Check engine light came on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GrandMasterB, Jun 27, 2022.
  1. Jun 27, 2022 at 2:04 PM
    GrandMasterB
    GrandMasterB [OP] Well-Known Member
    2020 Tacoma TRD Sport
    Supercharged, 2" Lift, 33" tires.
    Anyone ever get his message? "A malfunction in the electronic control of the engine, throttle, or automatic transmission has been detected. Contact your t
    Toyota dealer to have your vehicle inspected."
    I did a scan and came up with P066014 and P010064
    2020 v6 - I have a Maggy supercharger, been running it for about 25000 miles with no issues.
    Any help/guidance will be much appreciated. Thank you!
  2. Jun 27, 2022 at 2:08 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    This thread may help you: https://www.tacomaworld.com/threads...harger-and-twin-turbo-systems.566390/page-582
  3. Jun 27, 2022 at 2:12 PM
    saint277
    saint277 Vigilo Confido
    Looks like your still in the warranty for a Magnusson SC, maybe you should reach out to them?
  4. Jun 27, 2022 at 2:13 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    These should help. Maybe a loose hose/connection/both.
    mZiggy likes this.
  5. Jun 27, 2022 at 4:42 PM
    GrandMasterB
    Good info, Thank you. I will start with getting MAF cleaner tomorrow after work. See how that goes. This may be a process.
    ktbell444 and mZiggy like this.
  6. Dec 30, 2022 at 12:46 PM
    307tacodude
    307tacodude New Member
    Derek
    2008 silver taco
    Wondering if you were able to get this resolved. Having the same issue on my 2022 v6 with Maggy SC. Fine for first 2,500 miles after installation but same codes mentioned above just popped on.
    mZiggy likes this.
  7. Dec 30, 2022 at 12:54 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The P066014 refers to the acis hardware being removed as part of the install (and capped off), and the code will come up whenever another CEL (or at minimum a MAF code) comes up, and clears when the accompanying codes clear. All the same, double check connections where it's supposed to be capped via the Magnuson instructions just to be sure.
    The YotaWerx Tuning Stryker customers that have had the p0100 series MAF codes pop in the past have typically resolved it via MAF cleaning and/or confirming connections. I think @ackshen (if I remember correctly) also had this and cleared it via a tune reflash, but it's been awhile and so I can't remember for sure.
    Regardless, MAF codes are typically very broad and vague, so I'd recommend starting with the basics of confirming connections and cleaning.
  8. Jan 2, 2023 at 8:13 PM
    ackshen
    ackshen Well-Known Member
    Golden, CO
    2016 Black TRD Sport DCSB 6MT
    Magnuson Supercharged, 6112/5160
    In my case, the two that showed up after a reflash were p062f44 (internal control module eeprom data memory failure) and p066014 (intake manifold tuning valve control circuit short to ground or open). I was told that P066014 will pop up any time you pull faults. The ACIS system is no longer present, causing the code, however it will not set a check engine light by itself so this isn't the reason you will see a CEL. A reflash / clear codes and I never saw the P062f44 again.
    mZiggy[QUOTED] likes this.
