Check out my new enclosure! And an Amp Q
Discussion in 'Audio & Video' started by wakeman135, May 1, 2010.
  1. May 1, 2010 at 11:16 PM
    wakeman135
    wakeman135 [OP] Member
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    3" Toytec Spacers, Rear AAL, Bilstein 5100 in rear, Kenwood Excelon 994 HU, CTX65CS front components, ID IDQ10D4V.3, PowerBass 1100 5ch amp, 6" deckplate mod, 55w 8000k HIDs
    So i have been working on this enclosure the last few days. I dont really have any assembly/construction photos (i got to carried away with getting it done) but here is the finish product, preceded by a semi-finished uncarpeted picture.
    [​IMG]I think it turned out sweet. It allows me to still use the rear seats, it also doubles as a killer armrest. It comes out to roughly .9cuft. Im installing an idq10d4v.3.
    Now for my amp question, Im running the sub listed above as well as ID ctx65cs components up front. I will be running my rears off HU power for now. What 4-channel can you recommend to run this set up, or should i spring for a 5-channel for eventually amping my rears? what can you recommend based of experience?
    IDQ10 RMS is 500watts
    CTX65CS RMS is 100watts
    so 700 watts rms total
    Thanks y'all!
  2. May 1, 2010 at 11:22 PM
    wakeman135
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    Might i ad, i have looked at the following amps but want to be sure of the best amp for my money before i buy:
    Alpine PDX-5
    JL HD900/5
    Powerbass ASA1100.5x
    haven't looked into any 4 channels yet
    Budget <$400
    I know there are many more amps and opinions so i would like everyone's input. i listed to alot of everything, mostly country and rock, not really any rap. I think that is all the information you might need. Thanks!
  3. May 1, 2010 at 11:23 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    looks awsome man! good work!
  4. May 2, 2010 at 12:22 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What impedance is the IDQ sub?
  5. May 2, 2010 at 1:03 AM
    wakeman135
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    It is dual 4 ohm. I plan on wiring it to 2 ohm impedance.
  6. May 2, 2010 at 9:07 AM
    ItalynStylion
    Steven
    DFW, Tx.
    If you only plan to run a front set of speakers and a sub (good idea) you can get away with a beefy 4 channel. Other than that, get a 5 channel like the PDX5 and go at it.
  7. May 2, 2010 at 10:51 AM
    wakeman135
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    Stylion,
    Will running a 4 channel and bridging two of the channels to run the sub limit the capabilities of my HU's (kenwood excelon 994) eq options? Will i be able to adjust the "subwoofer" contol or will i just be adjusting the rear two channels to for my sub control? thanks
  8. May 2, 2010 at 10:54 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    You would just run the outs from your HU that are labled "sub" to the rear channels of the amp. You would not be limiting your eq setting from the HU if you ran it this way. If you ran the rear outputs to the amp, then you would be limiting the EQ settings for the subs.
  9. May 2, 2010 at 11:48 AM
    ItalynStylion
    Steven
    DFW, Tx.
    ^this
  10. May 2, 2010 at 2:53 PM
    wakeman135
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    ^^^ That"s exactly what i wanted to know. Thanks alot.
  11. May 2, 2010 at 4:02 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    First and foremost you should be banned for not getting dimensions, build pics. Secondly...900/5
  12. May 2, 2010 at 6:31 PM
    glandnut
    glandnut Reserve Squirrel Hair
    Florida
    16' 4Runner TEP, 01' Ext cab 4x4
    secret stuff.
    You can get a PDX-5 for under $400, but no way on the 900/5. I wish I could afford a 900/5, but they are steep!
  13. May 2, 2010 at 6:33 PM
    wakeman135
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    Ha ha well i have all the dimensions, you never asked. :D overall dimensions are 14.5" wide x 20.25" deep x 20.75" tall. The sealed portion for the sub is a little more complicated dimensions as there are a few angles that come into play. Luckily, i have the whole project drawn to scale so i can do it again :cool:
    here are a few more photos
  14. May 2, 2010 at 6:57 PM
    DevL
    DevL Well-Known Member
    HD900/5 is much better than the PDX5 but its $700 online and I got a quote for $75 from a dealer. The sub gets 500W no matter if its 2Ohms or 4Ohms with the HD900/5. I could actually hear a difference in sound quality between a PDX5 and HD900/5. Otherwise I would not have decided to spend the extra money. If you can save more money up get the HD900/5.
  15. May 2, 2010 at 7:02 PM
    jurrelyap5
    jurrelyap5 Coooooooach!
    Coach.
    That is genius! How much did it cost you to make? Time+money-wise. Thanks!
  16. May 2, 2010 at 7:51 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    props on a nice looking/functioning enclosure
  17. May 2, 2010 at 10:26 PM
    wakeman135
    Brandon
    Vancouver, WA
    2002 Tacoma SR5 4x4
    I think with carpet and glue, a full 4x8 of mdf, right around 55 dollars or so. i have plenty of glue left to do one or two more tho. And as far as mdf, a 4x8 sheet is enough for 2 enclosures. it took 2 evenings to build it and an hour to carpet it. The most time spent was getting the dimensions i wanted.
  18. May 2, 2010 at 10:28 PM
    jurrelyap5
    Coach.
    Thank you sir! Props to you.
  19. May 3, 2010 at 8:46 AM
    sirsaechao
    Tim
    Commifornia
    Make more cause I'll buy one.
  20. May 3, 2010 at 8:52 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    good job man it looks very nice! :thumbsup:
