Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Jul 28, 2009 at 4:36 PM
    #581
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I bought my Stalk...stock, wichever one is right. Pick it up tomorrow. Funny thing is , its 108 degrees here... in PORTLAND OREGON!!! Stealership wouldnt give me an off season dicount ROFL.
    (why can't i find that degree circle, thought the keyboards had one??)
  2. Jul 29, 2009 at 9:20 AM
    #582
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Hold down the Alt button and press 0176 on the 10-key number pad (not the overhead nummerals) and release alt button.
    108°
    Thats old school stuff when a mouse didn't exist. Well it did, but a mouse was only a mouse.
    Edit: Did I just date Myself?...
  3. Jul 29, 2009 at 4:02 PM
    #583
    Tacoyota
    08 4wd
    I'm running a laptop w/o the k.pad. I've never cut n pasted either lol . BUT ANYWAY.... dungondidit! I have the wiper mod, works fine zero problems mod related.Thanks Roland for the write up! 107.4 degrees now.
  4. Jul 30, 2009 at 5:32 AM
    #584
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
  5. Jul 30, 2009 at 5:39 AM
    #585
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
  6. Jul 30, 2009 at 5:45 AM
    #586
    ph16drive
    Paul
    Clevelandish
    Well now there's a replacement.
  7. Jul 30, 2009 at 1:20 PM
    #587
    tacojeff
    tacojeff TacoJeff
    jeff
    victoria b.c. canada
    '06 Tacoma Double Cab 6" lift
    6" fabtech lift, 20" wheels, 35" tires, HID fog lights with L.E.D. halos, Alpine DVD/T.V., Blackbird Nav,Backup camera, Bluetooth, chrome Billet antenna, back window anti break-in mod, Compustar paging alarm, Chrome tube side steps, and some other toys!
    hey, just wondering if you know if the seatbelt chime off mod will work on a 2006 Tacoma?
  8. Jul 30, 2009 at 6:03 PM
    #588
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    No, only newer models.
  9. Aug 5, 2009 at 4:27 PM
    #589
    Tacoyota
    08 4wd
    I Did the cruise crontrol mod today, went good except the clutch part.I thought my hands were small enough but they were a little cramped:mad: in there. 2008 reg cab 4wd 4cyl cali made no problems, my hands are my problem lol. Whoever took the leap of faith and started this mod, a Job/mod well done, Thank you!:cool: Who ever mhadden is on toyo nation and piercedtiger here for linking us to the modThanks.
  10. Aug 6, 2009 at 10:39 AM
    #590
    coke_220
    coke_220 Active Member
    Rob
    WA
    SR5 4x4
    Volant intake and ram air scoop, pioneer avc 900tb,8IN sub,aux fuse block, Satoshi Grill, brush guard with 2 lights
    Did u ever find out about the blue LED mod??
    Blue Dash
    White Dash
    IMG_0912_5043d10be78d9dddff6f238e0a25a1310a779d07.jpg[/quote]
  11. Aug 7, 2009 at 6:18 AM
    #591
    piercedtiger
    Jon
    Southern Tier, NY
  12. Aug 9, 2009 at 9:13 PM
    #592
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Just did this to my 09....Worked like a charm!!! Thanks bud!
  13. Aug 9, 2009 at 9:39 PM
    #593
    payrow
    Los Santos
    '18 DCSB Sport
    I got a bit confused and probably did the same thing you did at first. I made a slight change to the original post that may help you...
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob (with the display on ODO) and do a long 12 second count.
    4) After about 12 seconds and with the trip reset knob still depressed - Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time release the trip reset knob and then press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
  14. Aug 17, 2009 at 9:30 PM
    #594
    Darkknight22
    Darkknight22 Well-Known Member
    Steven
    Sumter,SC
    08 tacoma 4x4 trd black
    15% window tint, 3 in leveling kit, 285/75/16 BFG KM2's
    thanks so much for this man, i would have never guessed there was a code to turn that aggravating thing off my gf hates it lol thanks again
  15. Aug 18, 2009 at 2:24 PM
    #595
    coke_220
    Rob
    WA
    SR5 4x4
    well i thought i would post my placement of my aux fuse block i made my mount out of alum i had laying around the block i used has 12 slots for what i will be doing over time if u don't have alum then steel or wood or even duck tape could work lol hope some one finds a use like this for there truck hope ya like
  16. Aug 19, 2009 at 7:51 AM
    #596
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Does this also take care of the passenger seat seatbelt warning chime?
    TIA
  17. Aug 19, 2009 at 7:57 AM
    #597
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    nice! I was just about to do the same thing. I picked up some circuit breakers for an in cab inverter, the fuse block, and a stereo and I plan on mounting those to the same plate as the fuse block.
  18. Aug 19, 2009 at 8:09 AM
    #598
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    I did the buzz off on my '09, my observations:
    It chimes once when you start the vehicle. It never chimes any more for either seat while the vehicle is running.
    This only effects the chime. The seat belt warning symbols still flash.
    Sometimes I put an item of weight on the passenger seat and the symbol flashes away, of course.
  19. Aug 19, 2009 at 8:56 AM
    #599
    flatlander
    Many Thanks
  20. Aug 19, 2009 at 12:05 PM
    #600
    coke_220
    Rob
    WA
    SR5 4x4
    yea man no problem it ran me about 50 bucks or so to do thing plus i had aces to the weder ant work so it came out nice how your instal gose wll
