Check your fluid level... in the tag / license plate lights!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Jul 4, 2016.
  1. Oct 29, 2016 at 8:27 AM
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I decided what I'm gonna do is blow all the moisture out of it, glob the living crap out of the connector with some dielectric grease, put it back together and see if that stops the issue.
    If it happens again after that, I'll take it to the dealer again.
    This style of light has been used on the Tundra since 2012 so I don't understand why it has problems. On top of that, the driver's side one has been dry as a bone through everything. It's just the passenger side that keeps on doing it.
  2. Oct 29, 2016 at 12:16 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Fired up the compressor, blasted the snot out of both the lens and bulb holder. Carefully wiped the bulb with an alcohol pad, and then slathered dielectric grease all around the seals, and put copious amounts down the back of it where I think the water is coming in. Like a pea-sized glob and change. A decent amount oozed out as I clicked the connector in. Yup, pretty well caked with that goopy shit.:rofl:
    So we'll see. Based on my testing it seems like the lens and main seals are totally OK, and if you have a leak it's getting in from behind the connector, not because the housing itself has an issue.
    I'll keep the OP updated as I have more info.
  3. Oct 29, 2016 at 12:40 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Why try to waterproof something with grease..?? I'd use silicone...(after the housing is all dried out, etc) at least if "firms up" and will solve any water intrusion you may have....?? Obviously H2O is getting in from the back end where the plug fits into the socket... seal that MF'R with silicone rubber....!! Problem solved for 13 more years..!!
    16tacoblue likes this.
  4. Nov 4, 2016 at 4:57 PM
    easyrider88
    easyrider88 Well-Known Member
    2017 Quicksand Tacoma DCSB OR 4X4
    Interesting
  5. Dec 26, 2016 at 1:57 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Bump again... yup, it still leaks. :annoyed:
    Driver's side is still dry as a bone and has been from day 1.
    I have NO idea why the passenger's side leaks constantly. I'm gonna swing by the dealer tomorrow maybe, cause I am genuinely stumped at this point... and if they give me a replacement, this will be the 4th housing!
  6. Dec 26, 2016 at 4:52 PM
    el_zorro1
    el_zorro1 Well-Known Member
    Zorro
    Northern Virginia
    I applied clear silicone to the wiring to the bulb. No more water. In my case it was not the housing but some trickle leak from the wiring.
  7. Dec 26, 2016 at 4:55 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    If you wouldn't mind, could you take a picture or something to show me exactly where to put it? I don't wanna take it all apart and goop up something that won't do anything haha.
  8. Dec 26, 2016 at 5:07 PM
    el_zorro1
    Zorro
    Northern Virginia
    @jmn69 and I exchanged some notes about this sometime in April. Turns out for both of us the water entry was from the wiring itself into the plug and into the bulb socket through the connector. What we did was to silicone seal the wiring harness upstream where the 2 wires first go into the plug. That was where the water was entering.
    Mine has been water free since April.
    tomwil and Nitori[QUOTED][OP] like this.
  9. Dec 26, 2016 at 5:14 PM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Do you think there would be a benefit to the dealer replacing the harness as well as the housing and bulb?
  10. Dec 26, 2016 at 5:27 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Thanks a bunch! :thumbsup::cheers: That shit is a bitch and a half to get out, but I'll have to get around to it soon, before I risk it freezing and cracking the housing or some shit like that.
    My first move is going to see if I can beat a new harness out of the dingleberries at the dealership service dept.
    Clearly that has to be the failure point, and since other 3rd gens do not have this issue, sounds like it probably should!
    el_zorro1[QUOTED] likes this.
  11. Dec 26, 2016 at 5:33 PM
    ExplorHer
    Near Pittsburgh
    That harness is only a few feet long, and easy to replace. Hopefully they do not try to fight you on it.
  12. Dec 26, 2016 at 6:08 PM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    My drivers side is doing this too...
  13. Dec 26, 2016 at 6:17 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I'm going to add a goldfish to mine
  14. Dec 26, 2016 at 6:37 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    You pictures are WAAAAAAAAAAAY out of focus -- and sort of useless --sorry to inform you
  15. Dec 26, 2016 at 7:09 PM
    #35
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I know you've been having a shitload of problems, but is this seriously one of them too?
  16. Dec 26, 2016 at 7:15 PM
    #36
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Holy Shit. Water in the license plate light? Seriously?
    What's next? a TSB for a hood shimmy or water leak in the 3rd brake light...oh wait..
  17. Dec 26, 2016 at 7:34 PM
    #37
    Nitori
    Maricopa AZ
    2021 T4R SR5
    My guess is this is flying under the radar because of overall costs. Harness replacement might actually put a spark under someone's ass.
    Dealer has to shell out a hefty bill for a soaked interior? Yep, that gets someone's attention. Hood shimmy requiring subcontracting out to a 3rd party body shop for a couple hundred bucks? Yep, bean counters notice and try to get to the bottom of it... or at least they should. As much as people like to shit on Toyota and bitch about things, you'll notice a lot of big points (aside from the howling diff I think?) have all been TSB'ed out before 2016 is over. Control Arm noise, 6AT shifting, drive line vibration, etc... Sure they could have been a little faster in terms of month-to-month fixes, but I think a lot of that is caused by shitty personnel at a dealership level not communicating as they should.
    This one, service writers just keep replacing a $2 housing over, and over, and over, and over without stopping to think "hey, maybe it's not the fucking housing if this is the 4th one I've replaced on the same truck!". Because apparently all you need to be a service writer anymore is a pulse, no requirement for any active firing neurons. I'm willing to wager there will be a showdown tomorrow over getting this wiring harness.
  18. Dec 26, 2016 at 7:42 PM
    #38
    ExplorHer
    Near Pittsburgh
    If you really want to get noticed, you could start the Lemon Law process. I'm pretty sure you would have a case since you have repeatedly gone back for the same reoccurring / unresolved issue, and you are the original owner of the vehicle.
  19. Dec 26, 2016 at 7:56 PM
    #39
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I dunno, I don't really want to do that because I love the truck otherwise. Technically under PA law I meet all the requirements except the bolded one:
    • It has a nonconformity (a defect, or condition) the nonconformity is covered by the manufacturer's express warranty (✓)
    • The nonconformity SUBSTANTIALLY impairs the use, market value, or safety of the car (Depends on what we define "Substantial" as.)
    • The nonconformity is not the result of an accident, abuse, neglect, or alteration of the car by persons other than the manufacturer or its authorized dealer (✓)
    • You reported the nonconformity at least once to the manufacturer's authorized dealer during the Pennsylvania Lemon Law Rights Period of 1 year or 12,000 miles whichever comes first. (✓)
    • You gave the manufacturer or its authorized dealer three opportunities to repair the nonconformity. (✓)
    Could I argue that moisture inside a tag light would cause me to fail inspection & thus substantially impair use and/or market value? Probably. Again though I don't want to go nuclear on these people's asses out of nowhere. I'm gonna go there and only use such a force escalation if necessary. Really if they just get me a damn harness and it fixes it, I'll be happy.
    ExplorHer[QUOTED] likes this.
  20. Dec 26, 2016 at 8:15 PM
    #40
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Its good that they are addressing problems via TSB's but I am curious if those issues are now corrected for the 2017s or if the bean counters will have their way and force you to complain and then TSB again.
