Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016+)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Mar 6, 2016 at 8:07 PM
    #41
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I installed a Yaesu FT-7900R in my 2016 Tacoma today. The RF deck was installed behind right rear seat. I ran a circuit with 12 AWG from a 40A fuse in the aux fuse block I had previously in the engine compartment, through the firewall, under the threshold of the drivers-side doors to the storage tub behind the rear seat. I mounted a RIGrunner 4005H behind the seat to allow circuits for powering additional radios and other items. I used a 40A relay to switch power on-off for the entire RIGrunner controlled by a push switch installed in the dash. I ran the cable for the detachable faceplate and external speaker under the threshold of the passenger-side doors. I mounted the Yaesu MLS-100 speaker to the underside of the front passenger seat running the cable under the carpet to the underside of the seat. I have not decided which location to mount the faceplate yet so the faceplate cable is hanging out from under the passenger-side of the dash at the moment. Candidate locations for mounting the faceplate are (1) in the overhead sunglass holder, (2) The windshield GoPro mount, and (3) the top of front cubby in front of the gear shift where the Qi charger is.
    The RF deck install behind the rear passenger-side seat:
    Powered from a 40A fuse from the aux fuse block in the engine compartment:
    The 12 AWG wire for the power and the 16 AWG wires for the relay switching power on-off for the Yaesu FT-7900R controlled by a dash switch are run through the firewall and under the drivers-side door thresholds and under the B-piller:
    The cables for the external speaker and the detachable faceplate are run under the passenger-side door thresholds. The cable for the speaker can be seen turning and diving under the carpet to the underside of the front passenger seat:
    The speaker is mounted under the front passenger seat (shown unbolted and lifted away from the floor):
  2. Mar 7, 2016 at 6:28 AM
    #42
    Ender1524
    Ender1524 Member
    Detroit MI
    Very clean install. Where is your faceplate going?
  3. Mar 7, 2016 at 10:49 AM
    #43
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Details on the switch panel deal you made? Is it just ABS behind the snap in surround?
    C41n likes this.
  4. Mar 7, 2016 at 2:46 PM
    #44
    qnyla
    NM
    CheerioMatey, shrka, jpham and 3 others like this.
  5. Mar 7, 2016 at 7:21 PM
    #45
    qnyla
    NM
    I mocked it up and test fit the Yaesu FT-7900R faceplate on the GoPro mount to see how it looked. I used some RAM mounts I had around and purchased a GoPro mount with a 1/4-20 threaded hole. The view and location were fine, but the passenger sun visor would not clear it. This does not work for me, so the GoPro mount is eliminated as a possible install location. I may look at a longer RAM arm to move the faceplate further toward the center above the mirror. Of course at that point you might as well mount to the mirror rather than the GoPro mount.
    Some photos for those interested below. This was just a test fit so ignore the cables hanging off it.
    Yikes, I need to clean my mirror, the flash makes it look filthy!
    Sun visor does not clear:
    I also test fit the faceplate in the sunglass holder. It would drive me nuts to drive around with the sunglass holder hanging down. The sunglass holder also eliminated for me as a possible install location.
  6. Mar 7, 2016 at 7:22 PM
    #46
    AFMurse2014
    Devin
    San Antonio
    Damn that's clean. I wonder if it could be altered to use 1x1 square switches so 6 could be used over 3.
  7. Mar 7, 2016 at 7:49 PM
    #47
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    The dash opening is smaller than 2x3 so that wouldn't work without butchering the lower dash panel, besides, you'd also need some additional space between the switches.
  8. Mar 8, 2016 at 5:33 PM
    #48
    AFMurse2014
    Devin
    San Antonio
    Looks like I need smaller switches lol
  9. Mar 29, 2016 at 10:46 AM
    #49
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Nice, installs. I'm going to look for some options here.
  10. Apr 13, 2016 at 9:50 PM
    #50
    qnyla
    NM
    I mounted the faceplate for my Yaesu FT-7900R in front of the gear shift using "Extreme Industrial Velcro". Seems rock solid. Ran the cable through a hole drilled in the back corner of the cubbyhole.
    Durango95, vicali, I'mTheDude and 3 others like this.
  11. Apr 14, 2016 at 6:46 AM
    #51
    Woodrow F Call
    Colorful Colorado
  12. Apr 16, 2016 at 8:15 PM
    #52
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I'm going to put a straight blank plate up when I get home in a week, maybe 1/8" to 3/16" thick, that can replace the cubby and be modified by the end user for whatever item you want to cut into it. I don't know of a radio that'll actually fit there but it'll certainly open up some options for some people.
  13. Apr 17, 2016 at 7:04 AM
    #53
    Woodrow F Call
    Colorful Colorado
    Cool. I'd like to see what you come up with. I'm thinking that the area is big enough to house a remote face install.
  14. May 16, 2016 at 6:27 PM
    #54
    oorah54
    oorah54 Well-Known Member
    Darren
    Guyton, GA
    2015 Blue Tacoma Base
    Has anyone come up with a way to install an antenna on the bed of the truck with a tri-fold tonneau cover?
    YDCtaco likes this.
  15. May 19, 2016 at 2:42 AM
    #55
    FoleySwampPlotts
    FoleySwampPlotts [OP] Well-Known Member
    Klint
    Upper Peninsula, Michigan
    '16 MGM Tacoma TRD OR DCSB 4x4 V6 Std Trans
    '16 Tacoma- Avid side steps, LED interior lighting, yaesu ft-2900R VHF radio (KD8EHC), dog box, Garmin Alpha, Plott Hounds Wife's rig '12 Rav4 4x4 4cyl.... its a cupcake, but a damn good runner
  16. May 19, 2016 at 7:02 AM
    #56
    Squirrel cage
    Squirrel cage Well-Known Member
    Sam
    Reno NV
    2016 DCSB TRD OFF ROAD
    Icon stage 4 lift,FN Countersteer wheels (16X8), 285/75/16 Duratracs
    Any info on the GoPro mount that you tried? I've been looking and can't seem to find the right one. I have some RAM mount stuff, and think I can get it to all work for my Yeasu FT8800.
  17. May 19, 2016 at 7:49 AM
    #57
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    FoleySwampPlotts [OP] likes this.
  18. May 19, 2016 at 9:13 AM
    #58
    Cows Have Claws
    Cows Have Claws Well-Known Member
    Oregon
    2020 Army Green TRD-Pro
    What is that circle thing that is sticking out the cutout? My truck doesn't have that. Also what size bolts did you use to mount that to the inside wall of the engine bay?
  19. May 19, 2016 at 10:48 AM
    #59
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    I don't have a tonneau cover, but I have a canopy. This was my solution (inspired by others).
  20. May 19, 2016 at 11:16 AM
    #60
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Clutch reservoir.
    Key-Rei and Cows Have Claws like this.
