Check Engine Light Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotapower10, Jul 21, 2009.
  1. Jul 21, 2009 at 4:04 PM
    yotapower10
    yotapower10 [OP] Well-Known Member
    Neal
    Virginia
    02 Tacoma SR5 4x4 TRD
    TJM Roo Bar(Front Bumper/Bull Bar), LED Stop/Turn signal, LED undercab/bed lights, Custom Sound System w/ Subwoofer, Spray-In Bed Liner, Deck Plate mod, Black emblems, Black Stock Rims, Custom Fishing Rod Holder
    I have a 2002 v6 taco and my check engine light came on. I stopped by advanced today and got them to check the computer code for my check engine light. The code was T1135. Supposedly it means an Air Flow Heater malfunctioning or something like that. The guy at advanced said it might be the O2 sensor and I did not want to pay $200 for an oxygen sensor when my truck is running fine. I am getting ~18 mpg(even better than 2 months ago) and no stuttering or misfiring. I have recently done the deck plate mod and capped off both silencers. I am not sure what to do about the sensor. My dad said that I need to uncap the silencers because it has changed the way the air flow enters the engine(which makes sense). But my taco sounds soooooo sweet i dont want to change it. Any advice on what to do or how to fix the check engine light?
  2. Jul 21, 2009 at 4:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The code is a P 1135, and its the Bank 1 sensor 1 O2. Passenger side sensor closest to the engine.
  3. Jul 21, 2009 at 6:08 PM
    yotapower10
    Neal
    Virginia
    so do i need to spend the money on a new O2 sensor or is my truck going to be ok without one for a while?
  4. Jul 21, 2009 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'd get it replaced.
  5. Jul 21, 2009 at 6:25 PM
    yotapower10
    Neal
    Virginia
    ok thanks a lot man
  6. Jul 21, 2009 at 6:25 PM
    Forthedogs
    Forthedogs Member
    Walnut Creek, Ca.
    09 SR5 Access Cab
    First mod-license plate frame reads... "Driver carries no cash-wife shows dogs"
    Ditto. Yes you should replace it. If the cat overheats for over rich or lean condition it will melt down the matrix inside. If you are complaining about a O/2 sensor you will be screaming over replacing a cat.
  7. Jul 21, 2009 at 6:25 PM
    yotapower10
    Neal
    Virginia
  8. Sep 2, 2009 at 9:41 AM
    Rojo
    Rojo Active Member
    Texas
    12 TRD OffRoad 4x4 DCSB - Super White
    K&N, 2.5 lift/leveled, TRD FJ Wheels, 285/75R16
    I just had this same problem and also went to Advanced to get the code read but their machine said it was the Mass Air Meter (same 1135 code). Could their machine be incorrect or are there multiple 1135 codes for the Tacoma? I ask since you placed a "P" in front of the one you mention here.
  9. Sep 2, 2009 at 10:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Was it a "Mass Air" meter, or an Air Fuel meter?
  10. Sep 2, 2009 at 10:57 AM
    Rojo
    Rojo Active Member
    Texas
    The screen said mass air
  11. Sep 2, 2009 at 12:47 PM
    yotapower10
    Neal
    Virginia
    well i know with the code i had i replaced my o2 sensor on the passenger side and the check engine light hasnt come back on but chris4x4 is a great help and he can more than likely tell you more than i can
  12. Sep 2, 2009 at 12:58 PM
    Rojo
    Rojo Active Member
    Texas
    My first thought when the light came on was that it was some sort of emissions sensor but I wanted to be 100%. Maybe I should take it to Auto Zone for a second opinion. It's not running any different but I sure don't like that light staring at me.
  13. Sep 2, 2009 at 2:32 PM
    yotapower10
    Neal
    Virginia
    yeah mine wasnt running too much different either...my mileage dropped maybe .5 or 1 mpg but i didnt think it was too significant because i thought it was just me driving differently in the city but i couldnt stand it lighting up the cab every night
  14. Sep 2, 2009 at 8:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    P1135 is manufacturer specific code. For Toyota, it is exactly what Chris said. For a Ford, it is an Ignition switch problem. If it were an Audi, it would be Bank 1 Sensor 2.
  15. Sep 3, 2009 at 8:02 AM
    Rojo
    Rojo Active Member
    Texas
    So I went to Auto Zone last night for a second opinion and this time the code came up the same (P1135) but saying "Air/Fuel sensor heater circuit response. Bank 1 Sensor 1"
    Two out of three works for me so I'll be changing out my passenger side O2 sensor this weekend. Thanks for all the help guys.
  16. Sep 3, 2009 at 8:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its the Air/Fuel sensor.
  17. Sep 3, 2009 at 8:04 AM
    98tacoma27
    Ben
    Not Beech Creek
  18. Sep 3, 2009 at 8:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    Basically the same code.
