check engine light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mb_edgar, Apr 6, 2010.
  1. Apr 6, 2010 at 2:31 PM
    mb_edgar
    mb_edgar [OP] Well-Known Member
    Manhattan Beach
    Tacoma TRD Off Road Pack
    6000k headlights and fog lights, L.E.D lightning all around, satoshi grill, hella 5100's behind the grill, pnasonic in dash, dual fosgates ps3's behind back seat, powder coated back bumper.
    So I removed my rear cats which aren't monitored, and added a flowmaster 50 muffler. and now almost three weeks after removing my cats the check engine light somes on. Any ideas what it may be thanks for the help
  2. Apr 6, 2010 at 2:33 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Have the code read at an autoparts store. Could be a million things.
  3. Apr 6, 2010 at 2:36 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    On my Jeep there is a trick with the ignition, on-off-on-off-on in three seconds and the OD will spit out the codes. Is there nothing like this on the Tacoma?
  4. Apr 6, 2010 at 2:41 PM
    mb_edgar
    Manhattan Beach
    I don't think its anything to big to worry about, she's riding fine if not better then before. But I will definitely will see if I can get that error code thanks guys..
  5. Apr 6, 2010 at 2:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get the code read and report back to us. may be something as simple as the gas cap need tightening.
  6. Apr 7, 2010 at 3:11 PM
    Stlrzfan
    Stlrzfan New Member
    SR5
    I was using Supermarket discount gas in my 05 AC 4X4 SR5 and the light came on. Autozone guy read the code and said it was the "catalytic converter- $800 *big smile on his face*" I told him it was still under federal law warranty and drove off. Switched gas brands ( Sheetz here in PA) and the light went out in a couple of days and hasn't come back on since ( two months). Yeah, I stopped using the cheap gas even tho it's typically 60 cents off a gallon.
  7. Apr 7, 2010 at 3:32 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Have Autozone check it out. Report back to us, more than likely it's nothing if your truck is running fine. There a couple of ways to reset it (using the scanning tool, disconnecting the Neg. Battery Terminal for a about 10 mins). Hopefully it's something like a gas cap.
  8. Apr 7, 2010 at 3:55 PM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    do u have a k&n air intake or anything?
  9. Apr 7, 2010 at 6:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for your cel...it was probably that the gas cap wasnt tight enuff...cause they will set off the cel as well.
  10. Apr 7, 2010 at 6:50 PM
    Country
    Country Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    Better check the engine
  11. Apr 7, 2010 at 6:52 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    you probably are running low on blinker fluid.
  12. Apr 7, 2010 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hows about at least trying to be helpful....instead of some bullshit post??
  13. Mar 11, 2011 at 5:41 PM
    skipper
    skipper Member
    reg cab
    My check engine light came on about a month before inspection was due.. I called two local dealers and asked how much? They floored me 80.00 to scan it plus labor and parts usually about 500. I went to auto zone for free scan, cooling problems, free print out of problems and parts needed for repair: thermostat,temp sensor and top off antifreeze 70.00. Didn't solve the problem. Back to the dealer 80.00 for scan, changed sensors, 80 for new scan total 500. Had a mazda truck, check engine light came on auto zone said EGR 95.00. Went to the local dealer and asked, EGR usally are ok it's the sonsor on the exhaust manifold 65.00 bought it and that fixed the problem. Not so sure about the zone anymore. Nice people though.
  14. Mar 11, 2011 at 5:45 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    18 DCLB OR Prior: 99LX470/05DCOR97LX450/914R
    Basic
    Did the exact same thing with the same muffler. Check engine light came on also. I work at Autozone and scan it myself. But when I scan it it says its the O2 sensor.
  15. Mar 11, 2011 at 9:05 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    for 30 bux you can buy an OBDII scan tool.
  16. Mar 11, 2011 at 9:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And for 59 you can get an Ultra Gauge.
  17. Mar 12, 2011 at 7:02 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    URD O2 simulators clip into the rear O2 sensors. If you remove the rear O2 sensors, how do you add the URD kit? :confused:
  18. Mar 13, 2011 at 3:38 PM
    DrRabbitFurHead
    Salem, VA
    Thanks for the link. I bought the O2 sims from URD and they seem to be working well. I am glad you shared the link and if I have any problems, this will be the replacement.
