Check engine light flashing, motor running bad
Discussion in '4 Cylinder' started by alboy, Aug 26, 2008.
  1. Aug 26, 2008 at 8:14 PM
    alboy
    alboy [OP] Member
    florida
    98 SR5 4 wheel drive
    feels like not all cylinders are firing. ran codes and got p0125, p0401, and p1300. also just had some welding done to exhaust and i know they never disconnected my battery could have something to do with it?
  2. Aug 26, 2008 at 10:05 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you do any research on the codes?
    Check out this website and scroll down to look up the codes:
    http://www.troublecodes.net/Toyota/
    Happy reading!
    P0125 - Insufficient Coolant Temperature for Closed Loop Fuel Control.
    http://www.parksoffroad.com/tacomamods/maintitems/enginecode/cip0125.pdf
    P0401 - EGR Flow Insufficient.
    http://www.tankota.net/repair/Repair_Manual/03tacoma/di/eg2rzfe3/cip0401.pdf
    P1300 - Igniter Circuit - No. 1.
    http://www.parksoffroad.com/tacomamods/maintitems/enginecode/cip1300.pdf
  3. Aug 27, 2008 at 6:21 PM
    sormi
    sormi Active Member
    Texas
    Plane Jane with SR5
    So did you get it fixed? Did the welding cause any problems? I'd like to know seeing i'm about to have a muffler put in.
  4. Aug 27, 2008 at 11:19 PM
    alboy
    alboy [OP] Member
    florida
    problem fixed replaced plug wires. misfiring was the problem.
  5. Aug 27, 2008 at 11:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you wont have any trouble at all with a cel just having a muffler welded in.
