson to me
    Never say "it can`t be done"
    Speaking of which
    I just had another brilliant idea.....
    wait
    lost it
    it involved something to do with having an armload of gear, walking up to my locked truck to put the gear in the passenger side, hitting the remote button once and then dropping the remote, something to do with wiring the pass. side door lock/unlock mechanism through the drivers side motor eliminating the need to push the button twice.......hmmmmmmm :cool:
  10. Mar 10, 2008 at 6:36 PM
    #190
    piercedtiger
    Jon
    Southern Tier, NY
    Have to look at the electrical schematics. I wonder if you could find the wire that unlocks the driver door via remote, the wire that unlocks the rest via remote, and tie them together. Or swap the wire from passenger doors to the driver door one. I'm assuming, of course, that there's 2 wires. One that sends signal with 1 push, and another that sends after 2......
  11. Mar 10, 2008 at 8:28 PM
    #191
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Hey nice work as usual, on the video it looks like the passenger side running light is not working. Did something go wrong?
  12. Mar 10, 2008 at 10:08 PM
    #192
    jungleman
    North California
    The unlock "shares" the same power wire to both motors. The drivers side powers up on the first push, pass on the second. But the same wires carry power at the same time when using any switch other than the drivers side door key switch which is set up the same way as the remote.
    But that is exactly what I was thinking.
    If you take the unlock power from the drivers side motor and disconnect the power to the pass side motor then hook up the drivers side unlock power to the pass side motor it works.
    Splice into the blue with black/stripe wire on the drivers side motor and run it over to the pass side then cut the blue with black/stripe wire to the pass motor and attach the one from the drivers side to the motor side of the one you cut on the pass side and there you go.
  13. Mar 10, 2008 at 10:41 PM
    #193
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It's late and I'm a little off. What are y'all trying to do? If you're trying to open all the doors with 1 remote press, then why couldn't you grab the power from the driver door solenoid and pass it on over to the driver's side unlock switch. That would keep the wire runs to a minimum.
  14. Mar 11, 2008 at 5:03 AM
    #194
    piercedtiger
    Jon
    Southern Tier, NY
    Maybe it's too damn early in the morning and I need more sleep, but I can't figure out wtf you're saying Anthony without pictures..... :laugh:
    Lemme wake up and think about it some more.
  15. Mar 11, 2008 at 3:39 PM
    #195
    jungleman
    North California
    I`m open to suggestions......
    please
    go on.
    where would the driver door solenoid be?
  16. Mar 11, 2008 at 4:04 PM
    #196
    piercedtiger
    Jon
    Southern Tier, NY
    Had to update my pin switch setup. Not only did the bumpers move twice, but the pin switch (which I thought was tight) had be pushed further into the hole. So I tightened it down more before added the spacer, and applying some hot melt glue to the plastic bumper on the hood for more surface are to contact the switch.
    Another picture of the switch with spacer:
  17. Mar 11, 2008 at 6:14 PM
    #197
    jungleman
    North California
    Hmmmmmmmm
    pin switch activated engine compartment light
    awsome
    nice work
    next up! after the Volant ram air scoop that is
    thanks
  18. Mar 11, 2008 at 6:26 PM
    #198
    piercedtiger
    Jon
    Southern Tier, NY
    Hey, I stole the idea from AdrenaliNate! I just didn't want another damn switch on the dash! :D I still have a winch bumper with lights to install and only 1 blank spot left! :laugh:
  19. Mar 11, 2008 at 7:48 PM
    #199
    jungleman
    North California
    I remeber seeing it just never saw it all done with the pin switch
    I`m to the point of dremmeling out more holes in the dash for all the switches
    yeah, someday I`m going to get that reciever mount winch........
  20. Mar 11, 2008 at 9:20 PM
    #200
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Kind of off topic, Okay way off topic...
    But I'd make sure a receiver mounted winch is going to do what you need it to do. I had a frt receiver winch on my 97 Taco, and after a few years, it was all tweaked and bent up. Both the winch mount and the frt receiver mounted to the truck. They aren't designed for much more than 25° off center pulling and especially not while pulling you out of some good mud hole. And the 5 times I really needed it mounted on the rear, 4 of those times it was either I was being stupid and getting stuck by myself or it was so buried in mud mounted to the front, 2 feet under water, that it was not even possible to remount it. Oh well, just my past experiences! :D
