Cheap Mod: Secure Locking Gas Cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaCraZ, Apr 5, 2008.
  1. Apr 2, 2012 at 11:09 AM
    #41
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The light eventually went out when the original cap was put back on. That was on a couple of Nissans. I would expect your Toyota to do the same.
  2. Apr 2, 2012 at 6:50 PM
    #42
    JGUT
    JGUT Well-Known Member
    Yuma, AZ
    08 PreRunner Off Road Package
    2 Kicker 8" SL5, Kicker 750.1 mono amp, Kicker 200.4 amp, Kicker 6x9's front, Kicker 6.5's Rear, Pioneer AVH-P3200BT, Rear view camera
    I went to my uncle's house and he hooked up his diagnostic tool. The trouble code was P000?? I didn't get a chance to write it down but it said "Large vapor leak" or something to that effect. So he cleared the code and we'll see if it comes back. I'm returning the gas cap tomorrow since I find it to be the culprit.
  3. Apr 2, 2012 at 6:53 PM
    #43
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... Sub'd ... :popcorn: ... I like a protected fuel filler.
  4. Nov 14, 2013 at 12:10 PM
    #44
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    Good write up, but apparently there are some issues with locking gas cap security.
    It seems the proper fix would be to add a locking fuel door. Which could always be defeated by a lever of some sort if someone really wanted to get at the fuel system.
    But I am surprised no one has come up with a fix for adding a locking fuel door. So,..someone hurry up and produce a solution to this anomaly that utilizes the ignition key.
    That's an order!!!
    I married my tacoma likes this.
  5. Nov 14, 2013 at 1:17 PM
    #45
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    X2
    lol
  6. Jan 17, 2014 at 3:58 PM
    #46
    eAreEyeSee
    eAreEyeSee Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
  7. Jan 18, 2014 at 5:30 AM
    #47
    coolreed
    Reed
    OKC
    Outstanding!
  8. Jan 18, 2014 at 6:01 AM
    #48
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    Is that an electro magnet?
  9. Jan 18, 2014 at 9:59 AM
    #49
    eAreEyeSee
    Eric
    Aurora CO
    No. Its just a standard magnet to keep the door in the closed position while its unlocked. The hinge on the door has a natural tendency to rest about 1/16" to 1/8" away from the body so I put the magnet on to make sure the plunger and latch will line up when armed.
    I put it on the marketplace to see if there is any interest for something like this. If there is then I will make more.
    http://www.tacomaworld.com/forum/2nd-gen-tacoma-marketplace/311500-locking-gas-door.html
  10. Jan 18, 2014 at 12:30 PM
    #50
    InSight Retrofits
    InSight Retrofits Closed
    Stant caps are junk. A customer lost a key and came in to buy a new one. I went outside with a pair of channel locks twisted it loose, the exterior of the cap broke off, I then removed the inner valve and the piece that goes into the filler neck and put her new cap on all within 30 seconds.
    Locking door is a much better idea BUT remember a lock only keeps honest people out.
    One of our frequent commercial customers was getting his diesel fuel sucked out of his tow trucks at night. They are the big tanks right by the doors with the big flat round cap. He went out, placed some razor blades under the cap and tightened it down so the blades stuck out. Went in the next morning to find blood stains going from the cap and out the driveway.
    Hasn't had any diesel fuel siphoned since :D
    mose1117 and 06Tacooo like this.
  11. Jun 19, 2014 at 6:11 PM
    #51
    993guy
    993guy Member
    Bill
    Near Jacksonville, FL
  12. Jun 20, 2014 at 8:05 AM
    #52
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Tried ordering the Stant 10504 or 10509 from Amazon, but said neither fit my 2014 Tacoma. Amazon recommended the Gates 31780 instead, which I purchased. Installed ok and seems to work and lock fine, and came with 2 keys. No Check Engine light after 200 miles of use. I like the clutch action on the Gates when screwing it on.
  13. Oct 12, 2014 at 1:33 PM
    #53
    mikefromtacoma
    mikefromtacoma New Member
    puget sound
    2011 dcsb trd off road
    TRD off road,arb front bumper
    i need a locking chastity belt!!!
  14. Sep 2, 2018 at 11:08 PM
    #54
    67siia
    67siia Well-Known Member
    J
    32164
    2009 4WD DCLB aka Chupacabra
    Thank you. My second official mod. Cheers
  15. Mar 31, 2019 at 6:07 PM
    #55
    Globaldriver63
    Globaldriver63 Well-Known Member
    David
    Upstate SC
    Great info, Thanx
  16. Aug 21, 2019 at 11:05 PM
    #56
    JarheadGunny0311
    JarheadGunny0311 Member
    2015 Tacoma, TRD Off Road, Double Cab, Barcelona Red Metallic
    I have already accomplished a number of modifications to my 2015 Taco. I appreciate your posting this information, I am going to take advantage of this instruction and secure my fuel port ASAP. Thanks much!!!
  17. Aug 18, 2020 at 1:08 PM
    #57
    SpyderMan
    SpyderMan Well-Known Member
    Morgan Hill, CA
    05 TRD
    Great idea!
  18. Mar 25, 2022 at 3:55 PM
    #58
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I put a STANT locking cap, model #‎10504, on my 2014 AC V6 MT about 2 months ago.
    I get sporadic "check engine / TRAC Off" lights on dash, always the same two codes: P0441 and P0454, which are gross EVAP leak codes. Usually the codes come a couple of days after doing a full-tank fuel up.
    If I take special care to be sure the cap is on as tight as possible it seems like the codes come less often. I suspect the inner ratchet mechanism that is supposed to prevent overtightening may be marginal -- sometimes it torques enough for a tight fit, other times it doesn't get tight enough & throws codes.
    Charlie Bravo likes this.
  19. Mar 25, 2022 at 4:42 PM
    #59
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    if anyone is curious a honda locking gas cap works too
