Cleaned TB, engine now "knocks". Please help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aught2TaCO, Jul 4, 2013.
  1. Jul 4, 2013 at 7:39 AM
    Aught2TaCO
    Aught2TaCO [OP] Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Got the 3.4l, changed oil, plugs, wires, cleaned the MAF sensor and performance was improved, no problems. I then changed the belts and cleaned the throttle body after noticing it was dirty. Used CRC and a clean shop towel, and covered a hole after noticing the CRC going down it. Soaked up as much as I could out of that hole (two squirts CRC) and then just wiped the TB clean. I started it up and heard/felt nothing until I put it into gear, then I get a "knocking" sound coming from somewhere in the engine. I try to pinpoint the area of the sound, but it still eludes me. A little help is greatly appreciated!
  2. Jul 4, 2013 at 7:44 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    A knocking like engine ping or pre detonation?
  3. Jul 4, 2013 at 7:53 AM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    I want to say neither, it's more like a slapping sound. Kinda hollow sounding. Could it be the belts are too tight?
  4. Aug 29, 2013 at 2:47 PM
    mc3404
    mc3404 Well-Known Member
    Concord ,NC
    03 v6 tacoma
    Any fix for the knocking sound?
  5. Aug 29, 2013 at 5:16 PM
    fpradojr36
    fpradojr36 Well-Known Member
    J.R.
    90804
    04 Prerunner, 2019 TRD 4x4
    Well first of all, I'm pretty a lot of can relate. These tacomas in my opinion already have a tick knock noise. I think thats normal. But if you noticed it more after tune up.. Maybe check oil level, oil filter?
  6. Aug 29, 2013 at 11:48 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    UPDATE: I can't believe you found this thread mc3404, I was hoping it got buried. Anyway, the sound I created came from over tightening the belts. With the engine idling and in "park", I get normal engine sounds, including the "tick" of what I believe to be a valve that needs to be adjusted. When I shift into any drive gear, there's another noticeable sound along with a "knock" that can be felt when the gear selector is held. The sound is hard to describe, I can only say that it has a glub glub glub rhythm along with the knock and is RPM specific.
    In other words I fucked something up, but I have yet to start to find out because my back is giving me problems and I struggle around a vehicle for now. All fluids are clear with no leaks, engine temp, p/s,a/c and volts are all good for now, I just need to put one belt on at a time to see where my problem is. If anybody has had a similar experience please give input.
  7. Aug 30, 2013 at 4:50 AM
    mc3404
    Concord ,NC
    03 v6 tacoma
    Yes, I have the exact same problem. And when you turn the AC on it makes it even worse.
  8. Aug 31, 2013 at 1:30 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Take the a/c belt off and see if it eliminates the noise. It's a bit of work, but it's worth a try to see where your problem is.
  9. Aug 31, 2013 at 2:00 PM
    mc3404
    Concord ,NC
    03 v6 tacoma
    I just replaced te compressor because I was positive it was te culprit. It was not
  10. Sep 1, 2013 at 6:01 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Too tight of a new belt on used components can cause a immediate failure of said component. Watch those tensions. You can also pull a spark plug wire with the engine running to hear differences or changes on individual cylinders. Insulated spark plug boot puller is your friend on that deal,,don't bare hand that.
    Cheap wrong weight engine oil can cause funny noises. Not failures per say, but weird sounds from the engine. Those internal timing/balance shaft chain tensioners like the good stuff.
