I made a thing for switches because the thing I wanted didn't exist.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forty2, Feb 11, 2016.
  1. Feb 11, 2016 at 6:02 PM
    forty2
    forty2 [OP] Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Keeping things in the cab relatively stock looking is kind of a big deal for me, I don't like the look of Autozone toggles everywhere so when I needed to add a couple switches I decided to make a thing rather than hack my dash. I made a switch plate to fit in place of the somewhat useless (at least to me) dash pocket to the left of the steering wheel. It's sized to fit two Toyota style 22mm x 32mm push button switches.
    Fit's the space really nicely with minimal coaxing to fit the switches in as well and the plate to the dash panel. Tight fitting all around means that nothing will rattle. Cheap Ali Express switch color isn't 100% to OEM and neither is the black panel they are mounted in, but I'm sure I'll get over it eventually. I'm always my worst critic.
    EDIT - Getting a lot of questions at the end of the thread so I'm bringing the important stuff to the top post so you don't have to wade through every post to get to it. I made the part, it worked. Put it up for sale on Shapeways, a 3D printing service that pays me a small cut for every unit sold. Shapeways makes very high quality prints, something that simply can't be matched with consumer level printers, plus you can choose from a wide range of colors (if you're into that). Also, I designed a three switch version for the narrower Toyota style switches, installed photo courtesy of @ekimerpud:
    Both plates can be purchased though Shapeways, this is the link for the two switch version, and this is the link for the three switch version.
    Please note: These two switch plates take two different size switches. The two switch plate takes the fatter Toyota style switches, like the stock switches in the lower center console. The three switch plate takes the narrower Toyota style switches, same size as the "Clutch Start Cancel" switch below where the plate mounts, automatic transmission trucks have a blank fill plate in this location.
    At some point in the thread I also discussed making a plate for Carling switches, that is not going to happen since they won't fit without modification to the lower dash panel and my goal is a simple and clean solution that is both OEM looking and reversible.
    EDIT #2 - Added a simple blank out plate. You can find it here. Drill some holes and put any kind of switch you like in there.
    EDIT #3 - As requested in a PM I added a two switch plate using the narrow switches. Model can be found here. This may be a better option than the dual fat switch plate since it seems like there's a better variety in the narrow switches.
    EDIT #4 - At the request of a member I've added another variant. This is same as the three switch plate with the rightmost switch location swapped with a pair of Keystone mounts. Model is here. If you're wondering what this is for, it's probably not the blank for you, but for a select ham nerds (myself included) this might just be the clean mic jack you've been looking for. Use for running two mics, hot swapping one mic between radios, or simply use a blank out plate to eliminate what you don't need. Due to space constraints the keystone is oriented sideways with the push clip to the left.
    EDIT #5 - Updated list of all variations of my cubby replacement panels and associated products:
    First one I made, two short OEM style switches, this is the only cubby plate making use of this size switch:
    https://www.shapeways.com/product/EWH4EQRKR/tacoma-switch-plate
    Two switches:
    https://www.shapeways.com/product/24SYWZ66V/dual-narrow-switch-plate-16-tacoma
    Three switches:
    https://www.shapeways.com/product/CHMNWZF8H/tacoma-narrow-switch-plate-for-16-tacoma
    Two switches in the left and center positions, blank on the right:
    https://www.shapeways.com/product/GG2MSUX4J/two-switch-panel-with-right-blank
    Blank plate, no holes at all:
    https://www.shapeways.com/product/BKRG3BWST/2016-tacoma-dash-pocket-blank-plate
    Mounting hole for RedArc Tow Pro on the left, blank center and right:
    https://www.shapeways.com/product/XMYEH7Z4F/2016-tacoma-switch-plate-w-space-for-redarc-towp
    Mounting hole for RedArc Tow Pro on the left, OEM switch center, and blank right:
    https://www.shapeways.com/product/SLLX8MHJQ/3rd-gen-toyota-switch-plate-w-towpro-and-single-c
    Mounting hole for RedArc Tow Pro on the left, OEM switches center and right:
    https://www.shapeways.com/product/3EALSXSAD/3rd-gen-tacoma-two-switch-panel-w-redarc-towpro
    Two switches in left and center positions, double keystones on the right
    https://www.shapeways.com/product/D5YMDZE2N/tacoma-dual-narrow-switch-with-double-keystone
    Two round switches as found included with Rigid products:
    https://www.shapeways.com/product/DSP526ZQN/3rd-gen-toyota-tacoma-switch-plate-for-round-rigid
    Add anywhere single switch, requires cutting, accepts short OEM style switches:
    https://www.shapeways.com/product/Z9RGWG4AN/single-switch-panel
    Add anywhere double switch, requires cutting, accepts short OEM style switches:
    https://www.shapeways.com/product/ZZYW6KN22/simple-two-switch-panel
    Add anywhere keystone holder, requires cutting:
    https://www.shapeways.com/product/4LN869W6N/keystone-holder
    OEM short switch sized keystone holder:
    https://www.shapeways.com/product/22APYPH5F/short-toyota-switch-blank-with-keystone
    OEM short switch sized mic hanger:
    https://www.shapeways.com/product/95RW38ETC/toyota-switch-mic-mount
    CMAH, Jammers1971, TPickles and 100 others like this.
  2. Feb 11, 2016 at 6:04 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  3. Feb 11, 2016 at 6:05 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Wow, nice! :thumbsup:
    ramonortiz55 likes this.
  4. Feb 11, 2016 at 6:15 PM
    ekimerpud
    ekimerpud Well-Known Member
    Fort Worth, TX
    Are you willing to share the mode .stl file? I have a printer.
    OVNI and MGMTaco17 like this.
  5. Feb 11, 2016 at 6:17 PM
    ekimerpud
    Fort Worth, TX
    and are you willing to modify it to hold 3-4 taller toyota buttons? (like the Clutch Start Cancel button)
    ScottyR likes this.
  6. Feb 11, 2016 at 6:21 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I prefer to keep my IP protected but thanks for asking.
    Yes, sometime next week I'll be modifying for 3 of the narrow Toyota switches and either 2 or 3 Carling (not sure yet how many fit).
    LocoLocal and proven21 like this.
  7. Feb 11, 2016 at 6:23 PM
    ekimerpud
    Fort Worth, TX
    Thanks. Count me in on a 3 switch plate.
  8. Feb 11, 2016 at 6:24 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Curious how much that costed to produce?
  9. Feb 11, 2016 at 6:34 PM
    12CRZto16Tacoma
    12CRZto16Tacoma I love what you do for me, tacoma.
    2016 DC Red Tacoma
    Stocks
    @forty2 can you put 2 prewired dc in it instead? I buy it. I find it useful, i can plug-in usb power or dc power devices.
  10. Feb 11, 2016 at 6:35 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Markup is $2.00 + rounding to the nearest dollar. 3.5% of the markup goes back to Shapeways, the rest gets paid out to me.
    Jtcmedic and proven21 like this.
  11. Feb 11, 2016 at 6:38 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I can't put prewired anything in since it's just the printed plastic that gets produced by Shapeways. If you have a product in mind that you'd like to see in the panel link it here. When I get a chance I'll buy whatever it is you want to see in there and adapt the model to it. Won't model anything without product in hand though. I don't like to print the unknown.
  12. Feb 11, 2016 at 6:58 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    When will your Sand Ladder be available?
  13. Feb 11, 2016 at 7:06 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Can you 3D print me a solid axle swap kit and some King Shocks? Thanks.
    Just playin around, but that does look top notch. I love the OEM look and I'm pretty sure the quality is damn near just as good. :thumbsup:
    3GTaco and high n mighty like this.
  14. Feb 11, 2016 at 7:28 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Didn't really have the strength I was going for, as a display piece it works well enough though. Just didn't want to start selling them and have people disappointed in the performance that isn't there. You can see it in the background here:
    If you actually want one I'll make it available. At $1 markup plus rounding it comes in at $11 or $12 depending on color.
    Bullnettles, Hkusp45 and bobsuruncle like this.
  15. Feb 11, 2016 at 7:35 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    @forty2, is that a pic of a model? I don't wanna sound stupid but the way the lighting is and all it really looks like it???
    YDCtaco likes this.
  16. Feb 11, 2016 at 7:40 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I assume you mean in post #15, yes. All 1:10 scale, two Tamiya M-chassis, an HPI Cup Racer and barely visible was once an Axial SCX10.
  17. Feb 11, 2016 at 7:42 PM
    NewRider
    Travis
    '87 4runner
    Ya that's what I was talking about and that's AWESOME m the detail is crazy!
    Dean724 likes this.
  18. Feb 11, 2016 at 7:46 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    This is what's mostly out of frame:
  19. Feb 11, 2016 at 7:54 PM
    NewRider
    Travis
    '87 4runner
    That's absolutely f'n whiled! I thought about setting up model trains as a kid but never had the patience... Did you build all that?
    And sorry to distract from the thread topic... That is one hell of a clean mouting plate!
  20. Feb 11, 2016 at 8:02 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
