check engine light on?
Discussion in '1st Gen. Tacomas (1995-2004)' started by apex9r, Oct 31, 2009.
  1. Oct 31, 2009 at 9:59 PM
    apex9r
    apex9r [OP] mountain rover
    '97 4x4 2.7 5spd
    starting from scratch
    ok, this is about as basic as it gets right...lol sorry but how do you find out what is wrong when the truck is too old to have the plug in for the tester?
  2. Oct 31, 2009 at 10:10 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    lol....I like your signature, as far as your question is concerned I don't know and I hope someone will chime in on that. But have you checked basic things like your oil level, radiator fluid level, etc?
  3. Oct 31, 2009 at 10:11 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  4. Oct 31, 2009 at 10:42 PM
    apex9r
    '97 4x4 2.7 5spd
    pretty suremthat was 2000 and newer:notsure:
  5. Oct 31, 2009 at 10:43 PM
    apex9r
    '97 4x4 2.7 5spd
    you know it came on right after i added some antifreeze to the overflow res. could that be the issue?
  6. Oct 31, 2009 at 10:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    All 1996+ model has the OBDII protocol, check the link I provided above. OP, I don't think adding antifreeze would cause the CEL, could be just a coincidence. Maybe have someone with a code reader pull the codes for you and then you can post them up here.
  7. Oct 31, 2009 at 10:48 PM
    apex9r
    '97 4x4 2.7 5spd
    oh 96 and newer?!?! right on, i feel dumb now lol i just bought it and assumed it didnt have one:smack:
  8. Oct 31, 2009 at 10:51 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    If it was low and then caused your engine to overheat than maybe yes. I'm not sure why it would go off just because you added some antifreeze to it, I have never heard of that before. You may want to recheck it again though.
  9. Oct 31, 2009 at 10:57 PM
    apex9r
    '97 4x4 2.7 5spd
    just thought if it had too much coolent in it maybe ,but it has an overflow relief for that very reason so no way is it that. oh well autozone will check codes for free so no worries. im guessing just a egr or something. funny it came on a week after i buy it though, and my dome light stopped working to around the same time.............hmmmmmm
