Cheap RTT for those on a budget.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WNYTACO, Mar 1, 2017.
  1. Jun 11, 2018 at 8:48 PM
    #281
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
  2. Jul 2, 2018 at 11:55 AM
    #282
    Fly Guy
    Fly Guy Well-Known Member
    Eastern Shore of MD ... for now
    '17 DBL Cab TRD Sport 4x4 and '03 PreRunner DBL Cab
    More than some ... Less than others
    So, gave the set up a three day test run as my son and I are planning a two week trip to NM and CO the second half of July. The conduit center supports did their job fairly well but the center support bar was always off to one side or the other by day break. Not sure I can get a third bar in time to lock it in place, as they were custom made from a semi-local vendor. Will update with a fix, when I find one. Other than that ... worked well, decent night's sleep ... at 90 degrees and 80% humidity.
    shakerhood, Batman! and DrFunker like this.
  3. Jul 9, 2018 at 7:28 AM
    #283
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Did you just straight up use 4 u-bolts and it bolted on and holds steady? Been seeing people having legs support it and am curious if the tent will fall through in the middle or what the deal is with that.
  4. Jul 9, 2018 at 11:52 AM
    #284
    DrFunker
    DrFunker Well-Known Member
    There is a pole that goes down the middle of the tent under the floor.
    On mine, I did attach at the 4 corners and then U bolted the center support.
  5. Jul 9, 2018 at 1:46 PM
    #285
    Rustytaco71
    2018 4Runner
    That’s enough to support the weight of people inside? Just wasn’t sure if the middle of the tent would potentially be comprimied from bolting down on the edges only.
    DrFunker[QUOTED] likes this.
  6. Jul 9, 2018 at 4:22 PM
    #286
    DrFunker
    Very stable, very strong. Have had two adults in it, didn't budge.
  7. Jul 9, 2018 at 4:23 PM
    #287
    DrFunker
    Check out my thread to see more details, if you would like. :)
    starts here
  8. Jul 11, 2018 at 12:55 PM
    #288
    Batman!
    Batman! Well-Known Member
    Juan
    IG: moddedtacomas
    Ques
    Love the set up would you mind sharing more pictures?
  9. Jul 12, 2018 at 5:59 AM
    #289
    Fly Guy
    Thanks! Don't really have any other pictures at this time but we're leaving for CO and NM next Wednesday ... I'll be sure to take a few of the setup along the way!
  10. Jul 12, 2018 at 10:17 AM
    #290
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Is that the SE Diamondback? If so, any concerns with the 400# weight limit? I think LLOD ended up swapping to the HD model when he added the RRT on his setup.
  11. Jan 24, 2019 at 10:46 AM
    #291
    TRDjoe15
    TRDjoe15 Well-Known Member
    Joe
    Naperville, IL
    2015 6-Speed Manual Black TRD Sport
    - 3" Rough country Spacer up front. - Heavy Duty Dakar Leafs & bilstein 5160 for 3” in the rear with u bolt flip for Extra clearance - Tepui 6x4 Awning - BFGoodrich All-Terrain T/A KO2 285/75/r16 - Level 8 Tracker Wheels 16 x 8.5 / -6 Offset - Stock Exhaust, Muffler Cut Out & Replaced With 12" Performance Resonator and Straight Pipe - All-Pro IFS Engine/Transmission Skid Plates - Amazon Switch Panel with relay box - Retrofit Headlights Morimoto Bluetooth Control, HID Projectors - RGB Rock Lights Installed in Wheel well Bluetooth Controlled - EBAY Front Off-Road Bumper, Red Shackles, Amazon 20" Single Row LED Light Bar - Brute Force Fab Rear Off-Road Bumper with rear swing out gate, Red Shackles, Amazon Flush Mount Lights - TacomaBeast Waterport On-Board Water System - BPF Custom Raptor Grille, LED Pods, TRD Grille Emblem - Trail Gear Rock Sliders - Cali Raised 2x20 20W Ditch Lights With Brackets - Black Plasti-Dip Tacoma Badges - TRD Sport Stickers Removed - OEM Toyota Roof Rack With Dakine Aero Rack Pads - "Toyota" Tailgate Sticker Logo - Amazon LED Cup Holder Lights - Amazon Special Interior A/C Knobs - Firestik CB Antenna + Firestik Mount - Uniden Pto520XL CB Radio with PA Speaker Connect - TURBO SII 4" Round Pod Fog Flood Lights - K&N Cold Air Intake - Engine Cap Custom Painted Red - X-Bull Waterproof 13k Lb Synthetic Rope Winch - Yakima Skyrise RTT - 4x4 innovations 8” rise bed bars - Hi-Lift Jack on 4x4 innovations bed rail mounts - Leer hard top Bed Cap for short bed Tacoma
    So a question for the original post. Does the ply wood hold up in the weather - rain/snow/etc? Also Han anyone else had any support solutions besides the wood? I’m thinking about doing this because I’m usually camping by myself so I don’t need to spend the money on a Bigger RTT. Just a bit skeptical on the support part of the tent.
  12. Jan 24, 2019 at 12:09 PM
    #292
    DrFunker
    I think you mean @hightechcoonass
    His modification to the tent. Correct?
  13. Jan 24, 2019 at 12:18 PM
    #293
    TRDjoe15
    Joe
    Naperville, IL
    No @WNYTACO put some wood underneath the the tent cot for support but wouldn’t it be ruined by weather? And I see that other guys have Putin multiple 4x4’s but still have no been 100% satisfied with how the tent holds up. So I was wondering if anyone came up with solutions because I want to pull the trigger on this project lol
  14. Jan 24, 2019 at 12:21 PM
    #294
    TRDjoe15
    Joe
    Naperville, IL
    Actually, you are right. Just looked through the thread and saw that @hightechcoonass had the ply wood. Was wondering how that held up? Still looking for best possible options on supporting the tent and weight in it if anyone has any inputs.
  15. Jan 24, 2019 at 12:47 PM
    #295
    WNYTACO
    WNYTACO [OP] Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    I didn't use plywood but if you did you could get marine grade or coat it with paint to help with moisture. A good waterproof cover over the tent when it is collapsed would help too. It is definitely a fun project!
    DrFunker and TRDjoe15[QUOTED] like this.
  16. Jan 24, 2019 at 12:54 PM
    #296
    TRDjoe15
    Joe
    Naperville, IL
    Like I said I really want to do it. Just stuck on the support aspect. But from what I see everyone pretty much has been fine and is content with the end product.
  17. Jan 24, 2019 at 2:09 PM
    #297
    DrFunker
    Agree. It is a fun project for a fraction of what a true RTT costs. I have very much enjoyed making the one I have and continue to modify.
    TRDjoe15 likes this.
  18. Jan 24, 2019 at 4:49 PM
    #298
    TRDjoe15
    Joe
    Naperville, IL
    I’ll have it done by the summer time when most of my trips take place. Thanks guys!
    DrFunker likes this.
  19. Jan 25, 2019 at 2:37 AM
    #299
    DrFunker
    Great winter project. :thumbsup:
  20. Jan 25, 2019 at 3:04 AM
    #300
    DrFunker
    Looks like this ladder is $53 right now. Down from the usual $70.
