Clanking noise from front end normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DiffLock, Sep 25, 2017.
  1. Dec 17, 2017 at 2:38 PM
    #121
    DiffLock
    DiffLock [OP] Well-Known Member
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Yes I do have a trd pro skid and sway relocation kit... BUT... this happened on my stock truck with no aftermarket parts too (cheap black skid plate).
  2. Dec 17, 2017 at 2:52 PM
    #122
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Me too!
  3. Dec 17, 2017 at 2:52 PM
    #123
    Jason TRD OR
    I forgot mine did this stock as well! Anybody have any ideas
  4. Dec 17, 2017 at 2:58 PM
    #124
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    I'm pretty sure its the front axles where they connect the diff. shake yours and see. probably a normal thing.
  5. Dec 17, 2017 at 3:37 PM
    #125
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    I popped my skid and the skid support bars off, placed washers in between the frame and skid supports, then re torqued all bolts. No more touchy, no more sound.
  6. Dec 17, 2017 at 3:39 PM
    #126
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    interesting.. what kinda skid do you have?
  7. Dec 17, 2017 at 6:29 PM
    #127
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    It's the oem on the sport. So it may be different for anyone else with OR or aftermarket. But worth a look.
  8. Dec 17, 2017 at 7:32 PM
    #128
    TacoinMD
    TacoinMD Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    I have the same noise on the driver's side front, just started at 5k miles. Hours under the truck, all of the suspension components that move are tight. I'm taking the truck to the dealer in a few days, however, I'm not expecting a fix, rather I'm expecting the old, "Can't duplicate" response. I'm going to take the advice of others and replace the front body mount bolts at my cost. Standby for both the dealer's response and the results of the body mount replacement.
    UPDATE:
    The dealer replaced the front two body mount bolts and bushings. The metal on metal creaking noise is gone.
    Leathermatt and BOZOJUICE like this.
  9. Dec 19, 2017 at 6:45 PM
    #129
    BOZOJUICE
    BOZOJUICE Well-Known Member
    2023 ICE CAP PRO
    I went under my truck today and did find my driver side axle is making the same noise, was able to shake with my hand. I do believe this is the problem, will have dealer inspect soon. Passenger side did not make the rattle. Thank you for your post.
    My passenger was making a squeak, so they replaced the shock and tower parts under warranty. One shock only and strut parts.
  10. Dec 19, 2017 at 8:00 PM
    #130
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Mine is driver side as well. Why are these so loose?
  11. Dec 19, 2017 at 8:20 PM
    #131
    Fieldy23
    Fieldy23 New Member
    2016 DCSB Tacoma 4x4
    My '16 DCSB 4x4 was making this noise starting at about 2000 miles. Dealer said it was a loose body mount bolt and tightened it which fixed the issue for about 800 miles but then it started again. Second time around they replaced the mount and it hasn't made the noise since, now have 42000 miles on it. Hopefully this will help
    BOZOJUICE likes this.
  12. Dec 20, 2017 at 3:32 AM
    #132
    92PathSE
    92PathSE Well Known "member"
    GA
    It's a shitty design they've had since the 80s but they refuse to redesign it properly. Buy the upgrade from ECGS.
  13. Dec 20, 2017 at 10:03 PM
    #133
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    UPDATE
    Front two body mounts replaced. NO MORE NOISE.
    Tech told me they were mangled. And suspects they were misaligned from factory.
    61ragtop and RangerComa like this.
  14. Dec 21, 2017 at 2:57 AM
    #134
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Its funny how this issue has spanned two generations of Tacoma's, glad they fixed it for you. I know when I replaced mine and the creaking stopped it was a good feeling
  15. Dec 21, 2017 at 5:40 AM
    #135
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Interesting that it can come from the factory that way.
  16. Dec 21, 2017 at 12:34 PM
    #136
    TacoinMD
    Tim
    Ft. Lauderdale, FL
    UPDATE:
    After 2 days with 2 different techs, the front body mount bolts and bushings were replaced. The creaking metal-on-metal noise while traveling over speed humps is gone.
  17. Dec 21, 2017 at 12:46 PM
    #137
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Glad it is solved for you. I still think mine's different. More of a rattle, I think from those front axles.
  18. Dec 26, 2017 at 9:22 AM
    #138
    Jason TRD OR
    I think it may be the cv because everything else is tight on mine as well. Shitty design
  19. Dec 26, 2017 at 10:15 AM
    #139
    Swissdog
    Swissdog Member
    Kaaahh-Lee forn yaaa
    16 TRD Off road
    Does running into things count as a mod?
    I’ve noticed a distinct “thunk” coming from the passenger side front, mostly off road and in 4 high. I told the dealership, but they weren’t able to find anything wrong and weren’t able to replicate the noise. I have stock suspension/stock tires and a Demello Baja front bumper.
    Checked the passenger side front end out and didn’t feel anything that was loose, except for some play in the axle, .5mm or less. Boots were in good shape. Suggestions?
  20. Dec 27, 2017 at 10:47 AM
    #140
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    Jokes on me,
    The sound is STILL there.
    Thought it was gone but nope! fuck
    61ragtop likes this.
