"Check charging system" with ignition on, but not running.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SnoopisTDI, Oct 1, 2024.
  1. Oct 1, 2024 at 9:07 AM
    SnoopisTDI
    SnoopisTDI [OP] Member
    DFW
    2017 Tacoma TRD-OR
    C4Fab bumpers, Fox shocks, Ovrlnd camper, 5.29
    When I turn ignition on, like to roll the windows up or down, without actually starting the engine, I see "check charging system."
    Is this just one of the normal warnings you get like all the other idiot lights that come on? I've never noticed it before but I guess I'm not in the habit of turning it on without starting it either.
    It starts fine, 12.3-12.7V on the battery, just shy of 14v on the alternator. Seems good to me.
  2. Oct 1, 2024 at 9:09 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It's normal.
    02Duck, drizzoh, RIX TUX and 4 others like this.
  3. Oct 1, 2024 at 9:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It just means that the ECU is detecting a continuous drain from the battery. It is a non-issue as long as you are aware.
  4. Oct 1, 2024 at 9:14 AM
    SnoopisTDI
    DFW
    2017 Tacoma TRD-OR
    Thank you. I was deep in the national forest the first couple times I saw it. Everything seemed OK to me but it was bugging the hell out of me not knowing!
  5. Oct 1, 2024 at 9:17 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    It's not charging because the engine isn't turning the alternator.
  6. Oct 1, 2024 at 12:17 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    But don't make it a habit of course.. :anonymous:
  7. Oct 1, 2024 at 12:22 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    On the new cars it gives you a “check seatbelts” warning. And if you have a push button start it tells you “press brake pedal to start”.Signs of changing times.
    MagicToolbox likes this.
  8. Oct 1, 2024 at 12:49 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Time to part it out. :p
  9. Oct 1, 2024 at 12:55 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  10. Oct 1, 2024 at 1:06 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    When you and your friends are being chased by a bear, you do not need to be faster than the bear ... just faster than your friends.
  11. Oct 1, 2024 at 6:09 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    technically, there's always a continuous drain on the battery. the ecu just doesn't see the alternator charging voltage because the engine isn't spinning the alternator.
    older vehicles had a battery light indicator that performed the same function.
