check engine light persistence
Discussion in '1st Gen. Tacomas (1995-2004)' started by rmartinla, Jan 10, 2013.
  1. Jan 10, 2013 at 7:17 PM
    rmartinla
    rmartinla [OP] Member
    2000 PreRunner
    Hello TW, Twice in two years my 2000 Tacoma O2 sensor has been changed at the catalytic converter and twice the check engine light returns within days, the sensors were changed after computer analysis were run indicating the O2 sensor as the problem. Am I facing a unique tacoma problem here? Other options? Thanks.
  2. Jan 10, 2013 at 7:18 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I've had several cat codes but all were exhaust leaks. Check for leaks
  3. Jan 10, 2013 at 8:34 PM
    BamaToy1997
    Bill
    Navarre, FL
    Might help if you could post the specific code. There are a lot of O2 sensor and catalytic converter codes.
  4. Jan 11, 2013 at 8:09 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Had the same problem at Toyota. Then my buddy, a mechanic dug a little deeper with his diagnostics. Turned out to be a slow openning egr solenoid, different from the egr valve. No problem since(18 mths ago).
