Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Aug 14, 2017 at 8:32 AM
    #1201
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You only have the Zerks up front and have to pull down the little shield, I highly doubt that your Dealer did that at your 5k service. I ended up doing my truck at about 1500 miles or so.
    cwolgy88[QUOTED] likes this.
  2. Aug 14, 2017 at 10:33 AM
    #1202
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    The 4WD 2017 only has the front 2?
  3. Aug 14, 2017 at 11:49 AM
    #1203
    shakerhood
    Southern Ohio
    There are no Zerks on the Rear Driveshaft
    cwolgy88[QUOTED] and bshammer0 like this.
  4. Aug 19, 2017 at 9:20 AM
    #1204
    Connecticut_Tacoma
    Connecticut_Tacoma Well-Known Member
    Old Greenwich, CT
    2016 Tacoma TRD SPORT 6-speed Access Cab
    I'm quoting my own earlier post in case anybody would like to see exactly what I used.
    It took me about 15 minutes to do all 5 zerks on my 2016 4x4 tacoma. Four were fully exposed and one had a shield on it which was easily taken off by using a 12mm socket with an extension. All the zerks still had the factory black paint on them so they were never greased up during any of the maintenance inspections at the dealer. It took about 5-6 pumps before grease would start coming out from all over. You can actually hear the grease coming out after the 5th pump. My truck has exactly 29,500 highway miles mostly.
    I'm a wall street guy that just sits in front of the computer all day....if I was able to do it then you can do this easily.
    over60 likes this.
  5. Aug 19, 2017 at 11:17 AM
    #1205
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I'm no grease expert, (it all comes in a tube and makes a mess)...but Maw Toyota says to use NLGI No.2 Grease in the U joints..... That's what I used....
  6. Aug 19, 2017 at 12:15 PM
    #1206
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    The rear u-joints are not sealed at the factory, the Spicer u-joints selected by Toyota have no zirc fittings. In the future we'll see complaints here about their rear driveshaft making noise, or dropping out completely. Sometimes Toyota saves money in the wrong way, but hey, they don't have to drive these 16-17 Tacomas.
    Dannyblues[QUOTED] likes this.
  7. Aug 19, 2017 at 12:28 PM
    #1207
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Generally you need to find the "just enough" amount and not grease until you see grease coming out for things like ball joints. If you are greasing something with a rubber seal then you can bust the seal.
    http://www.suspension.com/blog/how-to-grease-ball-joints/
    For u joints you grease just enough where you barely see grease coming out.
    https://www.yourmechanic.com/article/how-to-lubricate-your-car-s-u-joints-by-ronny-brown
    Vbpiper likes this.
  8. Aug 19, 2017 at 12:40 PM
    #1208
    over60
    Muskoka, Ontario
    Yes, what this guy said in the second link you provided is correct..."grease till you see new grease coming out".... This IS the proper method for U-Joints... Don't know for ball joints cuz, I ain't had a greaseable one since the 50's... hehe
    You do not "blow" the seals on U joints if you over grease..... the only issue is you get grease all over the place.... THE most important thing is that grease purges from ALL 4 Seals on each U joint....! Grease flung all over the bottom of your truck will not hurt the truck... Might mess up yer driveway thought...!!
    Good luck..:thumbsup::thumbsup::burnrubber:
  9. Aug 19, 2017 at 12:44 PM
    #1209
    over60
    Muskoka, Ontario
  10. Aug 19, 2017 at 12:47 PM
    #1210
    gearcruncher
    Canadain bumper technician
    Maybe Mr .splitbolt can update his first thread and explain to the folks that 2 wheel drive trucks come with polypropylene sealed universal joints that are designed for 50,000 trouble free miles .
    If the universal joints have been replaced , chances are the aftermarket joint now has a grease zerk .
    Every oil change is the rule I follow with the exception of the slip yoke . The slip yoke uses a different lubricant and requires disassembly or drill and tap a zerk to lube the splines
    If you have a two piece driveshaft , reports are coming in there is a lack of lubricant on the splines of the slip and stub . Your truck will clunk when downshifting into first gear when cold . Takes a special lubricant
    This stuff will work http://www.lowrangeoffroad.com/ptfe...-ford-motorcraft-xg-8-ml1167-31508-42027.html
    And this stuff is said to be the best but pricey http://paceperformance.com/i-782162...bricant-high-temperature-c1-2-w-a-t-1-lb.html
  11. Aug 19, 2017 at 1:12 PM
    #1211
    over60
    Muskoka, Ontario
    Good advice, as usual..!!
    :thumbsup:
  12. Aug 19, 2017 at 1:47 PM
    #1212
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    I greased my u joints the other day doing my own 10,000 mile service. My rear u joint near the rear diff had a lot of water drip out of it when I greased it. I was surprised how much water actually dripped out as I was greasing it and not in a good way. I've never off roaded my truck or done any water crossings. This was the first time I greased them.
  13. Aug 19, 2017 at 2:05 PM
    #1213
    over60
    Muskoka, Ontario
    Yeah, 10K miles is a long time to go without grease..... they never greased them properly before you bought it... So you put on 10 K with just the factory "assembly grease" in them... likely some wear has occurred..! Good luck... at least you got grease in them now.
  14. Aug 19, 2017 at 2:57 PM
    #1214
    TexTako
    TexTako Well-Known Member
    Houston, TX
    2016 Tacoma MGM 4x4 TRD OR DCSB AT
    Yesterday, I went ahead and tried to grease all zerks in my OR 16' (Built in July 2016) and I verified that there are only 2 zerks for the front shaft only. All others for the rear shaft are sealed, with NO zerks at all. I pumped some grease on the only two zerks but I couldn't get the grease exiting from the seals. I observed that those front u joints have same seals (blue plastic rings) on them. Seems that with a few pumps the joints were already full as it was spreading grease from the zerks not the seals. Anyway, seems that with a sealed U joints is a problem less to care for maintenance.
  15. Aug 19, 2017 at 3:00 PM
    #1215
    shakerhood
    Southern Ohio
    Those front 2 Zerks are a bitch to get good access to, I ended up grinding down the grease fitting on my gun, once I got onto the Zerks it took a good 4 or 5 pumps before any came out from the seals.
    over60 likes this.
  16. Aug 19, 2017 at 3:19 PM
    #1216
    FFBlack
    2019 TRD OFF ROAD
    There's 3 on the rear driveshaft you just have to move the truck back or forward about a foot to get them facing down. My OR was built the same time as yours and there's 3 on the rear shaft.
  17. Aug 19, 2017 at 4:45 PM
    #1217
    over60
    Muskoka, Ontario
    Not necessarily... depends on build date..
  18. Aug 19, 2017 at 4:46 PM
    #1218
    The Real Moondog
    Moondog
    I also find it amazing that some of these U joints are coming dry. No grease at all. Then again my steering box was dry many moons again on our then new 01 Suburban. It lasted about 2500 miles that's way.
  19. Aug 19, 2017 at 4:53 PM
    #1219
    over60
    Muskoka, Ontario
    Yeah, Spicer tells Toyota to grease the U joints once they are installed in the drive shaft, as the pressure cannot be applied till they are held in by the shaft.....
    This is just a F-up by Toyota.... For what reason?... Stupidity OR just trying saving $... who knows..??
    My joints took about 7 pumps of grease before purging water/air and old yucky looking grease.(not much of that)..!
    shakerhood likes this.
  20. Aug 19, 2017 at 4:59 PM
    #1220
    The Real Moondog
    Moondog
    I really appreciate the feedback and I'm going to grease mine. I bet this is not just Toyota though. Like I said, my Suburban many years ago came dry as a bone. It has recirculating ball steering but that steering box was shipped with no grease so it didn't last any time at all. I'm now wondering if I should check my other vehicles.
