Check out this truck! Fair Price?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodsey32, Sep 4, 2012.
  1. Sep 4, 2012 at 1:27 PM
    woodsey32
    woodsey32 [OP] New Member
    I found a truck I really like, but am unsure of the price. Here is trh description of the truck:
    "Yes the entire exterior is Rhino Lined. This was $2700 out the door back in 08'. half the price of a paint job yet durable with a lifetime warranty from Spokane Rhino Linings. (i have receipt)
    -2007 Tacoma Double Cab short bed 6 speed manual 4WD
    -JL audio 6disc cd changer power door/locks, AC, etc... not the plain jane model
    -79,000 miles.
    -Still has an extended warranty till 100,000 miles or 7 years. Bought truck in December of 2006 from Rogers Motors of Lewiston Idaho. still a year and a half left on the warranty.
    -Oil changes and services on the regular. a lot from the dealer and the rest by me. spark plugs, air filters, cleaning throttle body, MAF sensor etc.. ( i have the paperwork)
    -ALL gear boxes (rear & front diffs, tranny, transfercase) changed 3 times already. once at 30,000, then at 50,000 another when i had the regearing done. Overkill i know, but i like to run on fresh fluids.
    -6 inch Fabtech lift/ shocks are Bilstein 5100's in front set at 1.85 for a total of 8 inches of lift.
    -Custom ordered Alcan springs (out of Colorado) in rear with 8 inches of lift and an added 300lbs over stock load capacity. (so this means NO unsafe blocks in rear like most lifts have)
    -U-Bolt flip kit installed on rear springs
    -4.88 gears (speedmeter is 10mph fast from 50 and up I can give you a cheat sheet for all speeds) (odometer gives an extra 1.36 miles every 10 miles)
    -Custom sliders built by BeefedTaco in Southern California. (the supports are as far forward as possible. it is a bolt on kit and i can high lift my whole truck off the ground with them) truck is 5300lbs with gear
    - Safari snorkel kit.(for Hilux but modded by Safari to fit 2nd Gen Tacomas since others dont make a kit for these yet)
    -315/70/16 (35X12.5X16) Dick Cepek Mud Terrains. Bought last summer.
    -Biggest deep cycle battery Optima has to offer. You will not be able to get one with more cold cranking amps or amp hours. 75 amp hours 900 cold cranking amps. 4 terminal posts.bought this year.
    -All Pro Winch Bumper (will fit up to a 9500lb Warn)
    -CB installed but will need new whips on bed. mounts are there
    -Shut off switch for ABS
    -Installed 750 watt inverter with outlets ran to the back cab. this is in addition to the factory 400 watt inverter that has an outlet in the bed.
    -Wheel lug nuts are ALL key studs and i have two sockets that fit them for you.
    This truck has been taken care of well and is going to last forever if you continue to treat it like i did. or dont, its a toyota. enough said"
    What would you consider is a fair price for the truck? $30,000, $20,000? Any guidance would be greatly appreciated.........
  2. Sep 4, 2012 at 1:38 PM
    Large
    Large Red
    Hard to tell due to different prices per region but I would say from 18-23k.
  3. Sep 4, 2012 at 1:39 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    21,500 is what i would offer. seller would probably meet in the middle if they didnt want an arm or leg along with some $. All the extra mod doesnt automatically equal more $
  4. Sep 4, 2012 at 1:40 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    20, no more than 22.
    Waiting for a flood or something? Pretty much the only thing that truck would be good for :stir:
  5. Sep 4, 2012 at 1:43 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    yeah mods go either way for trucks. good or bad, but just because there's 5-10k worth of mods doesn't mean you have to pay full price for them. try to stay at what the actual stock 2007 truck would cost today
  6. Sep 4, 2012 at 1:48 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Like others have said, if it isn't a OEM add-on, it does not increase the value of the vehicial. Its really a negative to some people, trucks already modified already. I would reccomend you go to KBB and see what your truck would go for stock.
    Sorry if it wasn't what you wanted to hear.
  7. Sep 4, 2012 at 1:51 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
  8. Sep 4, 2012 at 1:52 PM
    Streetsurfz727
    Streetsurfz727 Well-Known Member
    Its funner to build your own truck any ways even if you don't know what you doing.
  9. Sep 4, 2012 at 1:55 PM
    Large
    Large Red
  10. Sep 4, 2012 at 2:01 PM
    woodsey32
    Yup! That would be the truck. He is selling it locally here in Northern Idaho for $24,000. It seemed like a fair price, but I don't know much about Tacomas. It looks like he has a lot of money in it, but I wanted an opinion from third parties.
    I really appreciate the advice.........
  11. Sep 4, 2012 at 2:09 PM
    Large
    Large Red
    :popcorn: ?
  12. Sep 4, 2012 at 5:24 PM
    woodsey32
    He said it is because he is getting a 65 crewcab 1ton ford built with a cummins diesel. He said as he gets older, he finds a need for a larger truck.........
    So it sounds like a mutual opinion that an offer around $21,500 is good.....KBB puts the value of a comparable (w/o the aftermarket parts) around $20,500
