Check your bed bolts!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shook0002, Jul 26, 2009.
  1. Jul 26, 2009 at 8:57 AM
    shook0002
    shook0002 [OP] "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Lately I've been getting a thunk from the rear, and also the "bed creak". So today I decided to rotate my tires, while I had some time I pulled out the torx set and wanted to see if my bed bolts were tight. Well they were loose, 3 of the 6 took more that 1 full turn. I don't really load the bed up that often but have towed some cars with the hitch. Maybe that caused some flex. I'm gonna take it for a longer ride this afternoon so I'll see if it helps with the bed creaks. I was kinda surprised to see the bed bolts coming loose, when I get a chance I'm gonna pull them all and use some blue loctite on them.
  2. Jul 26, 2009 at 8:59 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Good catch.
  3. Jul 26, 2009 at 9:03 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Good work man, I will check mine today!!
  4. Jul 26, 2009 at 9:27 AM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    Add some blue loctite to them next time and it may keep it from happening again.
  5. Jul 26, 2009 at 10:07 AM
    bobtackett
    bobtackett Well-Known Member
    chicago heights,illinois
    4x4 trd offroad package
    3inch suspension,side steps,westin brush guard,carbonfiber hood w/scoop
    thanx for the info shook
  6. Jul 26, 2009 at 10:13 AM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    Good point, but I wouldn't stop at the bed bolts. Might as well go through as many as you can. Lately I have been hearing a rattle under the engine and was figuring on going under there to see if there is anything loose.
  7. Jul 26, 2009 at 11:21 AM
    Plain Jane Taco
    Plain Jane Taco I have become comfortably numb
    Bill
    USA
    2015 SW DCSB TRD Sport PR
    Yep, I would too. In fact, if you look at the service manual that comes in the glove box, it says to check major chassis/suspension nuts/bolts as part of the routine service checks.
