Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Feb 1, 2011 at 10:59 AM
    #881
    BLACKnBLUE
    BLACKnBLUE Well-Known Member
    Iain
    Ellensburg, WA (Kittitas County)
    07 TRD SR5 with ARB Front Bumper
    ARB front winch bar, 3" lift, blacked out badges, blacked out headlights, Custom Steel Rear Bumper Mod, and Leer 100XQ
    My truck must have come with the noise already turned off cuz I have never had it go off on me, I just get the blinking red light telling me I'm "not safe." My parents have a 2010 Silverado and it's annoying as hell with all it's alarms going off for any and all reasons! I guess I just got lucky :cool:
  2. Feb 3, 2011 at 7:46 AM
    #882
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
  3. Feb 3, 2011 at 8:00 AM
    #883
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    The 'HEY RETARD PUT YOUR SEATBELT ON' beep was added in the 2008s
  4. Feb 5, 2011 at 9:32 AM
    #884
    ADVBedouin
    ADVBedouin Well-Known Member
    Central CA Coast
    '10 Preunner Acc Cab 2.7L 5spd
    2" CCM front spacers, secondary airfilter gone, OEM 16" alloys, Trailer hitch gone, Seat belt buzzer gone, Ignition key buzzer gone, shortened fact. antenna.
    I'm SO STOKED to have disabled my door-open chime when the key is in the acc position. Thanks to JPMorrisvb for the awesome link. It's so easy & took maybe 15 minutes, most of that was just being careful not to damage anything;
    http://www.toyotanation.com/forum/showpost.php?p=2643003&postcount=27
    The only thing I'd recommend is that you don't have to move the top half of the steering column cover. You don't even need to fully remove the lower half, just pull it down a few inches & it's easy to pop out the sensor/plug. There's tiny tab at the front of the plug (facing toward front of truck) that only needs a light squeeze & it pops right out. Voila, no more annoying door chime/buzzer with the key in the ACC position.
    This really should be a Cheap Mod/DIY sticky on here.
  5. Feb 7, 2011 at 11:33 AM
    #885
    wdinfla
    wdinfla Can't Fix Stupid
    Walt
    Melbourne, Florida
    2011 4 cyl, 5 speed, Pyrite Mica
    Front mud flaps, Seat covers by GT Covers, Hurst shifter T-handle, debadged, 15" antenna, In channel Vent-Visors, Undercover SE tonneau cover, Weathertech digital fit floor mats, Redline Tuning hood struts, Bed mat, Intermittent wiper switch, Leather armrests, Drag DR-33 Gunmetal Grey 15x7 +40 offset, BFG Radial T/A's 255/60R15, BHLM, OEM style Fog lights on anytime,
    This worked on my 2011. Just did it today. Thanks
  6. Feb 7, 2011 at 1:56 PM
    #886
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    I like that Key in the igintion sound. Keep me from locking keys in.
  7. Feb 20, 2011 at 7:45 PM
    #887
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    Awesome trick, just turned my annoying chime off. Thanks for the tip!
  8. Feb 22, 2011 at 9:51 AM
    #888
    JTN757
    JTN757 Active Member
    Jay
    Texas
    Silver PreRunner TRD Sport
    Roll N Lock Cover, Bed Cargo Manager
    I did this yesterday, and consider it to be a qualified success. Successful in that once the initial seat belt fastening chime times out (or upon buckling of the seat belt), it doesn't chime again. In other words, you can then unbuckle the seat belt and it won't chime...only the idiot light will be illuminated on the instrument cluster. But if one turns the key on, without buckling up, it will still chime.
  9. Mar 4, 2011 at 8:48 AM
    #889
    BBJ285
    BBJ285 Well-Known Member
    Scurry, TX
    03 Pre-Runner
    SnugTop cap, "SuperSpring" helperspring, flowmaster muff,K&N CAI, CB, small amp & 2 6x9s in the bed on a toggles switch for nights at the drive-in...
    I used a Scion LED enhancement kit. 2 Amber LEDs in the cup holders, the illumination bar under the front seats to light up rear floor, and just the led heads velcroed behind center dash pointed at each front floor.
  10. Mar 11, 2011 at 8:51 AM
    #890
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I made this simple console divider out of some scrap 1/4" plywood I had laying around. Just cut two pieces of plywood to fit the dimensions of the console, cut a slot halfway through each (1/4" wide) and stick them together. I made the slot narrow enough that it required a rubber mallet to get it all the way down. I shaped one side of the shorter board to allow easier access to the small cubby area near the passenger.
    The long piece is 10.5" at the top and 10" at the bottom. It's about 6" tall.
    Before:
    After:
  11. Mar 13, 2011 at 4:53 PM
    #891
    MillerMan06
    MillerMan06 Well-Known Member
    Adam
    Raleigh
    06 PreRunner SR5
    K&N Cold Air Intake,Running boards,bed cover,windows tinted, MagLite seat mount (A big Thankyou to piercedtiger for that one got it off cheap/free mods) extra 4 outlets on the 12V plug 3 12V plug in's and a USB all one box with toggles,48LED dome light (blue), Tail gate theft mod,Exhaust flowmaster super 44 with tips!!!!
    Hey just did that to my taco!!! im a new owner of an 06 SR5 prerunner double cab and i found that yes the factory light mount behind the back seat is nice but makes a little nosie and not that handy, the maglite seat mount is MUCH BETTER!!!!!!!!!
  12. Mar 14, 2011 at 4:09 PM
    #892
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    anyone know how to turn off the seatbelt chime on a 2011?
    thanks
  13. Mar 14, 2011 at 4:14 PM
    #893
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Same instructions.
  14. Mar 14, 2011 at 5:19 PM
    #894
    dan0
    swamplands of sc
    hmm, didn't work for me
    I'll try again once the little round holes on my fingers fill back in.
  15. Mar 15, 2011 at 6:16 AM
    #895
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My 09 was also a bit wierd on this setting. If I had the truck locked and went out and hit the keyless entry unlock button to get in, then did the instructions above, it would not work.
    After jacking with it a few times, I went out one day when the truck was in the garage and before it was started up. I don't lock my truck in my garage, so no keyless unlock. Went through the instructions as above, worked!
    I've replicated this little idiosyncrosy on my truck a couple of times. For some reason this key code will not work right after a keyless entry unlock is done.
  16. Mar 19, 2011 at 2:54 AM
    #896
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I found this link trying to find variable wiper speeds for 2011 tacoma. I am really annoyed for how much you pay that it wasn't standard. If I missed it in a previous post I am sorry but do I just order the 05-08 stalk? or is there a new one out and has the guide changed?
  17. Mar 19, 2011 at 3:26 AM
    #897
    deerdevil
    deerdevil Member
    Jeremiah
    South Texas
    ARB Replacement Front Bumper, leather interior, painted front emblem black,
    nice thread
  18. Mar 19, 2011 at 6:17 AM
    #898
    dan0
    swamplands of sc
    I tried this so many ways I'll have little round marks on my fingers for a few years. took it to the dealer they turned it off in 5 mins.
    much easier on the ears now
  19. Mar 20, 2011 at 10:20 AM
    #899
    MillerMan06
    Adam
    Raleigh
    06 PreRunner SR5
    I did it on my 06 prerunner and i love where it is not from the factory mount behind the back seat of the double cab.... i used the screws that came with the kit and so far works well!!! great idea!!!!!!!!!
  20. Mar 20, 2011 at 2:24 PM
    #900
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    The "old" 05-08 intermittent wiper stalk part# 84652-04141 works on the 09 truck.
    Will this work on the 2011?
