Cheapest Lift Solution!
Discussion in 'Suspension' started by ilovemytaco, Sep 4, 2008.
  1. Sep 4, 2008 at 3:33 PM
    ilovemytaco
    ilovemytaco [OP] Well-Known Member
    i want to lift my tacoma but i want to know the cheapest way. i was looking around 3'' would be good to give it a good look
    while i have ur attention has anyone made a home made grill yet?
  2. Sep 4, 2008 at 4:43 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Read my lift FAQ.
  3. Sep 4, 2008 at 9:45 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
  4. Sep 4, 2008 at 9:57 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
  5. Sep 5, 2008 at 5:11 AM
    cleanTRDmachine
    cleanTRDmachine watch the meat
    Kyle
    Q-Town, PA
    06 DC TRD
    tint gray camo seat covers debadged color matched grille surround off of 06 TRD sport grillecraft black mesh grille Hella 500's demudflapped Toyota rear leaf TSB (first edition) 265/75/16 BFG AT TA KO's Flowmaster Super 40 #952445 Maglite Mod AntennaX 13in antenna Painted Lower Valance Vision X H4 Xenon headlights Halo Solaris H10 foglights Velocity Offroad 2.5 leveling kit (removed) Spidertrax 1.25" wheel spacers Rocky Mounts Clutch SD bike mount 4ft combo lock cable for bed extender Stage I interior LED's Toytec 1.5" AALs Extang Trifold Signature Series Bed Cover Reese front mounted tow hook Icon Stage 1 Suspension
    talk to Oxymar00n about his Satoshi
  6. Sep 5, 2008 at 3:30 PM
    ilovemytaco
    so what did u guys use to lift ur trucks
  7. Sep 5, 2008 at 3:39 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    You really should fill in your information so when you ask a question, I don't have to ask what kind of Tacoma you have.........1st gen?.......2nd gen?.......2wd?.......4wd.....base model?........sr5?......etc., etc.,
    That being said, the cheapest you'll find would probably be a spacer lift which consists of (usually) aluminum spacers for the front shock assembly and either AAL or lift blocks for the rear. These kinds of lifts are available from Toytec, Revtek, I could keep going, but what's the point. They're similarly priced from brand to brand. Toytec is a popular one since they make suspension systems for Toyotas only. You could get a complete lift kit for around $300.
    Someone mentioned Billstein 5100s, which is a better alternative for a more compliant ride, but would cost a little more. Bottom line, a spacer lift is your cheapest option.
  8. Sep 5, 2008 at 3:40 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    BTW, I have a 3" Toytec spacer lift that cost me $300 +/-.
  9. Sep 6, 2008 at 12:34 PM
    ilovemytaco
    oh sorry i have a 2008 tacoma 4 door v6 sb....thats a reasonable price but how much would it be to install it(just an estimate) also is there any downsides, im really going for looks:)
  10. Sep 6, 2008 at 2:13 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Not sure on the installation cost, I did mine at home with a couple friends. You'll also need an alignment once the lift has been installed. I think the biggest downside is a bit of a stiffer ride.
  11. Sep 6, 2008 at 2:15 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Have you had the rear spring TSB done? I ask because that will change your options for the rear end of the truck.
  12. May 13, 2009 at 9:23 PM
    T-Ride
    T-Ride New Member
    Newport Beach, CA
    05 base model
    I have an 05 tacoma 2.7L, 2wd, base model. If I get the 3" spacer lift, what's the max tire size with out rubbing?
  13. May 14, 2009 at 7:12 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    32" you can fit 33"s with some trimming of the inner fender wells
  14. May 14, 2009 at 7:14 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    check my signature.
