check your ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rmodel65, May 20, 2015.
  1. May 22, 2017 at 8:13 PM
    #101
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I have Moog with the lifetime warranty and they are garbage. I have replaced both sides two times in the past 5 years because of play. I grease their zerks regularly but they still fail. If I could go back I would go OEM but since I dont pay for the replacements I continue to swap em every year or two.
  2. May 22, 2017 at 8:52 PM
    #102
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Has the LBJ design changed on later gen Tacomas?
  3. May 22, 2017 at 8:54 PM
    #103
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I have no idea. I sure hope so.
  4. May 22, 2017 at 8:54 PM
    #104
    Rmodel65
    Rmodel65 [OP] Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Yes the joint gets forced together instead of apart like the 1st gens
    cruiserguy likes this.
  5. May 22, 2017 at 9:00 PM
    #105
    ghs57
    Chops
    Catskill Mts. NY
    That's good to know. But of course, that doesn't help any of us.
  6. May 22, 2017 at 9:05 PM
    #106
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    The title for this thread totally should have read "Check your balls."
    hunter357mag and Smiley52 like this.
  7. May 22, 2017 at 9:07 PM
    #107
    Smiley52
    Smiley52 Insta: @Sm1ley52
    Danny
    Melbourne, FL
    2012 SR5 4x4
    Great minds think alike lol
  8. May 22, 2017 at 9:23 PM
    #108
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Really wish there was a way they could re engineer this part, but I don't think it's possible without changing the steering
  9. May 22, 2017 at 9:31 PM
    #109
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A little like playing russian roulette.
  10. May 22, 2017 at 9:31 PM
    #110
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    There is its called a SAS conversion
    ThunderOne[QUOTED] and se7enine like this.
  11. May 23, 2017 at 5:59 AM
    #111
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Same thought I had. Shame.
  12. May 23, 2017 at 7:12 AM
    #112
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    that would involve changing the steering :rolleyes:
  13. May 23, 2017 at 7:15 AM
    #113
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    OK guys, don't over exaggerate the issue. The stock suspension in my truck worked on the road for last 22 years and almost 320k miles. That is quite good by my book. I don't do "wheeling", just occasional low quality dirt roads (however some streets in Wroclaw, Poland can qualify for "wheeling"). If you use this truck for rougher ride and pushing the strength of the front suspension to the limit, maybe 100k miles would qualify for thorough inspection.
  14. May 23, 2017 at 9:30 AM
    #114
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Not really, I check them regularly for play. They have to be pretty bad to fail in a catastrophic manner.
  15. May 29, 2017 at 6:27 AM
    #115
    RysiuM
    Rysiu
    I just came from Toyota Service. Doing oil change and tire rotation (I'm not setup in my new place to do it at home yet) and ordering seat belts, which I couldn't bring from USA on a plane (explosive device restriction). I also asked to do the full inspection of the entire front end especially LBJ. They found some knocking inside the steering rack (it's been there since the day one or at least as long as I remember) and nothing else. All bushings and boots are in like new condition (not even surface cracks), all ball joints with zero play. Their recommendation was to "leave this alone, you will hear first before anything fails".
    BTW this was the third "second opinion" I wanted to get just to be sure in case I don't know what to look for.
    I'm good for the next 10k miles when the truck will be due for the next service.:fingerscrossed:
    This is 95.5 X-cab 4x4 with all factory (22 years old) front end (minus brakes and shocks of course) and 318k city miles (no more than 1k miles mild of road total). I guess first batch of 1st gen Tacoma got the best parts ever made.:hattip:
    Aldog likes this.
  16. May 29, 2017 at 11:16 AM
    #116
    BreezeyFL
    BreezeyFL Member
    Nick
    2001 Toyota tacoma 4x4
    3 inch lift, ARB bumper, ARE Camper top, Warn M8000 winch. Rancho shocks.
    I have a 2001 and I just had 2 ball joint failures that resulted in the wheels coming off. The first one on the passenger side. Rebuilt all the damage an bought Hi end Moog ball joints and installed on both sides. Now the drivers side just failed and the wheel came off in the middle of the road. I have about a 3 inch lift. This seems to have started happening after I replaced the shocks and coil springs. I really need to find out what is causing this so I have a safe truck to drive. Any ideas?
  17. May 29, 2017 at 11:25 AM
    #117
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Buy OEM, not Moog. Moog are known to be of lower quality than the OEM ones.
    Aldog likes this.
  18. May 29, 2017 at 12:57 PM
    #118
    BreezeyFL
    BreezeyFL Member
    Nick
    I thought Moog was top of the line. Where can I get the OEM and will they work with my lift? Some of them did not press in and the moog did. Had to use the press tool. I think it could be something more than just the quality of the ball joint.
  19. May 29, 2017 at 1:03 PM
    #119
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    109,000 miles on mine still going strong! Going to definitely replace them soonish though.
  20. May 29, 2017 at 1:10 PM
    #120
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Are you having upper or Lower ball joint failures?
