Christmas lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd, Dec 12, 2007.
  1. Dec 12, 2007 at 7:27 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    You can put them on stock rims, but you'll need spacers.
  2. Dec 12, 2007 at 7:38 PM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    Cool! Thanks! Tires are the pricey part tho.....that'll be in the future. Can't decide what kind I want anyway. All the reviews are spinning in my head. I want somehting with some road song for sure tho. Oops, sorry, didn't mean to drag this post off topic....!
  3. Dec 12, 2007 at 9:18 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    i went with 33's instead of 32's because i think it feels up the wheel well a little better and i personally think the taller the better...... i loved mine at first, and still do, but now i want 35's :eek:
  4. Dec 13, 2007 at 3:15 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Only go 2nd or 3rd notch. I did mine at the 2nd and it sits 1/4" higher in the front with the tsb.
  5. Dec 13, 2007 at 6:53 AM
    nd
    nd [OP] Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Holy crap i have alot of responses to respond to....
    hate to admit it, but pretty funny, good job Cannuk
    The stock off-road tires are 31 inches and some change. I'm considering 32's cause i'm thnking about just a 2.5" lift for the front and nothing for the back since i already got a small lift from the TSB. I dont have to worry about 32's rubbing, plus they get slightly better mileage than the 33''s maybe not a whole lot but every little big counts. I was considering spacers till i realized that a set of two 5100's is not much more than the spacers.
    Actually i have read and heard multiple times that wider is much better than thinner in mud due to having more surface area. A thinner tire "cuts" down through the mud much easier. I've heard that surface area is actually more important than tread. All tread, no matter how rugged eventually gets filled with mud, essentially turning your tires into "slicks". Thats when having a wider tire is better than a thinner tire. Also, nobody has been able to tell me why 33s are so much better than 32's (aside from greenbean mentionion appearance if i lift it more)
    Yah, thats why i'm thinking 5100's. That should level my truck without me needing to do anything in the rear. if i got 3 inch i would need blocks for the back.
    Thanks for the response Charli. Its nice to see a new member jump right in and start posting helpful stuff right off the bat. I think you're gonna fit in just fine here :)
    yeah, my original plan was the 3" lift with the AAL. Then i got the TSB done and the AAL is no longer an option, and my back end sits higher. So a 2.5" lift should level it out without me having ot do anything to the back. I think the back is more than 2" higher than the front. it was higher to start off with and now with the TSB it got a little over a 1 inch lift. As far as blocks, i dont really know anything about them. I dont know what axle wrap is but i know its bad and blocks can cause it. So i'll avoid them if i can. Thanks for the response, it was very helpful.
    exacytly, thank you Toy. I now i CAN run 33''s but dont know what the benefit is over 32's. Bean mentioned appearance but i want to know how it is better off-road. I'd rather not shave or rub so 32's will probably be fine for what what i do.
    Thats exactly what i'm thinking. I'll PM you to get some details about your setup if you dont mind. thanks rick.
  6. Dec 13, 2007 at 6:58 AM
    nd
    Nate
    Greenville, SC
    yeah, you can run 33's with a 3" lift on stock rims. you may have some rubbing depending on the width
  7. Dec 13, 2007 at 7:00 AM
    nd
    Nate
    Greenville, SC
    almost all threads get hijacked so dont worry about it. I've heard nothing but good things about BFG AT's or MT's. Good performance for a good price
  8. Dec 13, 2007 at 7:04 AM
    nd
    Nate
    Greenville, SC
    I'm not exactly sure what you mean. first of all i dont know what the notches are ont eh 5100's. is 3rd the highest? also, when you say 1/4" higher... doyou mean higher than stock or higher than the back end?
  9. Dec 13, 2007 at 7:40 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Ok ND,
    To answer the question that you originally asked. What benefit does a 33 offer over a 32? (figured I'd re-cap incase anyone forgot)
    A 33" diameter tire is 1 inch taller than a 32" diameter tire (assuming for a minute that we are talking about the same brand, and model, and that all tires really do measure to what they advertise.)
    So if you center them up and lay one on top of the other you'll find that the 33" tire protrudes 1/2" all the way around as compared to the 32" tire.
    That is going to be your one and only functional benefit. 1/2" more running ground clearance. In the real world, that may prevent a high center (though I suspect if you really were going to high center that a half inch won't help that much), and it may prevent your skid plate from taking a hit that it may otherwise have taken.
    That said, I agree with your plan, of going with the TSB in back, and 5100's in the front, though I am curious about your plan to go with the diff drop. I remember being told when I planned to lift my 04 that I could go up to a 2 1/2" front lift before needing a diff drop, and that is what we are basically talking about here. Has the point at which the diff drop is necessary changed with the gen 2 trucks? Help me out here?
  10. Dec 13, 2007 at 8:00 AM
    nd
    Nate
    Greenville, SC
    Thanks for the response Mav. I was wondering if a 1" difference in the tires would equate to anything in terms of torque or anything technical liek that that i dont understand. I really think i'm gonna go with the 5100's up front and leave the back alone. Does anyone know if i could add a 1/2 inch or 1 inch spacer to the 5100's later on down the road if i wanted a little extra lift?
    As far as the diff drop i'm not sure. I just assumed i woudl need it but if not then thats great! I have no idea at hwat point you need to compesate for the adjusted angles. guess i need to figure that out. I just want to do whatever i can to keep the lift from affecting my truck negatively.
  11. Dec 13, 2007 at 8:19 AM
    maverick491
    South Jersey
    Ahh, see, I thought you asked for "benefit." As far as "differences" go, fuel mileage, and torque, they are both going to drop, because you will be turning more rotational weight, so it will take more energy to turn the 33" tire than the 32" tire, and that is energy that used to be uset to move the truck, and now it is moving the tire instead. If that makes any sense, though I am not sure how much of a decrease you'll see from a 32 to a 33. Your speedometer will also be off more, though I can never remember if it will be higher or lower when you increase tire size.
    As to putting spacers in the 5100's I don't think you can do that, I seem to remember reading that in another thread somewhere, but I did not subscribe to it, so I can't seem to find it now.
  12. Dec 13, 2007 at 8:27 AM
    Charli
    Chuck?
    Ohio
    Axle wrap is "unwanted suspension movement that allows the pinion angle to change." Stacking blocks makes the problem worse due to instability. Any way, none of that matters since you aren't doing that anyway, but I'm a geek when it comes to information.
    Thank you for the compliment!
    Toytec is sort of non-commital on the diff drop stuff--they don't say its "required" just that its "a good addition" (their words), but they also don't specify what height lift its "a good addition" to. I'm not gonna say anything more than that since I really don't have any idea whether it's at all necessary with the 2.5" front lift.
    The 5100's and leave the back alone sounds good to me--it's not like you couldn't do something to the back later if you don't like it, but I also don't know why you wouldn't like it since it's pretty much gonna put you level.
  13. Dec 13, 2007 at 8:37 AM
    nd
    Nate
    Greenville, SC
    Thanks for the continued response evreryone. Now i guess the big question is... do i need hte diff drop kit with the bill 5100's? Does anybody know?
  14. Dec 13, 2007 at 11:10 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    if you are looking i love my pro comp x terrian tires
  15. Dec 13, 2007 at 11:14 AM
    #35
    2003greenbean
    socaste,sc
    03 trd
    you need the drop after 2in i think you want it to keep from wearing out the front end
    i feel your pain i want more lift
    i have herd this before also
  16. Dec 13, 2007 at 1:25 PM
    #36
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    is the diff drop just for 4x4?
  17. Dec 13, 2007 at 2:26 PM
    #37
    maverick491
    South Jersey
    Correct.
    The diff drop lowers the front diff so that the front driveshafts still remain more in-line with the hubs to reduce stress on the CV joints.
    Pre-runners or solid axle swap guys don't have to worry about this.
  18. Dec 13, 2007 at 2:59 PM
    #38
    Charli
    Chuck?
    Ohio
    Thanks greenbean! I looked 'em up, and they look good, but ouchie! on the price!
  19. Dec 13, 2007 at 3:00 PM
    #39
    jhodge83
    SC
    17 XLT Sport
    good deal
  20. Dec 13, 2007 at 3:33 PM
    #40
    Toy4Life
    Chad
    Slippery Rock, PA
    I got my eye on the Firestone Destination MT's
