clanking noise coming from the engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Apr 3, 2011.
  1. Apr 3, 2011 at 7:46 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    Just the like the title says, there's a clanking noise coming from the engine when going pretty fast (55+). It doesn't have a steady rythm to it, it's pretty speratic. Only happens when I'm on the highway pressing the gas pretty good or when I'm going 50 or so and going up a hill, so I guess it only happens when the engine is working pretty hard. Started happening a few days ago and it's pretty noticable. Any ideas what it could be? It's hard to pinpoint exactly where it's coming from since it only happens when the truck is moving.
  2. Apr 3, 2011 at 9:20 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    sounds like you might have a little rod knock to me
  3. Apr 3, 2011 at 10:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you rev up in nuetral do you hear it?
  4. Apr 4, 2011 at 3:57 AM
    DaytonLax14
    Corey
    Ohio
    sorry to be dumb but what does that mean?
  5. Apr 4, 2011 at 5:19 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Knock sensor might have gone south so the timing isn't being properly adjusted under load. In my old van I used to drive with the engine cover open and adjust the timing to the point where it didn't knock under load in third gear, of course no easy way to do that in a new vehicle.
  6. Apr 4, 2011 at 4:39 PM
    jblair
    Colorado
    99 taco 2.7L I4
    it's where the push rod hits the head, but honestly it's pretty much impossible to know or even guess what the problem is with abnormal engine noises without being there and using a stethoscope. That's one of those things that you should take to a shop and have them look at it.
  7. Apr 4, 2011 at 4:42 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    No push rod in that motor
