Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Sep 27, 2017 at 1:03 PM
    #541
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Garmin and chrisrocks300 like this.
  2. Sep 29, 2017 at 3:42 AM
    #542
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    You sir are a Genius! I never would have thought to use the AC drain grommet. I just ran my coax last night from the bed, under the cab and through the AC drain grommet. Total time may have been 30 minutes.
    Thank you!
    chrisrocks300[QUOTED] likes this.
  3. Sep 29, 2017 at 8:55 AM
    #543
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Work smart not hard
  4. Sep 30, 2017 at 1:02 PM
    #544
    FoleySwampPlotts
    FoleySwampPlotts [OP] Well-Known Member
    Klint
    Upper Peninsula, Michigan
    '16 MGM Tacoma TRD OR DCSB 4x4 V6 Std Trans
    '16 Tacoma- Avid side steps, LED interior lighting, yaesu ft-2900R VHF radio (KD8EHC), dog box, Garmin Alpha, Plott Hounds Wife's rig '12 Rav4 4x4 4cyl.... its a cupcake, but a damn good runner
    doesn't flop around unless it hits limbs and brush
  5. Oct 6, 2017 at 8:20 PM
    #545
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    This is how I've got my Cobra 75WX ST set up on mine. This is one of the blanks ahead of the shift lever.
    [​IMG]IMG_1455[3895] by Mike M, on Flickr
    Yes, it's not 100% centered, my measurements were slightly off. However, I got it set up perfectly without a scratch on it, so I'm calling it a win. I've got a 4' Firestik on a CBI ditch light bracket with a spring and quick disconnect. I just need to reassemble the center console and I'm good. My SWR measured nearly 1.0 on Channel 1 (needle barely moved) and about 1.3 on Channel 40. I'm not planning on touching it.
    I'm on the fence on mounting the mic, but I figure it's a case of plugging in the antenna and microphone when I'm ready to use it. I have an external speaker that I'm unsure if I will use.
    DrFunker likes this.
  6. Oct 7, 2017 at 12:52 PM
    #546
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    DJFriar, eurowner, Mr-Paul and 8 others like this.
  7. Oct 9, 2017 at 7:46 AM
    #547
    DrFunker
    DrFunker Well-Known Member
    Just got one of these ext. speakers. Was looking for options on mounting.
    Thinking of cutting into the overhead sunglass holder. Then I would need to extend the cable to the box.
    hmmm.....
    any ideas? Anyone else do this besides @MeefZah ?
  8. Oct 9, 2017 at 11:48 AM
    #548
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    I bought a little external as well but haven't figured out where to mount it. Was thinking above the seatbelt mount on the driver side above the driver left shoulder.
    Also wish it would stop raining today so I can do the whole cb install and oil change since it's my only day off
    DrFunker[QUOTED] likes this.
  9. Oct 9, 2017 at 11:51 AM
    #549
    DrFunker
    That would be a good spot too. :rolleyes:
    Think I am going to hack into the sunglass holder and run an extension down to the box.
    Dgibson529[QUOTED] likes this.
  10. Oct 9, 2017 at 11:52 AM
    #550
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Probably smart. I imagine getting a replacement sunglasses holder part is cheap. Might look into there too
  11. Oct 9, 2017 at 11:55 AM
    #551
    DrFunker
    Yeah. Was thinking the same thing. Would be the smallest part. But ya know....I can't get that door out easily. Wondering if there is some trick to getting it out without snapping the two little tabs.
  12. Oct 9, 2017 at 11:57 AM
    #552
    DrFunker
    Could always just use the bracket it came with too and put a couple smallish holes in that door instead. :rolleyes:
  13. Oct 9, 2017 at 12:27 PM
    #553
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Hmm. Haven't really tried removing it ever. Honestly I never even touch the sunglasses holder. Such a waste of space if you ask me
  14. Oct 9, 2017 at 12:28 PM
    #554
    DrFunker
    Same. That is why I was thinking of doctoring it up a bit.
    :sawzall:
  15. Oct 9, 2017 at 1:48 PM
    #555
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Where'd you run the power through the firewall?
  16. Oct 9, 2017 at 1:50 PM
    #556
    DrFunker
    No. I just just an add-a-fuse.
    I know it's not the best, but it does work.
    I have too much shit going into the battery right now.
    Aux fuse block is on the list. Has been for a while.
  17. Oct 9, 2017 at 2:13 PM
    #557
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Ya this is the only thing I have to the batt right now. Found a spot to get it through just trying to figure out a good spot to mount the radio
  18. Oct 9, 2017 at 3:01 PM
    #558
    DrFunker
    What radio are you going with?
  19. Oct 9, 2017 at 5:30 PM
    #559
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Uniden bearcat
  20. Oct 9, 2017 at 5:31 PM
    #560
    chrisrocks300
    Brandon, MS
    Nice choice
