Cheap Mod: DIY AUX Input in a 2005-2008 Factory Head Unit
Discussion in 'Audio & Video' started by fbconvert, Jun 9, 2011.
  1. Jun 26, 2012 at 8:49 AM
    #221
    fbconvert
    fbconvert [OP] Well-Known Member
    Brian
    Portland, OR
    2005 Tacoma Double Cab TRD Sport
    I was really close to getting it figured out. but then way too many other things came up. I finally put it down after I completed my 2009 JBL Bluetooth upgrade (Link). I recently just moved to Portland but now things are finally starting to settle. I might be interested in trying to figure it out again. My 05' head unit is still just sitting in a box already disassembled. I could use some help on understanding that data sheet though. I haven't really looked at it. Unfortunately, the write up I found way back in the day seems to be a broken link now. It should be pretty simple still. Just determine what the Right and Left hand input channels are on the audio chip and solder your wire to them. Your post kind of got me thinking about this again so who knows.
  2. Jun 26, 2012 at 3:13 PM
    #222
    fbconvert
    Brian
    Portland, OR
    Check out the diagram from the data sheet that pscrev20 posted.
    The problem is the Radio Input could be an of those input channels. You might be able to trace it to the radio transformer but I am pretty sure it will almost require a trial and error approach. Unless anyone else has another idea. Since I have a spare head unit I wouldn't mind attempting this I just haven't had the time.
  3. Jun 27, 2012 at 11:46 AM
    #223
    pscrev20
    pscrev20 Member
    Philip
    Shenandoah Valley of VA
    05 Taco Double Cab
    AUX jack in stock radio, overtakes FM.
    I've figured it out. I'll post something as soon as I get it written up and pictures in order.:D
  4. Jun 27, 2012 at 4:32 PM
    #224
    fbconvert
    Brian
    Portland, OR
    Sweet I can't wait to see it!
  5. Jun 27, 2012 at 7:17 PM
    #225
    brandonn
    brandonn pretend this is a clever saying
    Brandon
    Houston, TX
    Just did this mod, works perfectly but I think I screwed up the FM radio. It's all static now, not sure what happened. Any ideas?
  6. Jun 28, 2012 at 5:12 AM
    #226
    pscrev20
    pscrev20 Member
    Philip
    05 Taco Double Cab
    Sounds like you may have forgotten to plug your antenna back in. Happened to me first time I removed my Head unit. Double check that first.
  7. Jun 28, 2012 at 6:14 AM
    #227
    brandonn
    Brandon
    Houston, TX
    Where's the antenna located? I don't remember seeing an antenna..
  8. Jun 28, 2012 at 8:58 AM
    #228
    pscrev20
    pscrev20 Member
    Philip
    05 Taco Double Cab
    If you check on the back of you radio, there should be a round plug on the left side. That's for the FM antenna. The cable is probably laying there in the dash, it's not attached to the wiring harness.
  9. Jun 29, 2012 at 9:10 PM
    #229
    Numbnutz
    Numbnutz Well-Known Member
    Oregon
    Slow work in progress
    Just finished this mod. I have to say hands down it's the best $4 I've ever spent. This was my first time soldering also, after a YouTube video I was ready to go. Thanks to the OP for this write up.
  10. Jun 29, 2012 at 9:13 PM
    #230
    brandonn
    Brandon
    Houston, TX
    Wow, that was it. Coulda sworn I plugged it in. Thanks! haha
  11. Jul 1, 2012 at 6:53 AM
    #231
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    FM1 or 2? I'm waiting to do this mod until someone figures the FM override method.
  12. Jul 2, 2012 at 9:31 AM
    #232
    cbs5090
    cbs5090 New Member
    Lafayette, LA
    06 PreRunner SR5
    DIY Aux Input
    I did this mod 2 days ago and it was great except that I also have engine feedback and static when my charger is plugged it. Unplug the charger and it is crystal clear. Has anyone figured out a way around that? I might not be keeping a tab on this thread so if someone does, please shoot me a message so that it will hit my e-mail.
    Thanks to the OP for figuring this out. I had to buy the soldering iron but the total project was $9. Crazy cheap compared to $200-$300 options.
    Edit: Dug around through this thread and may have found the problem- http://www.droidxforums.com/forum/droid-x2-general-discussion/36215-feedback-coming-phone-when-plugged-into-my-aux-jack-my-car-when-charging-3.html
    It seems this item WILL stop the whining noise while I am charging. It was only $11 through Amazon prime and couldn't hurt to have in the future:
    http://www.amazon.com/PAC-Ground-Isolator-3-5-Applications/dp/B001EAQTRI/ref=cm_cr_pr_product_top
  13. Jul 2, 2012 at 1:51 PM
    #233
    pscrev20
    pscrev20 Member
    Philip
    05 Taco Double Cab
  14. Jul 3, 2012 at 6:26 AM
    #234
    pscrev20
    pscrev20 Member
    Philip
    05 Taco Double Cab
    Ok, Inputs are as follows for those who want to know:
    AINRP1 (+), AINRPN1 (-), AINLP1 (+) and AINLPN1 (-) are for external 6 disc changer (I assume as they trace to the external connector and are balanced inputs).
    AINRP4 and AINLP4 are not used.
    AINRP3 and AINLP3 are for the built in CD deck.
    AINRP2 and AINLP2 are for the FM Tuner.
    This is for a Stock 6Disc changer in an 05 radio.
  15. Jul 3, 2012 at 8:15 AM
    #235
    fbconvert
    Brian
    Portland, OR
    Nice Work. I also updated my original post to include a link to your writeup. I am thinking I will have to give it a try when I have some free time.
  16. Jul 10, 2012 at 6:15 PM
    #236
    Jordanlawrence
    Jordanlawrence Well-Known Member
    Jordan
    turlock
    05 Tacoma 4x4 Acess Cab TRD off road white
    no way! how do you like it? I want to install it in an 05 tacoma.. how hard was installation and also how does it function
  17. Jul 18, 2012 at 2:23 PM
    #237
    bhai81
    bhai81 Member
    Lincoln, NE
    06 Double Cab Long bed Sport
    Cheap cheap cheap AUX input
    if only someone could find a way to harness the power of the cd changer port in the back..... :)
  18. Jul 18, 2012 at 2:26 PM
    #238
    TheGrinch
    TheGrinch Cheese Head.
    Sean
    RP, CA
    07 TRD DCSB OffRoad on 33's
    6" procomp lift
    subbing right Fucking NOW
  19. Jul 22, 2012 at 6:42 PM
    #239
    acdronin
    acdronin Well-Known Member
    Whoo Hoo! It worked (and I didn't have any screws left over) Thanks!
  20. Jul 23, 2012 at 9:49 AM
    #240
    pscrev20
    pscrev20 Member
    Philip
    05 Taco Double Cab
    That is what the aftermarket units like the USA Spec and GROM devices do. Hard part with that one is tricking the radio into believing that the external CD changer is there. That would take a microchip and some programming I'm sure.
