Check Engine Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Irish020, Jun 21, 2011.
  1. Jun 22, 2011 at 5:58 AM
    Irish020
    Irish020 [OP] Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    So I stopped at Advanced Auto this morning on the way into work. They ran a diagnostic code for me and it says:
    Evap-Emission System incorrect purge flow
    Evap-Emission System Leak detected grossly no flow
    Any recommendations? The girl that ran it said it may have been the loose gas cap...she did not reset the CEL for me.
  2. Jun 22, 2011 at 6:14 AM
    EricGagne
    EricGagne Well-Known Member
    Eric
    Montreal
    2010 TRD Off Road
    Literider Tonneau Cover, RAM Mount Laptop Support. Uniden CB RTT and awning with self-designed custom rack Dual battery system - National Luna solenoid and monitor, Columbia Overland dual battery tray, 2 Odyssey PC1200 12 circuits Fuse block with 80A macro fuse block "breaker" OME suspension Replaced passenger area with a flat platform for my ARB fridge and camping clothes. Tiregate HG series
    It would be better if she had given you the actual codes and not just the descriptions.
    Evap-Emission System incorrect purge flow:
    That is code P0441
    Evap-Emission system Lea dectected grossly no flow:
    Not 100% sure but I think that would be a P0455 which the correct description for is Evaporative Emission Control System Leak Detected (Gross Leak).
    I've been fighting these 2 codes for almost 2 months now and I've learned a lot about them. The problem is most likely your gas cap since it started short after you filled it up.
    The gross leak test is done when the car is not running and starts only 5 hours after the ignition is turned off. At this point, if your fuel temperature is not below 95 the test starts 2 hours later and if it's still not below 95 then it starts another 2.5 hours later.
    So the ignition may need to be off for as much as 9.5 hours for test to be done. That's why sometimes it takes a few days before the CEL goes off after you tight your gas cap.
    And for the record................don't panic because is says "gross" leak, what they call gross is actually very small.
  3. Jun 22, 2011 at 6:21 PM
    Irish020
    Phil
    Pennsylvania
    So, I hear my problem was probably a loose gas cap...I tightened it and am waiting for the light to reset.....stay tuned.......
  4. Jun 22, 2011 at 6:59 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you want to speed up the reset process for testing purposes...You can disconnect the battery for 20-30 mins and it should make the light go out. If it comes back that was not the problem.
  5. Jun 23, 2011 at 6:02 PM
    Irish020
    Phil
    Pennsylvania
    Okay, so I did the battery thing and the CEL is off and has not lit again! Damned loose gas cap!!!
  6. Jun 23, 2011 at 6:03 PM
    Irish020
    Phil
    Pennsylvania
    Thanks to all for your advice. Once again Tacoma Forum has saved me a potentially costly trip to a dealership or garage!!! I love this place!
  7. Jun 23, 2011 at 6:13 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Glad you got it solved. I got CheckEngine for a while, it come and goes. If it back on I don't know if I'm able to pass inspection for the tag. In my county I can't get a tag if my CheckEngine is on.
