Chipped Paint/Rust Spots
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 31, 2012.
  1. Jan 31, 2012 at 9:33 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    What's recommended for the touch up here? How should I clean up the area?
  2. Jan 31, 2012 at 9:49 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    pictures are worth a thousand words
    are all the chips down past the primer and rusting?
    how big are they?
    I usually use a Dremel to get to bare metal (if rusted) then use a filler/primer followed by color matched touch up and finally throw some wax on top. I only use Duplicolor and I have had good results.
    If it's not down past the primer I scuff it up with an abrasive pad and then touch it up with a couple coats of paint then wax.
  3. Jan 31, 2012 at 9:56 AM
    jeremy_283
    it's just one small chip the diameter of a BB..... and it is rusted a little bit....
  4. Jan 31, 2012 at 10:35 AM
    XXXX
    sKiP
    05 Prius
    Take it down to bare metal and follow the rust out...the rust will have crept under the paint and you will need to remove more paint then is currently chipped. If you do not get out all the rust out it will continue to corrode under the paint.
    Just get a duplicolor primer/filler pan and a color matched pen from either Toyota or duplicolor
  5. Jan 31, 2012 at 10:37 AM
    jeremy_283
    just get some fine sandpaper and wrap it around a pencil eraser?
  6. Jan 31, 2012 at 11:13 AM
    XXXX
    sKiP
    05 Prius
    I must have done over 50 chips on my truck and none of them have begun to rust from underneath or show any signs of trouble. I use a Dremel with a fine point stone for all of them (same as Ive done for the past 15 years).
    No clue about a pencil eraser and sandpaper, but IMO it seems they may be to large to zero in and remove just the paint needed to get to the end of the rust.
  7. Jan 31, 2012 at 1:11 PM
    jeremy_283
    Don't like power tools :eek:... WD-40 and a rag ? :)
