Check your Air Intake Hose Clamp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mateo_roberto, Jun 15, 2017.
Did your Turd Gen have a loose/undertorqued air intake hoseclamp
  1. Nope. Both were relatively tight.
    52 vote(s)
    80.0%
  2. At least one was loose, Baja built
    6 vote(s)
    9.2%
  3. At least one was loose, Texas built
    7 vote(s)
    10.8%
  1. Jun 15, 2017 at 9:52 PM
    #41
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Didn't you just do that 6k mile lone wolf overland trip? Your thread was nuked no?
    bshammer0 and avitaco[QUOTED] like this.
  2. Jun 15, 2017 at 9:57 PM
    #42
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    Yeah.
    I was getting crap mileage the whole time. maybe 13/15 ish.
    GPsevinSixx likes this.
  3. Jun 15, 2017 at 10:59 PM
    #43
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    How do you clean the MAF? Never heard of this before. Location and how-to instructions?
  4. Jun 15, 2017 at 11:08 PM
    #44
    mateo_roberto
    mateo_roberto [OP] Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Here ya go.
    My build date was 10/15 in Baja. Has anyone had a loose clamp from Texas?
    Edit: Made one of them poll things, for science.
    Old School likes this.
  5. Jun 15, 2017 at 11:16 PM
    #45
    Dacon
    Danny
    Gilbert, Arizona.
    All my clamps are tight since I installed TRD CAI. Never checked before.
    The above video is for another engine type, looking for directions on our 16-17 tacos.
  6. Jun 15, 2017 at 11:29 PM
    #46
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    It's the same process for most cars, the tacoma isn't special. Remove the upper half of the engine air filter box assembly, popping the two latches and backing off the hose clamp that we're talking about in this thread. Now, you won't be able to take this air filter box out just yet. Why? There's a cable attached to it. What's that cable? Your MAF wiring.
    Disconnect the plug and undo the latch on the air box to free the box lid w/ MAF from the cable. 2 phillips heads, and remove the sensor. Don't touch it with anything except for MAF cleaner, reference the video. Let dry for at least 30 min. Reinstallation is everything in reverse.
    Google is your friend.
  7. Jun 15, 2017 at 11:34 PM
    #47
    Dacon
    Danny
    Gilbert, Arizona.
    THAT! tiny thing? I thought so but wasn't sure. Have 3600mi on it now, do I need to clean it so soon?
  8. Jun 16, 2017 at 4:17 AM
    #48
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    same with some of my electrical tape..
    shakerhood likes this.
  9. Jun 16, 2017 at 5:42 AM
    #49
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    mateo_roberto[OP] likes this.
  10. Jun 16, 2017 at 5:43 AM
    #50
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    I just wonder if something was really loose like this in @AFMurse2014 truck? Something nobody ever picked up on? This is a interesting discovery for sure.
  11. Jun 16, 2017 at 5:45 AM
    #51
    Zoop
    Zoop Well-Known Member
    Texas built, outside was 1-2 turns loose, checking the other tonight after work. If you want it done right, do it yourself! Thanks OP for posting!
    GPsevinSixx and bshammer0 like this.
  12. Jun 16, 2017 at 5:47 AM
    #52
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Crazy to see so many that were loose, glad I said something in the MAF thread and that Mateo created this thread to bring awareness to others.
  13. Jun 16, 2017 at 5:47 AM
    #53
    bshammer0
    Brandon
    Nashville, TN
    Of course you shouldn't really ever NEED to clean it if it was assembled properly and you keep your air filter clean... unless you use an oiled one and then cleaning is more frequent.
    But I've never had to do 90% of the things I've had to do on this low miles, NEW vehicle... acceptance is the first step to recovery. We have to assume things were not assembled correctly then attempt to diagnose with the help of Google and TW.... glad you all are here!
  14. Jun 16, 2017 at 5:49 AM
    #54
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Damn seems like im going to have to checl everything from top to bottom
    bshammer0 likes this.
  15. Jun 16, 2017 at 5:54 AM
    #55
    bshammer0
    Brandon
    Nashville, TN
    So far: 6 months, 12k miles.
    ubolts loose
    ujoints dry
    Warped drum
    Over torqued lugs
    Low tranny
    Low rear diff
    Dirty MAF
    Extremely Loose intake hose
    Suspect Catalytic Converter
    Crappy ECU / fuel maps
    2 transmission TSBs
    Cracked windshield first couple of weeks - from turning on the defroster the first time, tons of scratches since
    Will swap CPS this weekend just to eliminate that potential source of misses / poor MPGs
  16. Jun 16, 2017 at 7:17 AM
    #56
    Willbird
    Willbird Well-Known Member
    Bill
    Magnetic Gray Metallic 2017 SR5 Double Cab
    4/17 Baja, both tight. Also there was a purple dot on each. Working for a co that did work for big three we would often dot features with a paint marker that were being 100% inspected due to a corrective action.
    cwolgy88 likes this.
  17. Jun 16, 2017 at 7:24 AM
    #57
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Seems like we have to go back through the entire truck, check every nut, bolt and fastener to ensure things are torqued and installed properly. Wow. It just makes you wonder what else they fucked up when they were putting these 22,000 pieces and parts together.
    mateo_roberto[OP] and bshammer0 like this.
  18. Jun 16, 2017 at 8:00 AM
    #58
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    That's why warranties exist. Not all 22,000 pieces are assembled correctly and not all 22,000 pieces are made perfectly. Everything fails at one point or another. No point in worrying about it driving yourself crazy over something that may or may not exist
    CusterFan likes this.
  19. Jun 16, 2017 at 8:14 AM
    #59
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    Thanks for the heads up guys. Will check mine when I can get around to it. :thumbsup:
    smitty99 likes this.
  20. Jun 16, 2017 at 8:36 AM
    #60
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Warranties for trucks like ours don't exist because "everything fails at one point or another". They exist because everything is designed with a safety factor that comfortably allows these trucks to hit 36k without going to complete shit. After that, very few of your 22,000 pieces are covered. After 60k, they've C'd their own A, and guess who needs to know how to troubleshoot their truck?
    Yea man thank you. I kind of wrote it off as a fluke when I first noticed it and meant to mention it in the other thread. Thanks!
