Check Engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by JaredC, Dec 11, 2010.
  1. Dec 11, 2010 at 12:04 AM
    JaredC
    JaredC [OP] New Member
    If there is another thread about this then I am sorry for creating this one, but I was unable to locate an answer with the search function.
    My check engine light came on the other day (2002 Tacoma) I called the Toyota dealer and they said it would cost me 160 dollars to get the diagnostic run on it to figure out the problem.
    Is there any other place I can take it to that is cheaper than that or any potentially easy fixes that can cause the light to go off that I can simply do on my own without wasting that money?
    The truck is just over 99k miles. Any help would be greatly appreciated.
  2. Dec 11, 2010 at 12:07 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Drive to advanced auto ask them to check your engine code. They will tell you what it is.
    They do not charge its free, they will not clear it.
    They are not supposed to, unless you slip him a 5 or something lol
  3. Dec 11, 2010 at 12:19 AM
    JaredC
    Unfortunately Advanced Auto appears to be almost solely located on the East Coast.
    I am in the San Francisco California area. So I guess I will keep trying to call around and see if anyone else does it for free.
  4. Dec 11, 2010 at 12:50 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
  5. Dec 11, 2010 at 6:50 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    autozone would be another place to try,im told they do it for free. 160$ is such a rip off, you could go buy ur self a half decent code reader for that price.
  6. Dec 11, 2010 at 7:46 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    You COULD buy yourself a decent code reader not a half decent one lol
  7. Dec 11, 2010 at 8:02 AM
    thombiz
    thombiz Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    Most Check engine lights are errors. I find if I'm setting in the truck with the ignition key on but the motor not running, like you might do listening to the radio, it will cause a check engine light after about 5 minutes. You can turn off and reset the check engine light by disconnecting the positive cable on the battery for about a minute then reconnect. Almost always, the check engine light will not return.
  8. Dec 11, 2010 at 8:21 AM
    JaredC
    I am going to give this a shot, I was listening to the radio in my car the day it happened so it could certainly be this.
    Also I called Auto zone and they said they had the code reader for 60 bucks but couldn't run the diagnostic for me.
  9. Dec 11, 2010 at 9:25 AM
    DirtDriven
    DirtDriven Active Member
    You can pick up code reader pretty cheap. Look on Amazon and sort by bestselling. You can pick one up for around $50 and less. It is a good tool to keep around. If your strapped for cash like everyone else most big chain parts stores will read the codes for you for free. Good Luck
  10. Dec 11, 2010 at 11:21 AM
    JaredC
    This was the problem. Thanks a lot man, saved me a bunch of money.
  11. Dec 11, 2010 at 12:26 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ^ right on.if it comes back on,get the codes checked and hit us up with the numbers so we can figure out whats goin on.
  12. Dec 11, 2010 at 2:43 PM
    thombiz
    Corpus Christi
    Other people have helped me bigtime on these forums so I'm glad when I can give back. Glad to help.
  13. Dec 11, 2010 at 6:33 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    All of the parts stores in my area does it for free. You could buy an ultragauge for $60 and have one yourself. www.ultragauge.com
  14. Dec 11, 2010 at 8:41 PM
    boats
    boats Member
    Poconos
    03 dbl cab trd
    Most likely just an O2 sensor. Got a good friend that's a Toyota Tech. That's the most usual check engine light according to him. Happened to me. Best of luck
  15. Feb 7, 2013 at 4:44 PM
    raybo128
    raybo128 New Member
    SR5 4WD
    Easiest way to reset check engine light: In the under hood fuse box, locate the 20 amp EFI fuse. Pull, count to 10 and replace. You won't lose your radio presets, etc.
