check engine light need to pass inspection
Discussion in '1st Gen. Tacomas (1995-2004)' started by blacksheff405, Nov 2, 2011.
  1. Nov 2, 2011 at 7:02 AM
    blacksheff405
    blacksheff405 [OP] no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    alright so i took my truck to get it inspected and the engine light was on. (because of my tires) well got there they cleared it and told me to drive around well after about 2 1/2 hrs of driving back and forth the light came back on.. he cleared it again and i was wondering if there was a way to pass the inspection without having to get a new speed sensor (mine is broken)
    thanks in advance
  2. Nov 2, 2011 at 7:15 AM
    blacksheff405
    caleb
    bump need help... have to get inspected asap
  3. Nov 2, 2011 at 7:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Fix the problem and you'll pass inspection.
    Sorry, had to say it.
  4. Nov 2, 2011 at 7:37 AM
    blacksheff405
    caleb
    well i really don't want pay for a new sensor if i don't have to
  5. Nov 2, 2011 at 7:39 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Why are your tires causing a CEL?
    Based on my calculations....you need a new speed sensor.
  6. Nov 2, 2011 at 7:40 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Why don't you want to pay to fix the sensor?
  7. Nov 2, 2011 at 7:42 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I don't think you will be able to pass without fixing it. Not what you want to hear, but I'm afraid you are just out of luck. (Disclaimer: not sure what your state inspection laws are)
  8. Nov 2, 2011 at 7:42 AM
    blacksheff405
    caleb
    well this blows alright.. i was afraid of that but hey it don't hurt to ask...
  9. Nov 3, 2011 at 4:55 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Or buy a Scan Tool and clear your own codes right before you pull up to have it inspected??? Probably make sure you go do a different inspection station too?
  10. Nov 3, 2011 at 5:03 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    remove bulb. no CEL anymore.
  11. Nov 3, 2011 at 5:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    Some states will hook the scanner up regardless.
  12. Nov 3, 2011 at 6:06 AM
    blacksheff405
    caleb
    yea they hooked it up anyways.. but i'm trying to get it fixed this weekend.. i'm going to try and do it myself.. not sure how hard its going to be though..
  13. Nov 3, 2011 at 6:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Do you know the actual code number?
  14. Nov 3, 2011 at 6:13 AM
    blacksheff405
    caleb
    no i'm not even sure what part i need but my dads gonna help me out.. unless you have some advice tips ect.
  15. Nov 3, 2011 at 6:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    LOL, that's kind of why I need the code. Should be PO___ (I'm guessing a 500)
  16. Nov 3, 2011 at 6:18 AM
    blacksheff405
    caleb
    were would the number be?
  17. Nov 3, 2011 at 6:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    The code am I referring to is the CEL. You have to scan it with a reader (plugs into the OBDII port under the driverside dash). It's the same thing the inspection people do.
  18. Nov 3, 2011 at 6:22 AM
    blacksheff405
    caleb
    so should i take it back to them and ask them for the number? sorry for the ignorance
  19. Nov 3, 2011 at 6:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes or you should be able to have it read at a local auto parts store for free
  20. Nov 3, 2011 at 6:26 AM
    blacksheff405
    caleb
    ok i think i might take it to the guys b/c they some good ole country boys and i think they would be glad to help me out.. thanks for the info when i get a chance to get out there and get the info i'll post it up here... thanks again
