Check Your 3.5l Coolant Pipe!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ruggybuggy, Jan 31, 2018.
  1. Apr 18, 2021 at 9:20 AM
    #181
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You won't see a new gen till 2026+ tbh... Tacos have been on a 10ish year lifecycle
    TAC1[QUOTED] likes this.
  2. Apr 18, 2021 at 9:22 AM
    #182
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    So this was fixed by 2019?
  3. Apr 18, 2021 at 9:22 AM
    #183
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    By then it will be electric........problem solved
    Skydvrr likes this.
  4. Apr 18, 2021 at 9:27 AM
    #184
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Just go ahead and buy one....they aren't going to change much, if at all, even when the new models eventually come out. You'll just know to keep an eye on certain things. Lots of guys have had issues with their crank position sensor that has left them stranded as an example of common things that have gone wrong with these truck...didn't stop me from buying it tho.
  5. May 6, 2021 at 11:43 AM
    #185
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    That makes sense.
    Good point.
  6. May 6, 2021 at 12:10 PM
    #186
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe MY 2024 is when the 4th Gen is due.
    MOC221_, tonered and Lt. Dangle like this.
  7. May 6, 2021 at 12:22 PM
    #187
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Agreed. Fall of 2023 you will see the 4th gen IMO on the street.
  8. May 6, 2021 at 2:48 PM
    #188
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Ive had a coolant smell since new in 2018 and if its this pipe and Toyota doesn't warranty it I'm going to be pissed!
    Ive reported it numerous times (Before knowing about the crossover pipe) and nothing from the dealers I've been too.
  9. May 6, 2021 at 2:52 PM
    #189
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Similar experience. My 2018 always leaves the garage smelling of coolant after it’s been running. But in the last 3 years the level has never dropped. So I figure it’s the reservoir venting.
  10. May 6, 2021 at 2:59 PM
    #190
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    If it's documented, then I would imagine you're good to go. Your dealership might be kicking and screaming the whole way, but it's not your fault that they couldn't diagnose the issue prior to your warranty expiring.
  11. May 6, 2021 at 3:36 PM
    #191
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    One thing I notice on tw you guys have so many ridiculous problems my 2017 is flawless must of been a good month on the production line for me and my truck lmao lucky me
    Evostaco likes this.
  12. Jun 8, 2021 at 12:37 PM
    #192
    AZVern
    AZVern Well-Known Member
    Vern
    Phoenix, AZ
    2016 Tacoma TRD OR DCLB
    Not enough
    For informational purposes. I have a 2016 DCLB. 100k miles in the Arizona heat. Just had it replaced because it became porous or the seal between the flange and the plastic pipe just wore out. Book has it listed as a 16 hour job and with my oil change I came to about $1500
  13. Jun 8, 2021 at 1:03 PM
    #193
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :eek:
    Did they at least toss in some swag for keeping the shop busy?
    shakerhood, Kev250R and Skydvrr like this.
  14. Jun 8, 2021 at 1:28 PM
    #194
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What shop u go to? Camelback?
    TAC1 likes this.
  15. Jun 8, 2021 at 2:55 PM
    #195
    flacoloco
    flacoloco Well-Known Member
    BMW had something similar on their Mini Cooper's. I believe their was a Thermostat housing that cracked about 30 to 50K miles. (its big job so it keeps dealers happy)
    do you have a plate underneath? the fluid could be there and as you drive it gets dry. (no pavement marking in your garage)
    Junkhead likes this.
  16. Jun 9, 2021 at 9:02 AM
    #196
    o313
    N
    2018 DCLB AT SC
    I seem to recall its routed above the rear of the engine which I think would leak down onto the trans but I'm not sure. I'll take a peak at that area when I'm underneath trying to silence my OME Dakar leaf spring bushings.
  17. Jun 9, 2021 at 9:50 AM
    #197
    AZVern
    Vern
    Phoenix, AZ
    Not enough
    Private shop I've used for years. Amazing work, solid crew. Leksfixit.
    Skydvrr[QUOTED] likes this.
  18. Jun 9, 2021 at 9:52 AM
    #198
    AZVern
    Vern
    Phoenix, AZ
    Not enough
    It was just seeping/sweating. Most of the dried coolant was isolated on the pipe way up high and hard to see. They just caught it using a flashlight and really looking around. Nothing down low.
  19. Jun 9, 2021 at 9:54 AM
    #199
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Right on.
  20. Jun 9, 2021 at 12:38 PM
    #200
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    My 4.0 ranger also had a plastic (Bakelite) thermostat housing. I had to replace it twice in 2 years. Never had a leak, but it smelled. Luckily, it wasn’t that hard to get to. All 4.0s had that plastic housing, they did make a metal one for the mustang 4.0 though.
    shakerhood and TAC1 like this.
