Clean throttle body
Discussion in 'Technical Chat' started by DanGer, Mar 29, 2009.
  1. Mar 29, 2009 at 5:26 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I searched around and couldnt find any threads but how do you clean your throttle body? Hoping someone will make a DIY or tell me how so I can
  2. Mar 29, 2009 at 5:29 PM
    mar_ga_rita
    mar_ga_rita Head of the MASTERS CIRCLE
    New Orleans
    2003 Tacoma SR5 PreRunner TRD
    BUG SHIELD BULL BAR OFF-ROAD LIGHTS 4-RUNNER FOG LIGHT SWITCH K&N EYE OF THE TIGER ON THE BACK GLASS TONNEAU COVER
    I used to be a mechanic and we used to just take off the air filter tube from the throttle body and while it is running spray in some carb cleaner... lot of carbon would burn outta the intake and worked pretty well
  3. Mar 29, 2009 at 5:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i usually just take the hose off the tb while the motor is off. then,i'll spray seafoam deep creep all thru the tb, and open the butterfly and spray more....clean with a tooth brush, then spray more until its all shiny inside. hook everything back up, then crank the truck. you'll have to crank it for a minute to get it to fire, then it'll puff a bit of smoke and you'll be set.
  4. Mar 29, 2009 at 5:47 PM
    DanGer
    thanks both of you! I bought a gallon of sea foam a bit ago :D would it be any different to spray that in through a windex type bottle?
  5. Mar 29, 2009 at 5:49 PM
    mar_ga_rita
    New Orleans
    I donno... have never used seafoam....
  6. Mar 29, 2009 at 5:50 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    regular seafoam and seafoam deep creep are 2 different products
  7. Mar 29, 2009 at 5:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i wouldnt do it that way. regular seafoam is a lil different than the deep creep. get a can of the deep creep specifically for the tb, and use the rest for the gas tank. use about 16 ounces per oil change.
