Cheap Mod: Secure Locking Gas Cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaCraZ, Apr 5, 2008.
  1. Apr 5, 2008 at 6:39 PM
    YotaCraZ
    YotaCraZ [OP] Well-Known Member
    Eastern Virginia
    08 4x4 Super White TRD Sport
    TRD Catback, AFE Pro Dry S Drop in, RS3200 Plus, Westin Step/Bull Bars, Access LE Tonneau, Redline Hood Struts, tint, AMI stubby antenna, AVS Vent Shades, Sylvannia Silverstar headlight/foglight bulbs, TRD Seat Covers, Bed Mat, Pop-N-Lock, Highland mats
    Like many, I was disappointed that Toyota did not provide a locking fuel door so... I went in search of a locking gas cap. Using the invaluable info that this board has provided I was able to find and purchase what I needed. Only one problem... I was used to hanging my old gas cap by the lanyard on the fuel door lock jaws so it didn't bang against the side of the truck. As they say...necessity is the mother of invention...hence the info below. I hope this helps someone else.
    Requires:
    STANT Locking Gas Cap: 10509, fits 2008 - no problems
    Approx 18" of 30lb test monofilament fishing line
    (2) Stainless Steel Swivels, Size 3
    (5) Double Sleeves, 1.3mm,
    Dremel Tool (or equivalent) with a 5/64" drill bit
    Wire cutters to cut fishing line; pliers to crimp sleeves
    1) Drill a hole straight through the locking gas cap handle - approx 3/4" back from the lock and a quarter inch below the top of the handle - handle is hollow
    2) Cut off about 4" of fishing line. Feed line through the gas cap handle - slide on a dbl sleeve and swivel. Make a loop a tad smaller than a US quarter and crimp the sleeve. Trim off excess fishing line.
    3) Repeat step 2 on fuel tank door where the old gas cap lanyard attached
    The following steps require some experimentation with length to ensure the gas cap does not come in contact with the fuel door
    4) Cut off about 12" of fishing line.
    a) Slide on a dbl sleeve
    b) Loop fishing line through the swivel on the gas cap, crimp sleeve and trim excess fishing line
    5) Slide a dbl sleeve on the unattached end of the 12" piece of fishing line
    a) Make a loop about the size of a US half dollar approx. 1-1/2" from the gas cap by feeding the fishing line the opposite direction through the dbl sleeve - DO NOT crimp, yet.
    b) While gently holding pressure on the sleeve/fishing line, hang the loop around the fuel door lock jaws to determine approxamitely where the gas cap will hang. GOAL: Gas cap should hang just below the fuel door. See photo
    c) Adjust the distance and size of the loop as necessary
    d) Crimp the sleeve
    6) Hang the gas cap on the fuel door lock jaws
    a) Slide another dbl sleeve on the unattached end of the 12" piece of fishing line
    b) Loop the line through the swivel attached to the fuel door
    c) Tighten up the slack in the line between the gas cap loop and the fuel door loop
    d) Crimp the sleeve and trim off excess line
    Done!
    In one of the attached photos you'll see the supplies I used. At the bottom you'll notice a piece of shrink tubing. I used it to cover the sleeves; if I ever have to do this again I'll probably use colored tape instead. It was a pain trying to shrink the tubing without melting the fishing line.
  2. Apr 5, 2008 at 6:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    Great Idea, thats one of the things I thought our trucks were missing.
  3. Apr 5, 2008 at 6:48 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Great writeup...added it to the 2nd gen mod list. Maybe piercedtiger will add it to his huge cheap mod thread as well.
  4. Apr 5, 2008 at 7:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    awesome mod!! definitely should be added to the cheap mods page!!
  5. Apr 5, 2008 at 7:22 PM
    YotaCraZ
    Eastern Virginia
    Great thing about this one...I had most of this stuff laying around the garage. Can't get much cheaper than that.
  6. Apr 11, 2008 at 3:01 PM
    yak
    yak member
    so cal
    08 indigo dc prerunner sr5
    roll n lock bed cover - tinted window - debadge - blue interior light
    Thanks for the idea yota. I did a simpler one.
    I just used leftover string for debadging. Drill a hole on the cap, then loose the screw and just loop the string around it and tighten it back.
  7. Apr 11, 2008 at 6:34 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Added to the TOC! :D
  8. Apr 11, 2008 at 7:07 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Have any of you guys used the cable that was on the original gas cap? thats what i did works fine for me.
  9. May 4, 2008 at 5:11 AM
    danusa
    danusa Well-Known Member
    Gas answer: .45 A.C.P.
    fökai671 and Toyota_Eddy like this.
  10. May 4, 2008 at 5:41 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    Thats definately a great idea! Thanks!
  11. May 4, 2008 at 5:42 AM
    danusa
    Make your move.
  12. May 4, 2008 at 5:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How's that gas cap holding up? I had a similar looking one for my Dodge. I hated it. It was cheap and felt cheap. If I could find a good metal one - I'd spend the money on it for sure.
    Nice write-up. I just hate those plastic locking gas caps.
  13. May 4, 2008 at 6:10 AM
    danusa
    Same question.
  14. May 4, 2008 at 11:05 AM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    I have the same gas cap and yes, it is cheap. Kragen says thats the only one they have that will fit my Taco.
  15. Aug 31, 2009 at 7:44 AM
    onecarnut
    onecarnut New Member
    Arkansas
    08 quad cab sr5
    I am new to the forum and am catching up on some interesting post.
    I just bought a locking gas cap for my 08 prerunner V6 SR5. NAPA part number 703-1647 works just fine; list for $26.30 and I bought wholesale for $13.88.
  16. Aug 31, 2009 at 7:52 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    :eek: is he back from the dead?!
  17. Sep 10, 2010 at 10:42 PM
    K Williams
    K Williams Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Does anyone know what's the Stant model # for the locking gas cap that fits the 2011 Tacoma? Thanks.
  18. Sep 12, 2010 at 7:31 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  19. Sep 13, 2010 at 3:03 PM
    K Williams
    Long Island, NY
    That and a locking tailgate...and a locking glove box. :confused:
  20. Sep 13, 2010 at 3:04 PM
    K Williams
    Long Island, NY
