Cheap TPMS Light How-To/DIY
Discussion in 'Wheels & Tires' started by EquinsuOcha, Apr 1, 2008.
  1. Apr 1, 2008 at 4:09 PM
    EquinsuOcha
    EquinsuOcha [OP] Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    If you are an '07 Tacoma owner, and have switched your stock wheels for a new set and you find that little orange dummy light annoying, this write up is for you.
    I searched long and hard for a thread that would tell me how to disable the TPMS light, but the consensus is that the ground-out method won't work on '07s. And to be honest, I wasn't too crazy about cutting wires anyway. (Here's the thread in case you'd like to try.)
    I read that someone (could never find out who) just simply stuck the old sensors into a hand truck/wheel barrow wheel and stuck it in with the spare...but no write up.
    So here it is!
    Please note: This is simply what I did, and have found to work. I take no responsibility for any malfunctions and/or damages to your person or vehicle.
    The wheel and tire I bought from Wal-Mart for $40 and is 15" in overall diameter. There are less expensive, smaller tires out there, but you run the risk of not being able to feed the spare-hanger through the center.
    First, deflate the tire completely and break the bead on one side of the wheel.
    The space was kind of tight, so I stuck the nipple end in first:
    Then, slip one side of the sensor down into the inside of the tire (The other side would not slide in easily, and I feared too much force would damage the sensor):
    I found that the next steps were easier with the wheel standing. Everything should look like the picture below at this point:
    Now take a large flat-head screwdriver and pull downward on it, so you can give yourself a bit more room to finish sliding the sensor in:
    Use your thumb to slide in the other side of the sensor:
    Repeat 3 additional times until all of your sensors are inside the hand truck/wheel barrow tire, then inflate to the specifications on the sidewall of your specific tire. Mine happened to be 60psi, but I only put in about 45psi.
    This is how the tire set in with my spare:
    Finally, raise your spare back to the underside of the bed making sure it is snug enough to avoid any annoying noises and possible damage to your truck. You should now be able to turn on your truck, and there should be no illuminated dummy light.
    I hope this helps you guys who couldn't get the ground-out wire fix to work.
  2. Apr 1, 2008 at 4:12 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Good idea. Thanks.
  3. Apr 1, 2008 at 4:17 PM
    rick
    rick `
    nice diy. i wonder if you can put the sensors inside the spare instead.
  4. Apr 1, 2008 at 4:19 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I would be worried about them moving around when I need to use the spare.
  5. Apr 1, 2008 at 4:39 PM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    Yeah, that's why I decided against putting them in the spare.
  6. Apr 1, 2008 at 7:38 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    When you reset the TPMS it considers the pressure reading the sensors are transmitting at that time as correct. Couldn't you just put them in a bag and reset the system or would that be too easy.... Then they could be stowed anywhere in the truck.
  7. Apr 1, 2008 at 7:40 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    What is the lowest functional pressure of the gauges. If it is 0 psig, then you could just keep them in the glove compartment. It's worth a shot.
  8. Apr 1, 2008 at 7:45 PM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    I considered those options too. On the way back from the tire shop (old wheels with TPMS sensors still attached were in the bed), I hit the reset button, and nothing happened. I think they have to sense a certain amount of pressure in order to work correctly. I have no other knowledge than that.
  9. Apr 1, 2008 at 7:48 PM
    Roland
    Rhode Island
    A long time ago I was taught to always try the simplest solution first. It doesn't work every time but has saved me a lot of money and frustration over the years. We need someone to try it and report back what happened. :D
    I think you have to be have the engine off to reset the sensors.
    Now I want to know. I might have to let the air out of my spare and see if I can get the system to accept it.
  10. Apr 1, 2008 at 7:55 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the light will go off depending upon + or - like 7 lbs from what they were set to. if u take the spare down to 0, it'll make it turn on.
  11. Apr 1, 2008 at 7:58 PM
    Roland
    Rhode Island
    Exactly. But if I take the spare down and reset the system will it accept 0lbs of pressure as acceptable. Inquiring minds want to know!
  12. Apr 1, 2008 at 8:03 PM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    So take out all sensors (to sense 0 psi) and deflate spare (to sense 0 psi as well) then hit the reset button? Hmmm...interesting...that would definitely answer the question as to whether or not the sensors are programmed to sense a certain psi.
  13. Apr 1, 2008 at 8:19 PM
    The_Hodge
    SC
    if that were the case, then everytime u turned the truck off, it'd reset...and if u had one that was low, how would it know whick pressure to run off of?
  14. Apr 1, 2008 at 8:31 PM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    That is my question. I'm not sure what the computer looks for. Does it look for a specific psi (i.e. 25 psi regardless of situation), or does it look for a specific psi minus whatever is in the tires when the reset button is pushed. I may be thinking of this in the wrong way though.
  15. Apr 1, 2008 at 8:33 PM
    The_Hodge
    SC
    i think it looks for a specific + or - from a set pressure, unless u get them reprogrammed
  16. Apr 3, 2008 at 7:22 PM
    Tug
    Tug Active Member
    4X4 Access Cab
    Stock
    What the guys on the Corvette Forum WERE doing is epoxying the sensors to their rims and to ensure they'd stay in place they'd place a band around the rim and the sensor. Although it worked for some there were quite a few members that were having problems balancing their tires.
    Someone on CF tried these and they thought they were the greatest thing since sliced bread.
    [FONT=Verdana, Arial, Helvetica, sans-serif] IFORGED TPS adapter
    I placed a call to them a few minutes ago but their obviously closed. I'll call them again first thing in the morning to see if their adapter will work with our trucks.
    Im a little confused about reprograming the sensors, I know on my Corvette I have to run a large magnet over the valve stem to reprogram but that sensor tells me how much air pressure is in each individual tire, to my understanding the sensor on the Tacoma's only comes on when a tire is low, correct?
    Thanks
    [/FONT]
  17. Apr 3, 2008 at 8:03 PM
    Roland
    Rhode Island
    My understanding is that the sensors send a pressure reading to the truck. That is why according to the book when you rotate the tires and correct the front and rear pressures you are supposed to reset the TPMS system so that the truck knows how much pressure to look for from the different tires.
