Clanking noise help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 808wildboi, Nov 14, 2017.
  1. Nov 14, 2017 at 10:09 PM
    808wildboi
    808wildboi [OP] Haaaawaiian!!!
    chase
    kailua kona
    2003 Toyota Tacoma DC 4x4
    My truck is making a clanking noise. :annoyed: I checked the belts, I checked the oil, anything that is visible and I can’t see where it’s come from. The check engine light and trac off light is on. Anyone have this problem? I took it to Toyota and it’s been in the shop since this morning. They don’t want to tell me what it is. So all they told me is that they ordered parts and they won’t come in til next week. So frustrating. Does anyone know if Toyota is supposed to give out a loaner since it’s still under warranty? :confused:
  2. Nov 14, 2017 at 11:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They should give you a loaner if they are keeping your truck
    Key-Rei and Oldman808 like this.
  3. Nov 15, 2017 at 7:54 PM
    rectangleboy
    rectangleboy Member
    Mountain View, CA
    When would it make the clanking noise?
    I know someone that might be having the same issue as you.
  4. Nov 17, 2017 at 11:49 AM
    808wildboi
    chase
    kailua kona
    I went down Toyota yesterday, they finally gave me a loaner. My truck will be down for awhile:frusty: turned out it’s something to do with the crankshaft. So Toyota is just replacing the crankshaft and a few other parts! Shouldn’t they just change out the whole motor? Anyone know if I can get my money back? Would rather get a 2nd Gen Tacoma.
  5. Nov 17, 2017 at 12:36 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
  6. Nov 17, 2017 at 12:44 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
  7. Nov 17, 2017 at 12:46 PM
    rodrigger
    rodrigger Active Member
    Canada, BC
    2017 Tacoma TRD Sports Upgrade
    crankshaft replacement?? surely they must have found a major problem here. How can a clanking noise from an engine go right to a crank replacement. Since the engine is still turning...so how did they determine that crankshaft is at fault, is it a spun bearing or bearing wipe out. Did they drop the lube oil pan and found lots of metal pieces???OR see bearing wipeout.... If that's the case then I think a lots of us should be concerned. Its previously reported , people are finding metal in their lube oil change even after 5k interval. THIS CAN BE A BIG ISSUE!!! FOR ALL 2017 and maybe 2016
  8. Nov 17, 2017 at 12:49 PM
    over60
    Muskoka, Ontario
    I think I'd change that "clanking" fan belt before I took it to the dealer.... You know they always replace the motor when that kind of clanking occurs... you will be without yer truck for at least 2 months...!! Ask them to throw in a 4.0 motor from the 2nd gen...!!
    Good luck.
  9. Nov 17, 2017 at 12:57 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
  10. Nov 17, 2017 at 3:46 PM
    808wildboi
    chase
    kailua kona
    I talked to one of the service department reps, and he said they put it on a machine and the codes that popped up was coming from the crankshaft. That’s all I know.
  11. Nov 17, 2017 at 3:55 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Ahh, the notorious replace crankshaft dtc. I always hated that one.
    daddy_o and over60 like this.
  12. Nov 17, 2017 at 4:15 PM
    daddy_o
    Bossier City, La
    That may be the CKP. Crankshaft position sensor.
    Do these trucks have knock sensors?
  13. Nov 17, 2017 at 5:34 PM
    rodrigger
    Canada, BC
    crankshaft position sensor makes more sense..... there is a recall on this for some 2016/17 model
    "The worst case scenario would be a crankshaft sensor failure at speed, which could result in the engine quitting. Considering power assist for things like steering and brakes would disappear with an engine failure, Toyota identifies this condition as a safety risk, hence the recall."
