check engine light...again
Discussion in '1st Gen. Tacomas (1995-2004)' started by olderthandirt, Jun 11, 2013.
  1. Jun 11, 2013 at 5:43 PM
    olderthandirt
    olderthandirt [OP] New Member
    silver city nm
    2001 6cyl. tacoma
    Newbie seeking answers. I have a 2001 Tacoma 6cyl. I bought the truck
    with 110,000 miles. The check engine light came on almost immediately.
    I replaced the front CO2 sensor. The light came back on. Replaced the rear.
    light on. Replaced the cat. Light stayed off for about 2000 miles and now it's
    back on. What now?
  2. Jun 11, 2013 at 5:47 PM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    04 SR5 4x4 TRD Xtra Cab
    Have you gotten the code read? Do you know for sure it's an emissions problem?
  3. Jun 11, 2013 at 6:24 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Our trucks are not happy with aftermarket sensors or cats. You have a 2001 tacoma so it's rated for California carb emmissions I believe, so there should be two cats. Did you use a denso brand o2 or a/f sensor? What cat did you use?
  4. Jun 11, 2013 at 7:32 PM
    olderthandirt
    silver city nm
    2001 6cyl. tacoma
    Sensors were toyota parts, although I had a aftermarket cat put on by a muffler
    shop. The OEM was exactly twice a much as the aftermarket.
  5. Jun 11, 2013 at 7:37 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'm about to replace the rear cat and O2 sensors on my 01. I pulled the code my self and got the P0420. I took it to a shop so they could tell me exactly what wasn't working. They said the rear cat and O2 sensor was bad. I'm gonna go ahead and replace both sensors and the rear cat. I've heard a lot of people say that our trucks don't do well with cheap aftermarket cats or sensors. Although, I have heard plenty of stories about magnaflow being a good quality cat. When I do mine I'm gonna go with magnaflow and DENSO sensors. Hope this helps. Good Luck!!!
  6. Jun 11, 2013 at 7:41 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
  7. Jun 11, 2013 at 8:25 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    Ditto^^^^^^^^^^^^^^^^
    magnaflow is the way to go, I have used them in the past on a stang, with no trouble. very good quality product.
  8. Jun 11, 2013 at 10:19 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    I also went with 50 state magnaflow cats, got 10% from Autoanything. Seems to be a good quality alternative to Toyota ones. Most aftermarket cats are "49 state" legal, I think every Toyota after 2001 is 50 state legal and won't accept crappy emmission parts
  9. Jun 11, 2013 at 10:35 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    OP:
    you never mentioned what code it is you're getting
    is it the 0420?
    i keep getting that too, it's strange, though
    i manually reset it once (well, disconnected the battery) and it stayed off for weeks; came back
    then, after that, it went off by itself, and stayed off for a couple of weeks; just came back
    what's strange is that both times it's came on, it's been in the same exact place;
    when i'm heading up the bottom of this specific mountain range going around 35-40 in 4th
    could just be a coincidence; but, it's seriously in just about the same exact spot, right down to the blade of grass, going the same speed, in the same gear
  10. Jun 12, 2013 at 3:50 AM
    Inverno4
    Baltimore, MD
    I'm running Bosch O2 sensors on mine, never had a problem. Plus they are a lot cheaper.
  11. Jun 12, 2013 at 3:57 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    Depending on the code your getting, try cleaning MAF sensor. Get a can of MAF cleaner at auto parts store.
  12. Jun 12, 2013 at 6:07 AM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    Idk about bosch, except their spark plugs suck, alls i know is non denso sensors don't work for most people, you're special! I'd rather just go with denso stuff from rock auto
  13. Jun 12, 2013 at 7:45 AM
    Inverno4
    Baltimore, MD
    Maybe just lucky. That was before I got smart and started using only Toyota or Denso parts for my truck.
  14. Jun 12, 2013 at 9:12 AM
    olderthandirt
    silver city nm
    2001 6cyl. tacoma
    Auto Zone code reads PO420.air leak in exhaust before HO2S.
    Installer
  15. Jun 12, 2013 at 9:52 AM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Catalytic converter(nevermind it already replaced, didnt see that part)
  16. Jun 12, 2013 at 10:17 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    PO420 can mean everything from a leaky gas cap, to a leak in the fuel filler neck, or a leak at the charcoal canister, or a bad converter. I wouldn't be surprised if you replaced the converter and it comes back.
  17. Jun 21, 2013 at 2:52 PM
    olderthandirt
    silver city nm
    2001 6cyl. tacoma
    I went to the Toyota dealer and had it diagnosed. They came back with bad cat....
    2600.00 to replace. Muffler guy who replaced with aftermarket cat wants me drive 125 miles and leave to have diagnosed by his guy. Between a rock and hard place.
    The guy who replaced the cat took the truck to his mechanic. He came back with; the cat is good. the problem is with the front O2 .It is switching too slow causing it to trigger the check engine light. so now I have full circle...back to the front sensor. So I replace the front O2 again? Oh and it is still reading PO420.
