Chirping/Cricket Noise coming from engine on throttle input
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KingZee, Jan 18, 2020.
  1. Jan 18, 2020 at 3:28 PM
    KingZee
    KingZee [OP] Well-Known Member
    Z
    Los Angeles
    2018 TRD OR
    Bootleg Pro Grill / 16” SCS Ray 10 Black / 265/75/16 KO2s / Voodoo 10” Rack / DA Warrior XL
    Hi guys, I looked through the forum a bit and found a lot of discussion regarding the fuel pump squeaking noise but the one coming from my truck doesn’t seem to have the same symptoms, it happens on throttle input only and I can’t hear it at idle. I’m wondering if it’s a loose pulley? Only happens after car is warmed up but it’s consistent. As soon as I’m in a bit of stop and go traffic it starts up and doesn’t go away until truck cools down again.
    It seemed to have started after I got into a little fender bender and truck went into the shop. There was zero mechanical damage, just front bumper and passenger side fender.
    I shot a short video where you can hear it pretty clearly. Any advice/help is greatly appreciated.
    Superdave1.0 likes this.
  2. Jan 20, 2020 at 6:34 PM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    Bump...any ideas guys?
  3. Jan 20, 2020 at 6:37 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Chew and shakerhood like this.
  4. Jan 20, 2020 at 6:37 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Sounds like a bad idle bear or pulley.
    Still have warranty?
    Can you video under hood while someone else revs?
    Freegolf likes this.
  5. Jan 20, 2020 at 6:40 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
  6. Jan 20, 2020 at 6:57 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    That's not your HPFP. Sounds like pulley or serpentine belt.
    KingZee[OP] likes this.
  7. Jan 20, 2020 at 7:07 PM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    Truck has just under 20k miles so yep, definitely still under warranty. Going to take it in for sure I just like to be knowledgeable and possibly fix it or diagnose it myself if it's easy enough before going in. The video you posted was awesome, sub'd to that guy so thanks for that! lol
    yep, I read through the hpfp thread a bit and it convinced me that this isn't the same thing. I'm going to check pulleys and see if I see anything obvious. Thanks!
    Freegolf[QUOTED] likes this.
  8. Jan 20, 2020 at 7:33 PM
    slick7108514
    slick7108514 Well-Known Member
    Arizona
    2018 White Tacoma TRD Offroad DCSB
    Belt. Just had mine replaced under warranty a few weeks ago.
  9. Jan 20, 2020 at 7:52 PM
    bluefiretacohb
    bluefiretacohb Well-Known Member
    Jeremy
    2018 TRD Pro
    Took mine to the dealership recently for the same issue(under warranty). 5 hours later they said “could not replicate sound” and nothing was done. Let us know what they say!
  10. Jan 20, 2020 at 8:00 PM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    Thanks for letting me know. How many miles did you have on your truck? Same symptoms of it only happening when the engine warms up?
    Will do for sure. Was yours making the noise when you took it in? It's definitely not constant for me, only happens when truck really warms up, heavy city driving or traffic. When it's moving along and air outside is cool it's not audible. The good thing is that when it starts it usually doesn't go away until truck has cooled significantly, like next day. If I do take it in I'll make sure to induce the sound before going in if I can learn to replicate it on command. Will update here.
  11. Jan 20, 2020 at 8:22 PM
    enforcertaco91
    enforcertaco91 Well-Known Member
    West is best !
    2024 Tundra Terra (terror) Pro
    PPF Front grill, bumpers and headlights.
    Sounds about right, I'd find another dealer.
  12. Jan 20, 2020 at 10:08 PM
    slick7108514
    Arizona
    14,000 on mine.
    Mine initially was only noticeable when warm for a few months then it got insanely loud after off-roading through a bunch of mud. I felt bad for my entire neighborhood it was so loud.
    New belt has it silent again. Good luck with yours.
    KingZee[QUOTED][OP] likes this.
  13. Jan 14, 2021 at 1:06 AM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    Long overdue update, just realized I never came back to this thread. It was just the serpentine belt.
    @slick7108514 I had also gone mudding and to be certain it was this a little water spray on the belt immediately cut the sound for a second. Thanks for your help.
  14. Jan 14, 2021 at 8:04 PM
    slick7108514
    Arizona
    @KingZee Glad you go it sorted out. I haven't had any issues in the last ~8,000 miles since my belt was replaced.
  15. Jan 14, 2021 at 8:12 PM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    I think it's the belt. My 2016 has done it twice after some offroading, and then also running through a big puddle. It did it for about 2 days then went away both times. I think it was the belt getting dirty, I have 69k on my truck with the stock belt and it's quiet after both times it temporarily did it.
  16. Jan 19, 2021 at 8:24 AM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    It was the belt. I was hoping it would go away but just kept getting worse. I think the mud really got into it. It was an easy fix though.
    Toyota09[QUOTED] likes this.
  17. Jan 19, 2021 at 10:24 AM
    Toyota09
    Good to know. Literally, the day after I wrote this post, I had to open my hood and then upon shutting it I got the squeak back too. After a few days of driving it has gone again. I think I knocked more dust onto my belt. Did you do an oem replacement?
  18. Jan 19, 2021 at 3:04 PM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    Nah just bought one from a local auto shop and replaced myself. If you want to be 100% sure it’s the belt spray some water on it while it’s running and the noise should go away immediately
