Christmas lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd, Dec 12, 2007.
  1. Dec 12, 2007 at 12:37 PM
    nd
    nd [OP] Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    This may need to be moved to the suspensin forum but i figured i'd get more responses here. When my parents asked what i wanted for Christmas, i couldn't really think of anything, so i'm thinking about a lift. they are willing to spend between $200 - $300. Here's my question. What do i get? I've already decided that i'm just gonna move up to 32" tires instead of 33". That is unless someone can make a compelling argument about why i need that extra inch.... personally i'd rather have a wider 32" and have more surface area on the ground, than a taller thinner 33". Pro's? cons? i need any and all input on this.
    Also, i have the suspension TSB done. If i do decide to get 33's then i'll need to lift the back another inch and cant use the AAL with the toytec lift since i already have the 4th leaf. as far as i know, with the TSB, the only way to do that (cheaply) is with blocks, and i have heard too many negative things about blocks.
    Now the front, I originally thought about doing spacers which are $140 from toytec. Then i noticed that the 5100's are only $60's more. Personally i hate to replace something thats not broken but for only 60 bucks more i can put in those 5100's and get my lift there. $140 for spacers. $200 for 5100's. Once again, i need any and all opinions. regarding lifting the fron.
    Assuming i lift the front only and not the rear, i am still planning on the diff drop kit, but i still need rear shims and driveshaft bearing drop?
    I dont know guys, help me decide what i need!
  2. Dec 12, 2007 at 12:41 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    I've got nothing to offer other than I have been thinking of the exact same thing.I'm looking forward to the responses here...Thanks for posting.
  3. Dec 12, 2007 at 12:47 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Can you give me their contact information? I have some neat suggestions on what they can get you. :laugh:
  4. Dec 12, 2007 at 12:56 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    Insert your own joke here
  5. Dec 12, 2007 at 1:01 PM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bird feed,
    Bird cage,
    Mini brewery kit,
    Navigation system with bird migration path's,
    Gift certificates to local strip joint,
    Inflatable (turkey) doll,
    Portable urinal,
    Airline tickets to Canada with transit in Dallas, Texas.
    I've got to go now but I will continue the list later. :mad:
  6. Dec 12, 2007 at 1:09 PM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    :eek: :eek: :boink: :laugh: :laugh:
  7. Dec 12, 2007 at 1:46 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    get the lift your truck already has 32s i think 265s i put 33s on becaue i wanted the bigest tire i could if you get the tsb done dont do the back untill you see what it looks like just order the stuff for the front i went with spacers because of the price i bought new tires at the same time so money was limited that dicsion is up to you you still need the diff drop you wont need shims in the rear because you are not changing the angle i think i dont know to much about the 2nd gen trucks but this is my opion
  8. Dec 12, 2007 at 2:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey nd............just remember that a taller, thinner, not so wide tire will be better in the mud than a wide tire. and go for a revtek or toytec lift.
  9. Dec 12, 2007 at 2:25 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    and if ur wanting to level it and dont wanna add anything else to the rear, just get a 2.5" lift in the front....get 3" and it'll look like u've got a lot of junk in ur trunk. i'm planning on going w/ a 255/75/17=32x10 come spring. bfg mud-terrain t/a km's btw...
  10. Dec 12, 2007 at 2:38 PM
    2003greenbean
    socaste,sc
    03 trd
    that funny even for a canadian
  11. Dec 12, 2007 at 4:55 PM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    I just ordered the Toytec lift, and their tech department says that the AAL isn't an option if the TSB's been done because they won't fit, not to mention the rather solid ride one would get. The TSB swaps the existing 3-leaf for a 4-leaf pack. Stock, the back is already higher than the front, and from what I understand the TSB lifts the back another inch which makes the back 2" higher than the front. If you just lift the front, it will end up about an inch higher than the rear. The 3 inch lift has 1 and 1/2" block option for the rear which is what Toytec recommends if you've had the TSB done. Axel wrap isn't really an issue with such a short block--it isn't a problem unless you start going crazy or stacking blocks to get height. I'm still working out the tire question myself, so I can't really help any there. Dunno if any of this is what you are looking for, but there ya go...
    Stock tires are 265/65/17 on mine which is like 30.5"; 265/70/17 is like 31.6" or so. 33s may or may not fit even with a 3" lift the front spaces are tight--Toytec's FAQ might be helpful to you. Or email them; they are very helpful and quick to email back (they say within 24 hrs on the website).
  12. Dec 12, 2007 at 6:32 PM
    The_Hodge
    SC
    people run 33's w/ 3" of lift in the front....ie LQQK for sure. he's running 285/70/17's...not on stock rims...but w/ just 3" up front.
  13. Dec 12, 2007 at 6:41 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    The question isn't if he can run 33's. It's why the extra inch of 33's over 32's is important or not.
  14. Dec 12, 2007 at 6:41 PM
    rick
    rick `
    bilstein 5100's on top notch with your rear leaf tsb. end of story
  15. Dec 12, 2007 at 6:51 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    Give me their contact info so I can give them suggestions on what they can get me!:thumbsup:
  16. Dec 12, 2007 at 6:58 PM
    The_Hodge
    SC
    i was referring to the last sentence of charli's post
  17. Dec 12, 2007 at 7:01 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    So was I.
  18. Dec 12, 2007 at 7:03 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I'm curious about the answer to 33" vs. 32" as well, it's a decision I need to make.......I keep bouncing back and forth on what size I want.
  19. Dec 12, 2007 at 7:11 PM
    2003greenbean
    socaste,sc
    03 trd
    get 33s so if you add more lift in the fut you tires dont look smalll
  20. Dec 12, 2007 at 7:26 PM
    Charli
    Chuck?
    Ohio
    Sorry, was refering to the comment:
    And I've been told that I can't run 33s with a 3" lift (by ppl in RL, not on this forum), so I thought I'd mention it. Actually, I'm glad to know that 33s are an option.... but not on stock rims?
