Choosing Between
Discussion in 'Suspension' started by H0LLYW00D, Aug 22, 2010.
Which One
Poll closed Sep 21, 2010.
  1. Toytec Ultimate Lift Kit for 2005 & Up Tacoma with Bilstein 5100 rear shocks & Dakar leaf springs
    9 vote(s)
    33.3%
  2. Icon 05-Up Tacoma Suspension System - Stage 4
    18 vote(s)
    66.7%
  1. Aug 27, 2010 at 6:10 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Maybe he wants a design that is one piece? I'm sure the ARB is much sturdier, but depending on what you are doing, you will probably never use it that hard.
  2. Aug 27, 2010 at 6:27 AM
    H0LLYW00D
    H0LLYW00D [OP] Well-Known Member
    I also find that ARB is airbag rated which is reassuring. Been looking at the ARB weight online and have it seems to be about 80 lbs.
  3. Aug 27, 2010 at 6:52 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    All bumpers are air back compliant just fyi. The Tacoma's air bag sensors are based on inertia. This was a huge topic months ago that was discussed, here's some reading if you would like. So whatever bumper you chose, buy with confidence your air bags will deploy. (Oh and the sensors are not located in the bumper).
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/61502-front-bumper-4.html
    That's all I'm going to say, I'm not trying to convince you of one or the other. Just want you to have all the information for an informed purchase :)
    Good luck with your set up and take pics :thumbsup:
  4. Aug 27, 2010 at 12:01 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'd also go relentless fab front bumper over AP. has the same looks to it, but one piece and actually sturdy/beefy. in the future i'll either get a relentless fab bumper or pay someone to weld together my AP bumper into one piece. it'll still be weaker than the relentless, but sturdier than it is now.
  5. Aug 28, 2010 at 6:59 AM
    H0LLYW00D
    I think I finally have my parts list sorted out for my 3" lift build that I will do this winter. I am curious to know what everyone thinks of the part and if there are any parts that I need that I forgot.
    Icon 05-Up Tacoma Remote Reservoir Front Coil-over Shock Kit [5-8730]
    Icon 05-Up Tacoma Rear Reservoir Shocks [5-7505]
    Dever Springs Custom 3" Lift Leaf Pack
    Dever Springs U-Bolts
    Total Chaos 05+ Toyota Tacoma U.C.A.[96504]
    Toytec Front Diff drop kit [TAC-DR-05]
    Toytec Zinc Axle Shims (3 Degree) 05 & UP Tacoma [TT-RS-846]
    I might eventually add these parts to the suspension:
    Total Chaos Stock Uniball Lower Control Arms with Dual Shock Capability [86500]
    Total Chaos Dual 2.5” Shock Hoop System [86602]
    Icon Secondary Front Shock ​
  6. Aug 28, 2010 at 7:24 AM
    Masada
    Taylor
    Laveen, AZ
    Parts in red:
    I wouldn't bother with the diff drop, it's been proven it really doesn't do much of anything for your CV angle. Install the lift first then see if you really want to go for it. All it's going to do is drop the diff about 1/2 an inch, not really enough to make a difference.
    Deavers are going to give you more flexability, but less payload capacity. If you still plan on using the back of your truck for hauling, I would think about the OME Dakars. Everything else looks like a really nice setup. The back end setup will just boil down to what you plan on useing your truck for. :)
