Cheap RTT for those on a budget.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WNYTACO, Mar 1, 2017.
  1. Jul 9, 2021 at 8:45 PM
    #381
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Buddy, I'm pretty sure somebody already called you Genius!
    Bed cover+RTT and easy to remove/install?
    You are Freaking Genius!
    Thanks for the idea and keypoints of design,
    I will develop my set up this way.
    Thanks again!
  2. Jul 12, 2021 at 12:00 PM
    #382
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Am I doing this right lol
    Shveet, DrFunker, NachorTaco and 3 others like this.
  3. Jul 14, 2021 at 9:29 AM
    #383
    Tooshort
    Tooshort Well-Known Member
    Eric
    2022 DCSB TRD-OR 4x4
    Did mine finally. Bought the ladder on eBay for 60.
    Got the tent cot for 100, someone used it one time but was claustrophobic.
    Bought a replacement RTT cover with similar measurements on ebay on eBay and some elastic bungee on Amazon and put those 2 together to have an elastic coverIMG_20210714_115144.jpg
    I attached it to my DIY prinsu rack using 2"x 5" U bolts
    Attached the ladder using smaller u bolts so I could push it similar to real RTT. Will def help with the setup
    I have to change the mount points so that the cover can get underneath a bit as intended with the bungee.
    Also, I have an old memory foam topper that fits perfectly and doesn't add much weight that I have used in this on the ground previously
  4. Jul 15, 2021 at 3:04 AM
    #384
    DrFunker
    DrFunker Well-Known Member
    Nice work. :bowdown:
  5. Jul 17, 2021 at 10:29 AM
    #385
    Tooshort
    Eric
    I'm def having trouble figuring out how to do the cover as the mounts are on the edges, I'm thinking grab wider square U bolts and put 4 points closer to the inside rather than 4 points on the 4 corners
  6. Feb 3, 2022 at 7:49 PM
    #386
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Been trying to figure out an awning solution for the Cabella's cot but been looking into some custom ideas and nothing decent comes to mind.
    but has anyone used one of these "teardrop" hatch style thing covers? there are a few i see online for sub $200. 81E-cbiMMRL._AC_SL1000_.jpg
    not the greatest of Photoshops, but on the Cabella's RTT, it seems to work;
  7. Feb 4, 2022 at 2:28 AM
    #387
    DrFunker
    That could work. Check out the Slumberjack Roadhouse tarp as well. May give you a few more options.
    Shveet likes this.
  8. Feb 4, 2022 at 5:55 AM
    #388
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    yeah the slumberjack could work. I'll look into it and see if its a better option overall. I do have a hammock tarp in a similar cut configuration but only 10feetx10feet which i would just need some extra tent poles for.
    DrFunker[QUOTED] likes this.
  9. Jul 9, 2022 at 12:04 PM
    #389
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Whelp. That's it.
    the tent-cot owes me nothing. not a dime.
    From Ontario
    To the cold of BC
    Up the Dempster
    and to the Arctic ocean
    And back down it
    As much as i rag on it and call it the "Hobortt" (Hobo-RTT) system. it's a sleeping platform and no more. it's a comfortable as a casket but it's a totally solid system to drive across Canada to reach the end of the road. Probably because it was a solo trip. not sure how the experience of it would be had i had a 2nd person
    10/10 Will keep it for the journey back home. Wherever home may be, if not the RTT on the back of the truck.
    chan2565, strider98, DrFunker and 2 others like this.
  10. Jul 9, 2022 at 2:36 PM
    #390
    DrFunker
    :woot:
    Tacosha and Shveet[QUOTED] like this.
  11. Jul 11, 2022 at 2:37 AM
    #391
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
  12. Apr 29, 2024 at 3:52 PM
    #392
    TacoTuesday1
    FL
    anyone know what the latest greatest temporary option is
    if this is smart for moving
    might just have to try one of the ones previously listed years ago
    moving across the country and very possible the truck bed is going to be entirely full of cargo
    but do have a bed rack that could fit an RTT
    hopefully cheaper, temporary, uglier
    than what seems like every one that pops up on Google being a minimum of $1k which sounds insane for...a tent...
    but hey I guess it's cheaper than a GFC and probably harder to set up than one
    am thinking, drive all day
    pull over at night, pop the tent, sleep on top and hope nothing goes wrong
    will need to figure out if there is any sort of product from the store,
    that can be sprinkled onto loaded trailer, scented
    to deter crackheads from stealing cargo while asleep, and where to park to avoid them
    I imagine they're more likely to encounter at populated areas like truck stops and rest areas
    I could find a solo spot to pull over, maybe drape camo net over the truck if it is cheap
    that may hide it but also look scary if seen and get the cops called
    if it can be used in the future again, great
    maybe sell. Or use for ground
    Way I see it, adventure with multiple people > one, and cheaper on gas
    it'd be awesome if going wheeling, one person can sleep in the bed
    another on top of the rack
  13. Apr 29, 2024 at 5:14 PM
    #393
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Just stay in campgrounds? Not sure what your route is but I did something similar a few years ago and just googled it day of and found plenty of camping options. Ground tent it near your truck.
    fellow_expert likes this.
  14. Apr 29, 2024 at 5:16 PM
    #394
    TacoTuesday1
    FL
    Maybe yeah. Good option and cheap. Might have shower. Find one each night to stop. Hopefully less crackheads.
    quieter nights less semi trucks passing by and risk of getting crashed into asleep or cops checking out vehicle for some reason
    nDub[QUOTED] likes this.
  15. Apr 29, 2024 at 5:21 PM
    #395
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    Akguy likes this.
  16. Apr 29, 2024 at 8:32 PM
    #396
    fellow_expert
    fellow_expert Well-Known Member
    2019 Midnight Black SR5 4x4
    Look into KOA Campgrounds. They're all over the US, and I'm sure you could probably find a few along your route. They're reasonably priced usually, have showers, electric, etc.
    nDub likes this.
