check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by fish, Jun 14, 2010.
  1. Jun 15, 2010 at 12:03 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Ohhh... makes sense
  2. Jun 15, 2010 at 1:11 PM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    I just replaced the Air/Fuel ratio sensor on mine last week. My truck only had 72,000 on it. The heater was what went out on my sensor also. I got the OEM Denso from Rockauto for $115. This same part at the Stealership will cost you $213!!! I was gonna replace it myself, but I could not get the bolts off the studs. The nuts would make a couple turns and then lock down. I ended up having to take it to a shop, and they had to heat them with a torch to get them off. Cost me $50 labor. But at least I saved some money on the sensor, thanks to Will (TacomaMan 04).
  3. Jan 29, 2011 at 5:22 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    hey guys i just got the same code that popped up. im assuming i do the same thing? where exactly is this sensor located and is it somthing i should be attempting to fix on my own? i also had a p0456 code come up which is a small emissions leak. and suggestions on what i should do for that also?
  4. Jan 30, 2011 at 2:42 AM
    Quast
    Dustin
    Mission, BC
    Bump!
