OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 22, 2021 at 5:21 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Well I plan to finish up and publish dyno results for 7psi, 10psi, 14psi pump gas tomorrow. We will see what happens. (the purpose is to stress test FPC)
    I still drive mostly in 4Hi. Love how it drives. Probably 2000+ pavement and highway miles in 4Hi.
    4Hi really only sucks in 2 situations, U Turns and Parking lots.
    Should have broke by now if it was gonna.....
    The only thing that is an issue on the test mule right now is it may have a bad wheel bearing. But that was there before the 4Hi tests. Actually hard to tell if it's that or just a bad tire. The tires are 5yrs old.
    I have not been nice to this truck at all, on purpose. I haven't even changed the oil filter in 12,000 miles. On purpose.
    Floor it on cold engine.. on cold transmission...
    have revved it to 7500... (in boost)
    Toyota really built these engines tough. There seems to be only 1 thing that will kill it. Severe detonation.
    Bad oil, no problem.
    Low oil? no problem. I know this from experience running the engine with no oil at all (not on purpose lol).
    I've been trying to get it to blow up so I can install the forged rods/pistons/cams I have.
  2. Apr 22, 2021 at 5:39 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is just awesome.
    I remember that Castrol or M1 commercials where they ran the engines with no oil. I believe it was the old Slant6s though?
    In the end, that is very impressive.
    Thanks for doing it. FI or N/A.
    :cheers:
    Junkhead and ihatemytruck like this.
  3. Apr 23, 2021 at 8:01 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    From what I have been told, the AT skips gears less and behaves normally. See the main vF thread or the vftuner.com forum.
    :cheers:
  4. Apr 23, 2021 at 11:10 AM
    OVTune
    OVTune
    Okay, numbers straight off the dyno.
    93 octane, new calibration standard 7psi.
    This tune has been modified for increased drivability, smoothness on / off boost, shift changes, torque converter and such.
    It runs really well.
    Note, these runs are at the hub, no TCF, direct axle reading. Close to what you would see on a dyno jet.
    Testing was performed with no dyno fans, hot run and cold run.
    RED = hot run (intercooler temps >130 *)
    GREEN = Cold run (intercooler temps <100*)
    Numbers are quite consistent between several runs, around 350 ft lbs and 315-325whp. This is the power you can expect (at the wheel) on 7psi.
    This is real world style pull, not loaded down waiting for peak load. Just 2000 RPM and straight into it. dyno runs are sweeped at a 200 RPM rate / 20 seconds roughly.
    More torque is possible @ lower RPM if I fully load it and wait for peak boost at 1500 rpm before ramping, but it's not entirely realistic. This dyno graph represents realistic / real world see and feel. (on an AT)
    10psi and 14psi results pending
  5. Apr 23, 2021 at 11:19 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    quit making me want to spend money :spending:
    Junkhead and ownubad like this.
  6. Apr 23, 2021 at 11:29 AM
    OVTune
    OVTune
    Important to post boost vs tuned N/A
    RedLantern, CanadaToy, Torspd and 2 others like this.
  7. Apr 23, 2021 at 11:51 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    @OVTune, how differently do you expect the base turbos to perform?
    From my understanding the previous/original numbers on 7psi were done on the base turbos and all of your recent (the last ~5 months) has been done with the powermax turbos. Will we base guys see lower #s, and if so.. how much lower?
  8. Apr 23, 2021 at 11:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Are the N/A curves 2.0? Base or Perf?
    Just asking because I don't think we have seen any 2.0 dynos other than Dump Tubes?
    Thanks!
    Shellshock likes this.
  9. Apr 23, 2021 at 12:10 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I'd like to know as well, because those are nearly spot on with the numbers that been obtained/posted/advertised for the base turbos...
    And seeing as I'm on base turbos...
    ownubad likes this.
  10. Apr 23, 2021 at 12:23 PM
    OVTune
    OVTune
    Power between base / powermax should be close to what is previously been posted.
    This test was also with catted DP, previous results were decatted.
    But these results are stress test results. No dyno fans, no fresh air tube, no duct on the intercooler to keep temps cool.
    For example the "hot" test was when the intercooler temp was 130+ at the start of the run, and 160+ by end of the run. Purposeful crap conditions.
  11. Apr 23, 2021 at 12:26 PM
    mZiggy
    mZiggy Honey badger
    Marc
    That's still pretty great then, getting the numbers presented with less than ideal conditions.
    ownubad, tonered and Shellshock like this.
  12. Apr 23, 2021 at 12:27 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Side note, I love driving this truck so much more now that I'm not having to be paranoid about overboosting the whole time. Lol continues to really scoot along at 6-7psi, sometimes I don't realize I'm actually accelerating with how smoothly the boost can come on in 5th and 6th
    ownubad and tonered like this.
  13. Apr 23, 2021 at 12:28 PM
    Shellshock
    Iowa
    Just keep rubbing it in ziggy
    Skydvrr and tonered like this.
  14. Apr 23, 2021 at 12:29 PM
    mZiggy
    mZiggy Honey badger
    Marc
    :confused::notsure:
    tonered likes this.
  15. Apr 23, 2021 at 12:30 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Yesterday evening I checked my oil. 3k miles with the turbos onboard and I'm not burning oil, nor is it gunking up super quickly. Color wasn't the gorgeous golden of new oil, but it wasn't really that far off from it either.
  16. Apr 23, 2021 at 12:30 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's Friday, so I FTFY:
    :D
  17. Apr 23, 2021 at 12:30 PM
    Tacoma559
    Tacoma559 Well-Known Member
    2020 Tacoma dcsb 4 cylinder
    This will never pass smog in ca. No point in CA
  18. Apr 23, 2021 at 12:30 PM
    mZiggy
    mZiggy Honey badger
    Marc
    I am Ziggy and I approve of this correction.
    Skydvrr and tonered[QUOTED] like this.
  19. Apr 23, 2021 at 12:31 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Move.
    pinochle and Shellshock like this.
  20. Apr 23, 2021 at 12:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    You got my vote.
Thread Status:
