cheap performence upgrades
Discussion in '1st Gen. Tacomas (1995-2004)' started by jamtoz, Apr 15, 2012.
  1. Apr 15, 2012 at 10:42 AM
    jamtoz
    jamtoz [OP] frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    i was wonderring if i should go with a full CAI or just a performence filter?
    i know it dosent give much gain if nothing at all but i just love how it sounds! and i was looking for something like a magnaflow muffler not the whole system, for now anyways.
    let me know what you think and what youve done to yours to improve your performence
  2. Apr 15, 2012 at 2:41 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    Search Deckplate Mod:D
  3. Apr 15, 2012 at 3:25 PM
    Ronaldo156
    Ronaldo156 Active Member
    Ron
    Washington
    Red LED interior swap, Deck Plate Mod, Magnaflow 18"
    Deckplate mod with a quality filter (30$), and yea a muffler of your choice for sound. use the search to find it, but there's an exhuast clip thread that can give you some good ideas!
    I think an airaid intake tube might also give a slight throttle response benefiet too, but that's about 90 bucks for a slight gain.
  4. Apr 15, 2012 at 3:34 PM
    TheMike515
    TheMike515 Well-Known Member
    Phoenix AZ
    OME Coilovers and Dakar Leafs
  5. Apr 15, 2012 at 4:38 PM
    jamtoz
    jamtoz [OP] frog
    James
    Quebec
    thanks ive seen it on here before but never looked it up :eek: deck plate mod did not sound like a performance upgrade lol
  6. Apr 16, 2012 at 12:46 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    There really aren't any "performance upgrades" for tacomas. Anything less than a supercharger or turbo will have a very very small effect on engine performance. You're better off focusing your attention on other areas.
  7. Apr 16, 2012 at 12:48 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    THIS ^
  8. Apr 16, 2012 at 6:40 AM
    TheMike515
    Phoenix AZ
    I don't know for certain but the article quotes this
    'At freeway speeds no fan is necessary because more air is being forced through the radiator than a standard engine-driven fan can pull. Therefore, if you remove the fan you pick up throttle response, a little horsepower, and fuel economy.'
    Seems to my like removing any rotating mass from the belt system would give the engine an opportunity for better throttle response and less wasted power...
  9. Apr 16, 2012 at 6:42 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    You are correct.
  10. Apr 16, 2012 at 6:56 AM
    JDMcQ
    The mass of a fan takes several horsepower to turn. Some have said up to 25hp. No way the load on alternator is that much. The clutch may open, but it still drags.
  11. Apr 16, 2012 at 7:06 AM
    JDMcQ
    I haven't done scientific test, obviously, but it is generally agreed that an electric fan is more efficient. partially due to the ability of it to be turned completely off. There is also the fact that the rotating mass of an electric fan is less that that of a mechanical fan.
    Mechanical fans can usually move more air and are certainly more reliable than electrics. The increased in air movement is the main reason that they are still used in truck applications due to their (sometimes) higher engine loads. Cars, on the other hand, are not as stressed and the manufacturers have almost all gone to electrics for the increased engine efficiency.
  12. Apr 16, 2012 at 10:05 AM
    shampoop
    southwest WA
    Unless you're swapping in a longer engine, stick with the factory fan. There's a reason why big HP supra guys always try to keep the factory mechanical fan if possible, because it works the best! It's a truck, the mechanical fan is one of the ingredients to it's awesomeness.
    Plus even if a electric fan did free up a few ponies, they would be VERY expensive ponies. A very poor $/hp ratio.
