checking your hp
Discussion in '1st Gen. Tacomas (1995-2004)' started by Regretless Rob, Jul 30, 2010.
  1. Jul 30, 2010 at 5:58 AM
    Regretless Rob
    Regretless Rob [OP] Well-Known Member
    Robert
    Chino CA USA
    2001 Toyota Tacoma PreRunner SR5
    Painted my stock rims black and polished my lugs, New jvc head unit with 2 12" subs with shut of switch, Side mirrors tinted, FULLBLOWN FM-74267 muffler, In dash wiring for my Garmin 750 GPS & 3Gs Iphone dock with aux plug and charger in dash, Three more cigarette lighter plus under my head unit also in dash, strobe head lights for the hell of ithttp://www.youtube.com/watch?v=3qumylyXOig,
    This might me a dumb question but dose anyone know how to check your hp ?? :D
  2. Jul 30, 2010 at 6:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yep, you need a dyno.
  3. Jul 30, 2010 at 6:58 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
  4. Jul 30, 2010 at 7:00 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Not as accurate as a dyno but you could use a scanguageII
  5. Jul 30, 2010 at 7:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Or the classic 'butt dyno', but that tends to have large inconsistancies...
  6. Jul 30, 2010 at 7:23 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    race a horse...?
  7. Jul 30, 2010 at 7:25 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Geek Squad at Best Buy?
  8. Jul 30, 2010 at 7:34 AM
    Regretless Rob
    Robert
    Chino CA USA
    hahaha i was thinken of doing that but my horse is sick and Im impatient but thanx :D:D:D
  9. Jul 30, 2010 at 7:43 AM
    Regretless Rob
    Robert
    Chino CA USA
    well whats a dyno and how dose it work??
  10. Jul 30, 2010 at 7:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  11. Jul 30, 2010 at 8:07 AM
    Regretless Rob
    Robert
    Chino CA USA
  12. Jul 30, 2010 at 9:20 AM
    AlexanderD
    Alex
    whitby Ontario
    dyno (short for dynamometer) is a largs machine with a drum you put your rear tires on. you strap the truck (or anything else you want to test) down and use it to turn the drum. the 'dyno' uses sensors on the drumb and figures out how much force in what amount of time you put on it. (because HP is a function of time aswell as force).
    tid bit of useless info
    a horse can actually put out a peek of up to 14.7HP
  13. Jul 30, 2010 at 9:26 AM
    JDMcQ
    Whoa there buddy! What is all this technical, useful info? We can't have that sort of talk around here.
    (just kidding, thanks)
  14. Jul 30, 2010 at 9:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That horse probably had a TB spacer installed...
  15. Jul 30, 2010 at 9:35 AM
    JDMcQ
    Where would you install it on a horse?
  16. Jul 30, 2010 at 9:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd like to see the write-up on that......
  17. Jul 30, 2010 at 9:46 AM
    AlexanderD
    Alex
    whitby Ontario
    in between the 6th and 7th vertebra. helps with low to mid range power. better for pulling stumps and doesn't hurt your grain per mile.
    it can be yours for a low low price of $17.50 +shipping. check it out here.
  18. Jul 30, 2010 at 9:56 AM
    98tacoma27
    Ben
    Not Beech Creek
  19. Jul 30, 2010 at 10:48 AM
    JDMcQ
    :laugh:
  20. Jul 30, 2010 at 1:53 PM
    Barnone
    Barnone Guest
    I programmed my SGII to show hp but I don't know how accurate but I guess it could show differences in mods?
